Interface RF Connector with Switch, built-in interlock, DC to 3GHz
MS-151NB Series
■Overview
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Designed for end user applications requiring redirection of transmission from internal built-in
antenna to the external antenna. Small size,
lightweight and high reliability makes it ideal for
use in 2.4 GHz band wireless LAN applications.
Plug can be rotated after full insertion.
■Features
1. Confirmation of complete connection
Built-in interlock feature confirms fully mated
condition with a "click" sensation.
2. Non-directional connection
The connector can be mated in any position on a
360° axis and can rotate within the same when in
use, allowing routing of the connected cable in
any direction.
●Receptacle
3. High durability
Guaranteed 5000 insertion/removal cycles.
4. Space-saving
The external dimensions of the board-mounted
receptacle (5.0 mm high, 6.5 mm wide, 7.0 mm
deep) makes it ideal for use in small devices.
5. Board placement with automatic equipment
Packaged on tape-and-reel. Also available with a
vacuum pick-up cap over each switch.
MS-151NB
6. RoHS compliant
All components and materials comply with the
requirements of the EU Directive 2002/95/EC.
●Plug
■Applications
GPS terminals, wireless LAN modules, notebook
computers, PDA, and other high frequency
equipment.
MS-151-C(LP)
●SMA Conversion Adapter
For Receptacle: MS-151NB
MS151P-HRMJ
For Plug: MS-151-C(LP)
MS151J-HRMJ
125
MS-151NB Series●Interface RF Connector with Switch, built-in interlock, DC to 3GHz
■Product Specifications
Frequency range
DC to 3GHz
Operating temperature range
–40ç to +85ç
Power rating
4W
N.C
V.S.W.R.
N.O
to 1 GHz
1.2dBmax.
1 GHz to 2 GHz
1.4dBmax.
1 DC
1.7dBmax.
2 GHz to 3 GHz
to 1 GHz
0.2dB
max.
0.3dB
max.
1 GHz to 2 GHz
0.4dB
max.
0.5dB
max.
2 GHz to 3 GHz
0.6dB
max.
1.0dB
max.
1 DC
Insertion loss
to 1 GHz
20dB
min.
1 GHz to 2 GHz
18dB
min.
2 GHz to 3 GHz
12dB
min.
1 DC
Isolation loss
Item
Specification
Conditions
1. Contact resistance 50 m ohms max.
2. Insulation resistance 1000 M ohms min.
3. Withstanding voltage No flashover or insulation breakdown
4. Vibration
No electrical discontinuity of 10 μs or more
5. Shock
6. Temperature cycle
7. Humidity
7. (Steady state)
Contact resistance: 100 m ohms max.
Insulation resistance: 10 M ohms min.
100 mA
100 V DC
100 V AC / 1 minute
Frequency: 10 to 500 Hz, single amplitude of 0.75 mm, acceleration
of 98 m/s2 for 2 hours in each of the 3 directions
Acceleration of 490 m/s 2 , 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis
Temperature: -55ç / +15ç to +35ç / +85ç / +15ç to +35ç
Time: 30 / 5 max. / 30 / 5 max.(Minutes)
100 cycles
96 hours at temperature of 40ç and humidity of 90%
No corrosions
Insertion force: 1~10N
9. Insertion/Withdrawal forces
Withdrawal force: 3~15N
10. Durability
10. (insertion/ withdrawal)
8. Salt spray
5% salt water solution, 48 hours (at 35ç)
With corresponding connector
5000 cycles
■Materials
Receptacle MS-151NB
Part
Material
Finish
Insulator
Lock mating section
Outer conductor shell
Contact A
Contact C
Polyamide (UL94V0)
Stainless steel
Phosphor bronze
Phosphor bronze
Beryllium copper
--------------Nickel plating (Termination area: Gold-lead plated)
Gold plating
Gold plating
Plug MS-151-C(LP)
Part
Cover A
Cover B
Ring
Inner contact
Insulator
Ferrule
Crimp metal fitting
Bushing
126
Material
PC
PC
Stainless steel
Phosphor bronze
Phosphor bronze
Polyamide (UL 94-HB)
Stainless steel
Brass
Polyester
Finish
Nickel plating
Nickel plating
Gold plating
Nickel plating
BTypical data
●NORMALLY CLOSED(N.C) ~ (Not mated with the plug)
: V.S.W.R. SPEC
: INSERTION LOSS SPEC
: ISOLATION SPEC
0.2
INSERTION LOSS
0.4
1.7
0.6
1.6
0.8
1.5
1.0
1.4
V.S.W.R.
