RS60N50D
N Channel MOSFET
ID
RDS(ON)(Typ )
VDSS
50A
14mΩ
60V
Applications:
• Load Switch
• PWM Applications
• Power Managment
Features:
• Fast switching speed
• 100% avalanche tested
• Improved dv/dt capability
Ordering Information
Part Number
Package
Marking
Packing
Qty.
RS60N50D
T0-252
RS60N50D
Tape&reel
2500 PCS
Absolute Maximun Ratings Tc= 2 5℃ unless otherwise specified
Symbol
Parameter
RS60N50D
Units
V
VDSS
Drain-to-Source Voltage
60
ID
Continuous Drain Current TC=25℃
50
ID
Continuous Drain Current TC=100℃
35
IDM
Pulsed Drain Current
200
PD
Power Dissipation
89
W
VGS
Gate- to- Source Voltage
±20
V
85
mJ
EAS
Single Pulse Avalanche Engergy
L = 0.5mH,VDD = 30V, VG = 10V, Tj = 25℃
Maximum Temperature for Soldering
TL TPKG
Leads at 0.063in(1.6mm)from Case for 10 seconds
Package Body for 10 seconds
TJ and
Operating Junction and Storage
TSTG
Temperature Range
A
300
260
-55 to 150
* Drain Current Limited by Maximum Junction Temperature
Caution: Stresses greater than those listed in the“ Absolute Maximum Ratings” Table may cause permanent damage to the device.
www.reasunos.com
1 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
Thermal Resistance
Symbol
Parameter
RS60N50D
Units
Test Conditions
Drain lead soldered to water cooled
RθJC
Junction-to-Case
1.8
heatsink, PD adjusted for a peak
junction temperature of + 1 5 0 ℃
℃/ W
RθJA
Junction-toAmbient
60
1 cubic foot chamber,free air.
OFF Characteristics TJ= 25℃ unless otherwise specified
Symbol
BVDSS
IDSS
IGSS
Parameter
Min.
Typ.
Max.
Units
Test Conditions
60
V
VGS=0V,ID=250µA
Drain- to- Source Leakage Current
1
µA
VDS=60V,VGS=0V
Gate- to- Source Forward Leakage
100
Gate- to- Source Reverse Leakage
-100
Min.
Typ.
Max.
Units
14
mΩ
VGS=10V,ID=30A
17
25
mΩ
VGS=4.5V,ID=30A
1.2
1.6
2.5
V
Drain- to- source Breakdown
Voltage
VGS=20V ,VDS=0V
nA
VGS=-20V ,VDS=0
V
ON Characteristics TJ=25℃ unless otherwise specified
Symbol
RDS(on)
VGS(TH)
Parameter
Static Drain- to- Source OnResistance
Gate Threshold Voltage
Test Conditions
VGS=VDS,ID=250µ
A
Resistive Switching Characteristics Essentially independent of operating temperature
Symbol
Parameter
Min.
Typ.
Max.
td(ON)
Turn- on Delay Time
7.4
trise
Rise Time
5.1
td(OFF)
Turn- OFF Delay Time
28.2
tfall
Fall Time
5.5
www.reasunos.com
2 /9
Units
nS
Test Conditions
VDS=30V RL=6.7Ω
RG=3Ω VGS=10V
Copyright Reasunos
RS60N50D
N Channel MOSFET
Dynamic Characteristics Essentially independent of operating temperature
Symbol
Parameter
Min.
Typ.
Max.
Units
Ciss
Input Capacitance
2050
Coss
Output Capacitance
158
Crss
Reverse Transfer Capacitance
120
Qg
Total Gate Charge
50
Qgs
Gate- to- Source Charge
6
Qgd
Gate-to-Drain(" Miller") Charge
15
Min.
Typ.
Max.
