A
B
C
D
E
F
G
H
MASS
MATERIALS
SHELL
O'RING
BACKSHELL BODY
CABLE GLAND
8
MATING FACE
WIRING FACE
30 0,5
7
RECEPTACLE SHELL
CABLE GLAND
BACKSHELL BODY
SEALING IN UNMATED CONDITIONS
OPEN FACE SEALING
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
20 0,3
5%
38 g
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC60529
IEC61984
UL94
UL746C
8
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
IP67 WITH R*M25* CONTACTS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
IEC60529
UL1977
NOMINAL CURRENT
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
CONNECTOR BREAKING CAPACITY
UL1977
IEC61984
277V 13A WITH AWG14/16 WIRES
250VAC 13A 4KV 4
6
CAPACITY C
ELECTRICAL
TOUCH PROOF
NOMINAL CURRENT
7
IP2X
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
6
ROHS COMPLIANT
30,6
ECHELLE 2/1
BLACK POLYAMID
NBR
BLACK POLYAMID
BLACK POLYAMID + NBR
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
62,2 FOR INFORMATION
28,8 0,5
A.5; Validé
NOTES
5
1. COUNTERPART REFERENCE UTL PLUG
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING:PHASE CONTACTS ARE FEMALE VERSION AND GROUND CONTACT IS MALE VERSION
6. UNIT IN MM
7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm
8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY
9. CAPACITY C : Ø6.5 / Ø12
5
4
4
VIEW IN MOUNTED AND
MATED CONDITIONS
BACKSHELL ONLY
UTL10JCP1 (*)
BASKHELL WITH CABLE GLAND
UTL10JC (*)
102,5 FOR INFORMATION
3
3
O'RING
UTL10SEAL (*)
CountryJurisdiction
& Control List
FR
NOT LISTED
THREADED PLUG
UTL1103G1P (*)
P/N :
2
A
12/02/18
ISS
WRENCH SIZE 24
DATE
Designed by:
WRENCH SIZE 25
TITLE
WRENCH SIZE 25
Scale
1/1
UTL1JC103G1S
Creation
Latest modification - by:
R.M.
Date:
12/02/18
1
H
G
F
E
D
C
FORMAT
A2
2
FREE HANGING WITH THREADED BACKSHELL SIZE 10
UTL CONNECTOR
General linear
Tolerances:
WWW.SOURIAU.COM
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
CUSTOMER DRAWING
MOD N $
SOURIAU DRG N°
UTL1-0102A-C
B
NPRDS / PROJECT
BE170912A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL1JC103G1S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+76.892061+9.33433
