LP150 series
Low profile trackball
Distinctive features and specifications
1.5” ball diameter
Panel mount design
Available in black or backlit illumination
Several protocol options
Additional button strips available
Environmental Protection Classification
(IP Rating): contact factory
CONFIGURATION OPTIONS
MECHANICAL
• LED backlighting: Red, Blue, Green or
Clear through a translucent Thermostat
resin ball
• Additional pushbutton switch: Two, three or
four* buttons (* USB only) – see Button Strips
• Connector cables
• Conformally coated PCB
Ball Diameter:
1.50" (38.10mm)
Ball Rotation: Continuous in all directions
Tracking Force: 10g (0.35oz)
Weight: 118.5.5g (4.18oz)
Life Cycle (ball rotations): 5 million
Operating Temperature: -40ºC to +85ºC (-40ºF to +185ºF)
PROTOCOL OPTIONS AND ELECTRICAL SPECIFICATIONS
• USB:
MOUNTING OPTIONS
Input: 4.00V – 5.25V @ 25mA max
(+30mA for backlit illumination option)
Output: USB 1.1
• 180º horizontal to 90º vertical – please
specify when ordering.
• PS/2 (2/3BTN PS/2): Input: 5.00V @ 25mA max
Output: CMOS/TTL
• Microsoft Serial*:Input:DTR/RTS @ 14 mA max
Output: RS-232, Serial
• Quadrature: Input: 5.00V @ 30mA max
Output: Quadrature Waveforms
• Sun Workstation:
(Mouse Systems Serial)
Output: CMOS/TTL
NOTE: * = Microsoft Serial Interface requires a 5V supply for the
LED backlighting option.
All values are nominal.
LP
SERIES
PROTOCOL FORMAT
MODEL
150 1.50” Diameter
(38.1mm)
1
3
5
6
7
MOUNTING
POSITION
Microsoft (2 btn Serial)
PS/2 (2/3 btn)
F - Level to 45º
Quadrature
N - Level to 90º
SUN Workstations
X - N/A
USB
RESOLUTION
10 - 120 resolution
20 - 240 resolution
30 - 480 resolution
POWER
REQUIREMENT
V00 5V Regulated
R00 RS-232*
(DTR & RTS)
*Microsoft Protocol only
Note: The company reserves the right to change specifications without notice.
APEM
www.apem.com
ILLUMINATION
R
B
G
C
Red
Blue
Green
Clear
Black*
*Non-illuminated
LP150 series
MOUNTING CUTOUT DIMENSIONS
88.90
(3.50)
61.98
(2.44)
26.67
(1.05)
- Without rubber
gasket
- With rubber
gasket
Mounting Hardware:
– Two #4-40x7/8
Phl Flat Screws
– Two Self Clinching
Standoffs
26.67
(1.05)
61.98
(2.44)
26.67
(1.05)
43.69
(1.72)
45.47
(1.79)
53.34
(2.10)
29.21
(1.15)
73.15
(2.88)
Ø4.57
(0.18)
26.67
(1.05)
Ø4.57
(0.18)
43.69
(1.72)
X4
36.32
(1.43)
32.00
(1.26)
Ø38.10
(1.50)
43.69
(1.72)
61.98
(2.44)
43.69
(1.72)
36.32
(1.43)
32.00
(1.26)
29.21
(1.15)
1.27
(0.05)
26.92
(1.06) 24.13
(0.95)
53.34
(2.10)
38.10
(1.50)
2.54
(0.10)
88.90
(3.50)
BUTTON STRIP FEATURES
• Two, three, or four* (*USB only) buttons
• Tactile feedback
• Normally open momentary contact switch
• 5 million lifecycles rating at 500mA at 12VDC
• Black or gray button caps
• Choice of convex or concave design
37.08
(1.46)
20.32
(0.80)
#4-40 Screw, Nut
& Washer (2 Places)
7.62
(0.30)
15.24
(0.60)
13.97
(0.55)
15.24
(0.60)
16.76
(0.66)
50.80
(2.00)
61.21
(2.41)
Panel
8.38
(0.33)
64.77
(2.55)
73.66
(2.90)
Panel
Ø13.97
(0.55)
16.00
(0.63)
White
Grey
Green (Common)
#4-40 Screw, Nut
& Washer (2 Places)
18.54
(0.73)
H
For Convex Buttons
H = 20.32/(0.80)
For Concave Buttons
H = 19.30/(0.76)
White
Grey
Black
Green (Common)
NOTE: All dimensions are in mm/(inch).
LP150_JOYST1412R1US
www.apem.com
APEM
很抱歉,暂时无法提供与“LP1505F20V00”相匹配的价格&库存,您可以联系我们找货