Units
Test Conditions
VGS= 0V
pF
VDS=30V
f=1.0MHz
VDS= 30V
nC
ID=20A
VGS=10V
Source- Drain Diode Characteristics
Symbol
Parameter
Test Conditions
IS
Continuous Source Current
50
A
ISM
Maximum Pulsed Current
200
A
VSD
Diode Forward Voltage
1.2
V
IS=20A,VGS=0V
trr
Reverse Recovery Time
28
nS
VGS=0V
Qrr
Reverse Recovery Charge
40
nC
di/dt=100A/µs
Integral pn- diode
in MOSFET
IS=20A
Notes:
* 1. Repetitive rating,pulse width limited by maximum junction temperature.
* 2. Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 1%
www.reasunos.com
3 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
Typical Feature Curve
www.reasunos.com
4 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
www.reasunos.com
5 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
Test ircuits and Waveforms
www.reasunos.com
6 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
www.reasunos.com
7 /9
Copyright Reasunos
RS60N50D
N Channel MOSFET
Package outline drawing(TO-252 Unit: mm )
尺寸
尺寸
符号
W
尺寸
符号
Min
Max
6.50
6.70
W1
(4.572)
符号
Min
Max
Min
Max
L1
0.80
1.20
T1
0.48
0.58
L2
0.60
1.00
T2
0.95
1.15
W2
0.6
0.8
L3
9.70
10.30
T3
0.48
0.58
W3
0.68
0.88
L4
1.30
1.70
T4
0.00
0.12
W4
L
(5.3)
6.00
www.reasunos.com
L5
6.20
T
(5.20)
2.20
8 /9
2.40
Copyright Reasunos
RS60N50D
N Channel MOSFET
Disclaimers:
Reasunos Semiconductor Technology Co.Ltd (Reasunos) reserves the right to make changes without
notice in order to improve reliability,function or design and to discontinue any product or service without
notice .Customers should obtain the latest relevant information before orders and should verify that such
information in current and complete.All products are sold subject to Reasunos's terms and conditions
supplied at the time of orderacknowledgement.
Reasunos Semiconductor Technology Co.Ltd warrants performance of its hardware products to the
speciffications at the time of sale.Testing,reliability and quality control are used to the extene Reasunos
deems necessary to support this warrantee. Except where agreed upon by contr- actual
agreement,testing of all parameters of each product is not necessarily performed.
Reasunos Semiconductor Technology Co.Ltd does not assume any liability arising from the use of any
product or circuit designs described herein.Customers are responsible for their products and applications
using Reasunos's components.To minimize risk,customers must provide adequate design and operating
safeguards.
Reasunos Semiconductor Technology Co.Ltd does not warrant or convey any license eith- er expressed or
implied under its patent rights,nor the rights of others.Reproduction of inform- ation in Reasunos's data
sheeets or data books is permissible only if reproduction is without modification
oralteration.Reproduction of this information with any alteration is an unfair and deceptive business
practice. Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such altered
documentation.
Resale of Reasunos's products with statements different from or beyond the parameters stated by
Reasunos Semiconductor Technology Co.Ltd for that product or service voids all exp- ress or implied
warrantees for the associated Reasunos's product or service and is unfair and deceptive business practice.
Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such statements.
Life Support Policy:
Reasunos Semiconductor Technology Co.Ltd's Products are not authorized for use as cri- tical
components in life support devices or systems without the expressed written approval of Reasunos
Semiconductor Technology Co.Ltd.
As used herein:
1. Life support devices or systems are devices or systems which: a.are intended for surgical implant into
the human body, b.support or sustain life,
c.whose failuer to when properly used in accordance with instructions for used provided in the laeling,can
be reasonably expected to result in significant injury to the user.
2.A critical component is any component of a life support device or system whose failure to system
whose failure to perform can be reasonably expected to cause the failure of the life support device or
system,or to affect its safety or effectiveness.
www.reasunos.com
9 /9
Copyright Reasunos
很抱歉,暂时无法提供与“RS60N50D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63700
- 10+0.58800
- 30+0.57820
- 100+0.54880
- 国内价格
- 5+1.10322
- 50+0.88096
- 150+0.78570
- 500+0.66680
