UTL0103G1S
UTL0103G1S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HSG RCPT 4POS WALL MNT SKT
UTL0103G1S 数据手册
UTL series The reliable connector to power up your device The UTL series is a sealed plastic connector range able to carry up to 16A 277V. Key shape coupling with latching retention system Designed to be overmoulded UV resistant. F1 material + IP68 Fire & smoke: UL 94 5VA Compliant with luminaires standard UL 1598, IEC 60598 No waste of time trying to find how to mate it Secure against unwanted tampering. Suitable for outdoor use Can be used in public environment Easy qualification of your system by regulation autorities UTL series The philosophy of the UTL series is built around three key elements: Dynamic IP68/69K UV Resistant UTL series is rated at IP68/69K… even in dynamic conditions. This means that it remain sealed even when used continuously underwater or cleaned using a high pressure hose and cable is moving. In most applications, our connectors are exposed to extreme climatic conditions; it was therefore key for us to select the materials best able to cope with the targeted environment. If this same level of performance is required even when connectors then we have special sealed contacts. This unique fetaure helps you to product your electronics from ingress of water. This is particulary insteresting when using with NEMA enclosure or outdoor luminaires. In most applications, our connectors are exposed to extreme climatic conditions; it was therefore key for us to select the materials best able to cope with the targeted environment. The UTL series uses an outdoor rated material. Underwriters Laboratories classifies it "F1". 2 UL/IEC Compliant The outmost priority for any electrical installation is to protect personnel from any shock hazard. In North America, Underwriters Laboratories insisted that connector manufacturers, depending of the application, respect their standards. The UTL series had thus been qualified, certified by this organisation and compliant with the UL 1598. In Europe and in Asia, IEC standards are better known and trusted by end users. Like its American equivalent, the IEC refers to safety rules. The UTL series was obviously designed to respect these rules and especially the IEC 60598. UTL series Technical features Mechanical • Durability: 1000 cycles (with stamped & formed contacts & S18 plating) • Vibration resistance: Sinusoidal vibrations per IEC 60512-4 from 10 to 2000 Hz • Body connector + Backshell: Thermoplastic • Insert: Thermoplastic • Nut: Metal Electrical • Working voltage: 277VAC per UL 1977 277/480VAC per UL 1977 • Rated current: 16A • Connector for breaking circuit Environmental • Operating temperature: from -40°C to +105°C • Flammability rating: UL 94 5VA • Salt spray: ≥1000 hours • UV resistant: F1material per the UL 746C • Sealing: - IP68/69K - IP6X mated & unmated - IPX8: mated (10m. underwater during 1 week) - IPX8: unmated with sealed contact (1m. underwater during 1 week) Cable assembly Souriau provides connectors in various applications for more than 90 years in the most extreme environment. Being conscious about the difficulty to find a quick and a reliable harness manufacturer, we decided years ago to start in house cable assembly production. It allows customers to reduce the number of suppliers, and to take advantage of the "best in class" quality of the Souriau group. Overmoulding is a process that further enhances the sealing properties of the UTL range, especially over many years of use. Overmoulding provides the opportunity to change the cable exit from straight through 90 