INSERTION LOSS [dB]
V.S.W.R.
1.2
1.1
1.0
DC
1.0
2.0
3.0 [GHz]
●OPEN(N.O) ~ (Mated with the plug)
INSERTION LOSS
0.2
0.4
1.7
0.6
1.6
0.8
1.5
1.0
1.4
V.S.W.R.
INSERTION LOSS [dB]
[dB]
ISOLATION [dB]
[dB]
1.3
V.S.W.R.
10
1.2
ISOLATION
30
1.0
40
DC
1.0
2.0
3.0 [GHz]
127
■Receptacle
3.6
G
7
2-1
5
2-0.65 (2.5)
6.5
C
2-0.25
2-0.3
1.8
B
2-0.3
A
MS−151
G
1.2
2-φ0.9
2
5.2
2-0.8
3-□0.5
0.5
3
Part Number
2.5
HRS No.
Packaging
MS-151NB
358-0215-9-01
1,000 pieces per reel
MS-151NB(01)
358-0215-9-01
100 pieces
BCircuit diagram
Not mated with the plug(N.C)
G
Mated with the plug(N.O)
G
A
G
C
G
G
B
G
A
B
G
Plug
C
G
MS-151NB
BPCB mounting pattern
2-Ø
2.5
1.2
(Th
rou
3
gh
2
ole
1.65
2.3
0.6
1.35
nd)
0.2
1.3
3.2
4.3
2-0.6
2-0.55
2-Ø1
128
3.6
5.2
1.8
(La
2
2-Ø
1.1
7.1
4.9
Connector front edge
No conductive traces
RoHS
YES
BPackaging Specifications
Embossed tape reel packaging (1,000 pieces/reel)
4
2
Ø1
.5
1.75
12
Ø1
16
16.4
1
Ø380
Ø80
MS-151
MS-151
7.5
3
Unreeling direction
Ø2
22.4 max.
7
Unreeling direction
BRecommended Temperature Profile
Using Lead-free solder paste
Peak Temperature 260ç max.
5sec. max.
Temperature(ç)
260
220
200
180
Maximum temperature
: 260ç
Peak temperature
: 240ç to 255ç
Peak temperature duration
: 5 sec. Max.
200ç min.
: 50 to 80 sec.
150ç to 160ç
: 60 to 120sec.
100
60 to 120sec.
50 to 80sec.
129
■Plug
(5.5)
(12.5)
(8)
(24.1)
(Ø4.15)
Part Number
HRS No.
Packaging
Applicable cable
RoHS
MS-151-C(LP)
358-0160-9
1
1.5DS-QEHV(TA)
YES
Termination fixture: MS-151/CF-MD, MS-151/SO-MD, MS-151/BE-MP and MS-151/CK-MP
Please contact your Hirose Electric representative for information.
■SMA Conversion adaptors
●For Receptacle: MS-151NB
φ7.3
φ4.15
1/4-36UNS-2A
6
6.3
(6.29)
5.5
17.79
Part Number
HRS No.
Packaging
RoHS
MS151P-HRMJ
355-0089-7
1
YES
●For Plug: MS-151-C(LP)
φ7.3
φ2.9
1/4-36UNS-2A
6
6.3
(6.29)
3.5
15.79
130
Part Number
HRS No.
Packaging
RoHS
MS151J-HRMJ
355-0088-4
1
YES
很抱歉,暂时无法提供与“MS-151NB”相匹配的价格&库存,您可以联系我们找货
