PK3021LI
PK3021LI
    TRIPPLITE
    KIT LIGHT, MOUSE, AND USB HUB
PK3021LI 数据手册
Notebook Peripheral Kit (Light, Mouse and Hub) Notebook/Laptop Computer Peripheral Devices Highlights ● USB LED light plugs into any USB port for easy operation and features an adjustable arm lets you point light right where it's needed ● Mini optical USB mouse with 27" retractable cord works on virtually any surface and includes a quiet scrolling wheel; 480 dpi resolution and 450 mm/s tracking speed ● USB 2.0 4-port mini-hub allows you to connect up to four USB peripherals to your notebook and supports high-speed data transfer rates ● Compact, zippered case protects contents and provides easy portability MODEL NUMBER: PK3021LI System Requirements ● Light: USB port ● Mouse: Windows 98SE/ME/2000/XP/NT and USB port ● Hub: Windows 98SE/ME/2000/XP or Mac OS X or higher and USB port Description This case contains everything you need to work in the low light situations such as on an airplane: a light, hub and mouse specifically designed for notebook computers. Features ● Contains everything you need to work in the low light situations such as on an airplane: a light, hub and mouse specifically designed for notebook computers Specifications OVERVIEW UPC Code 037332127082 Accessory Type Peripheral Kit PRODUCT OVERVIEW Product Overview Notebook Peripheral Kit (Light, Mouse, Hub) PHYSICAL Color Black; Silver Shipping Dimensions (hwd / cm) 31.75 x 16.51 x 5.08 Shipping Dimensions (hwd / in.) 12.50 x 6.50 x 2.00 Shipping Weight (kg) 0.42 Shipping Weight (lbs.) 0.92 1/2 Unit Dimensions (hwd / in.) 1.6 x 6.9 x 6.7 Unit Dimensions (hwd / cm) 4.06 x 17.53 x 17.02 Unit Weight (lbs.) 0.51 Unit Weight (kg) 0.23 CONNECTIONS Number of Ports 4 FEATURES & SPECIFICATIONS Mouse Tracking Speed (mm/s) 450 Resolution Mouse: 480 dpi USB 1.1 Compatible Yes USB 2.0 Compatible Yes USB Powered Yes WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
PK3021LI 价格&库存
很抱歉,暂时无法提供与“PK3021LI”相匹配的价格&库存,您可以联系我们找货
