RS10N60F
N Channel MOSFET
ID
RDS(ON)(Typ )
VDSS
10A
0.6Ω
600V
Applications:
• Switch Mode Power Supply(SMPS)
• Uninterruptible Power Supply (UPS)
• Power Factor Correction (PFC)
Features:
• Fast switching speed
• 100% avalanche tested
• Improved dv/dt capability
Ordering Information
Part Number
Package
Marking
Packing
Qty.
RS10N60F
T0-220F
RS10N60F
Tube
50 PCS
Absolute Maximun Ratings Tc= 2 5℃ unless otherwise specified
Symbol
Parameter
RS10N60F
Units
V
VDSS
Drain-to-Source Voltage
600
ID
Continuous Drain Current TC=25℃
10
IDM
Pulsed Drain Current (Note*1)
40
PD
Power Dissipation
39
W
VGS
Gate- to- Source Voltage
±30
V
EAS
Single Pulse Avalanche Engergy
L = 10mH, VDD = 50V, RG = 25 Ω
320
mJ
A
Maximum Temperature for Soldering
TL TPKG
TJ and
TSTG
300
260
Leads at 0.063in(1.6mm)from Case for 10
seconds
Package Body for 10 seconds
Operating Junction and Storage
Temperature Range
-55
to 150
* Drain Current Limited by Maximum Junction Temperature
Caution: Stresses greater than those listed in the“ Absolute Maximum Ratings” Table may cause
permanent damage to the device.
www.reasunos.com
1 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
Thermal Resistance
Symbol
RθJC
RθJA
Parameter
RS10N60F
Junction-to-Case
Junction-toAmbient
Units
Test Conditions
℃/ W
Drain lead soldered to water cooled
heatsink, PD adjusted for a peak
junction temperature of + 1 5 0 ℃
1.92
62.5
1 cubic foot chamber,free air.
OFF Characteristics TJ= 25℃ unless otherwise specified
Symbol
BVDSS
IDSS
IGSS
Parameter
Min.
Typ.
Max.
Units
600
V
1
µA
100
-100
Min.
Typ.
Max.
Units
Static Drain- to- Source OnResistance(Note*2)
0.6
0.72
Ω
VGS=10V,ID=5A
Gate Threshold Voltage
3
4
V
VGS=VDS,ID=25
0µA
Drain- to- source Breakdown
Voltage
Drain- to- Source Leakage
Current
Gate- to- Source Forward
Leakage
Gate- to- Source Reverse
Leakage
nA
Test Conditions
VGS=0V,ID=250µ
A
VDS=600V,VGS=
0V
VGS=30V ,VDS=0
V
VGS=-30V ,VDS=
0V
ON Characteristics TJ=25℃ unless otherwise specified
Symbol
RDS(on)
VGS(TH
Parameter
Test Conditions
Resistive Switching Characteristics Essentially independent of operating temperature
Symbol
Parameter
Min.
Typ.
Max.
td(ON)
Turn- on Delay Time
45
trise
Rise Time
28
td(OFF)
Turn- OFF Delay Time
190
tfall
Fall Time
75
www.reasunos.com
2 /9
Units
nS
Test Conditions
VDS=300V
ID=10A
RG=25Ω
Copyright Reasunos
RS10N60F
N Channel MOSFET
Dynamic Characteristics Essentially independent of operating temperature
Symbol
Parameter
Min.
Typ.
Max.
Units
Test Conditions
Ciss
Input Capacitance
1363
-pF
VGS=0V
VDS=25V
f=1.0MHz
Coss
Output Capacitance
139
Crss
Reverse Transfer Capacitance
18
Qg
Total Gate Charge
42
Qgs
Gate- to- Source Charge
6
nC
VDS=400V
ID=10A
VGS=10V
Qgd
Gate-to-Drain(" Miller") Charge
22
Min.
Typ.
Max.
Units
Test Conditions
Source- Drain Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current
10
A
ISM
Maximum Pulsed Current
40
A
Integral pn- diode
in MOSFET
VSD
Diode Forward Voltage
1.4
V
IS=5A,VGS=0V
trr
Reverse Recovery Time
552
nS
Qrr
Reverse Recovery Charge
2.76
µC
VGS=0V
IS=10A,di/dt=100
A/µs
Notes:
* 1. Repetitive rating, pulse width limited by maximum junction temperature.
* 2. Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 1%
www.reasunos.com
3 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
Typical Feature Curve
www.reasunos.com
4 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
www.reasunos.com
5 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
Test Circuits and Waveforms
www.reasunos.com
6 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
www.reasunos.com
7 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
Package outline drawing(TO-220F Unit: mm )
www.reasunos.com
8 /9
Copyright Reasunos
RS10N60F
N Channel MOSFET
Disclaimers:
Reasunos Semiconductor Technology Co.Ltd (Reasunos) reserves the right to make changes without
notice in order to improve reliability,function or design and to discontinue any product or service without
notice .Customers should obtain the latest relevant information before orders and should verify that such
information in current and complete.All products are sold subject to Reasunos's terms and conditions
supplied at the time of orderacknowledgement.
Reasunos Semiconductor Technology Co.Ltd warrants performance of its hardware products to the
speciffications at the time of sale.Testing,reliability and quality control are used to the extene Reasunos
deems necessary to support this warrantee. Except where agreed upon by contr- actual
agreement,testing of all parameters of each product is not necessarily performed.
Reasunos Semiconductor Technology Co.Ltd does not assume any liability arising from the use of any
product or circuit designs described herein.Customers are responsible for their products and applications
using Reasunos's components.To minimize risk,customers must provide adequate design and operating
safeguards.
Reasunos Semiconductor Technology Co.Ltd does not warrant or convey any license eith- er expressed or
implied under its patent rights,nor the rights of others.Reproduction of inform- ation in Reasunos's data
sheeets or data books is permissible only if reproduction is without modification
oralteration.Reproduction of this information with any alteration is an unfair and deceptive business
practice. Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such altered
documentation.
Resale of Reasunos's products with statements different from or beyond the parameters stated by
Reasunos Semiconductor Technology Co.Ltd for that product or service voids all exp- ress or implied
warrantees for the associated Reasunos's product or service and is unfair and deceptive business practice.
Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such statements.
Life Support Policy:
Reasunos Semiconductor Technology Co.Ltd's Products are not authorized for use as cri- tical
components in life support devices or systems without the expressed written approval of Reasunos
Semiconductor Technology Co.Ltd.
As used herein:
1. Life support devices or systems are devices or systems which: a.are intended for surgical implant into
the human body, b.support or sustain life,
c.whose failuer to when properly used in accordance with instructions for used provided in the laeling,can
be reasonably expected to result in significant injury to the user.
2.A critical component is any component of a life support device or system whose failure to system
whose failure to perform can be reasonably expected to cause the failure of the life support device or
system,or to affect its safety or effectiveness.
www.reasunos.com
9 /9
Copyright Reasunos
很抱歉,暂时无法提供与“RS10N60F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.38680
- 10+1.96560
- 50+1.78200
- 100+1.55520
- 500+1.45800
- 1000+1.39320
- 国内价格
- 1+1.59900
- 10+1.47600
- 30+1.45140
- 100+1.37760