degrees and avoid any stress on the cable terminated to the connector. Also, as the wires are encapsulated inside the moulding, a barrier is created which prevents from any liquid from entering the equipment through the connector if the cable jacket is breached. O ring PVC or PUR overmolding Compound 3 UTL series Layout OR OR WITH Specifications Contact type Crimp contacts supply separately Part number Connector type Male insert Female insert Plug UTL6103G1P UTL6103G1S Square flange receptacle UTL0103G1P UTL0103G1S Jam nut receptacle UTL7103G1P UTL7103G1S Inline receptacle UTL1103G1P UTL1103G1S Sealed unmated: see page ? Electrical characteristics UTL 103G1 derating curves Current (A) 30 28 25 Test conditions UL: 16A 277V UL94 5VA 23 20 18 15 Contact used: 13 Machined contacts 10 Wires used: 8 1.31mm² IEC: 16A 250V 4kV 4 for Classe II equipment 5 3 0 0 20 40 60 80 100 120 Ambient Operating Temperature (°C) 4 Current use Limited use Not recommended use UTL series 3 + ground 16A/277V Dimensions per UL 1977 Square flange receptacle - UTL0 12 33.5 28.6 30 Ø18 19.9 Mating face Wiring face Receptacle - UTL7 14 30 22.2 28.6 28.6 20 Mating face Wiring face Plug - UTL6 15.1 Wiring face 23.2 Ø20 23.2 11.3 Ø15.5 26.1 15.1 Wiring face Panel thickness Panel cut out Square flange receptacle - UTL0 Jam nut receptacle - UTL7 16.45 21.8 Ø3.2 Front mounting Ø18.3 17.2 6 max 26.7 Note: all dimensions are in mm 5 Contacts # 16 Tooling Part number Handle Tool kit Part number Part number Shandles Toolkit Standard contacts Wire size Type AWG Machined 30-28 Machined 26-24 Stamped & Formed 26-24 Machined 22-20 Stamped & Formed 22-20 Machined 20-16 Stamped & Formed 18-16 Stamped & Formed 18-16 Machined 16-14 Machined 16-14 Stamped & Formed 14 Part numbers mm² 0.050.08 0.13-0.2 Male Female RM28M1K RC28M1K RM24M9K RC24M9K SM24M1S18(A)(1) SC24M1S18(A)(1) SM24ML1S18(A)(2) SC24ML1S18(A)(2) RM20M13K RC20M13K 0.320.52 RM20M12K RC20M12K SM20M1S18(A)(1) SC20M1S18(A)(1) 0.35-0.5 SM20ML1S18(A)(2) SC20ML1S18(A)(2) 0.52-1.5 RM16M23K RC16M23K SM16M1S18(A)(1) SC16M1S18(A)(1) 0.8-1.5 SM16ML1S18(A)(2) SC16ML1S18(A)(2) SM16M11S18(A)(1) SC16M11S18(A)(1) 0.8-1.5 SM16ML11S18(A)(2) SC16ML11(A)(2) 1.5-2.5 RM14M50K RC14M50K 1.5-2.5 RM14M30K RC14M30K SM14M1S18(A)(1) SC14M1S18(A)(1) 2.0-2.5 SM14ML1S18(A)(2) SC14ML1S18(A)(2) 0.130.25 Sealed contacts Wire size Type Part numbers AWG mm² Male Female Machined 18-16 0.8-1.5 Machined 16-14 1.5-2.5 RM16M25K RM14M25K RC16M25K RC14M25K (A): Plating available (S31, S18) Do not mix tin plating & gold plating Contacts (1): Contact reeled (2): Loose contact Available platings (contact supply separately) K S31 S18 Min 0.4μ gold over 2μ Ni Active part: Gold flash over Ni Crimp area: Nickel Active part: 0.75μ gold min over 2μ Ni Crimp area: 1.3µ tin over Ni / Other: Nickel Contact size RM/RC 28M1K(1) S16RCM20 RM/RC 24M9K S16RCM20 (1) RM/RC 20M13K(1) S16RCM20 RM/RC 20M12K (1) S16RCM20 RM/RC 16M23K (1) RM/RC 14M50K(1) RM/RC 14M30K(1) Accessories S16RCM16 Standard contacts #16 Ø 1.6mm S16SCM20 SM/SC 20ML1S18 S16SCM20 SM/SC 16ML1S18(1) S16SCML1 SM/SC 14ML1S18 S16SCML1 SM/SC 16ML11S18(1) S16SCML11 RM/RC 14M30K (1) UTL10DCG (1): example of plating For further information, click here www.souriau-industrial.com Or contact us click here contactindustry@souriau.com 6 S16RCM14 (1) RM/RC 16M23K(1) Part number S16RCM1450 SM/SC 24ML1S18(1) (1) Dustcap Part number of head Standard contacts #16 Ø 1.6mm S16RCM16 S16RCM14 INDUTL01US © Copyright SOURIAU 2011 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. UTL series
UTL0103G1S 价格&库存
很抱歉,暂时无法提供与“UTL0103G1S”相匹配的价格&库存,您可以联系我们找货
