A
B
C
D
E
F
G
H
MATERIALS
SHELL
O'RING
BACKSHELL BODY
CABLE GLAND
8
7
SEALING IN UNMATED CONDITIONS
OPEN FACE SEALING
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
MATING FACE
WIRING FACE
30 0,5
RECEPTACLE SHELL
62,2 FOR INFORMATION
BACKSHELL BODY
20 0,3
CABLE GLAND
5%
35 g
BLACK POLYAMID
NBR
BLACK POLYAMID
BLACK POLYAMID + NBR
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC60529
IEC61984
UL94
UL746C
8
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
IP67 WITH R*M25* CONTACTS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
ELECTRICAL
TOUCH PROOF
NOMINAL CURRENT
IEC60529
UL1977
NOMINAL CURRENT
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
CONNECTOR BREAKING CAPACITY
UL1977
IEC61984
277V 13A WITH AWG14/16 WIRES
250VAC 13A 4KV 4
CAPACITY C
6
28,8 0,5
A.5; Validé
MASS
NOTES
7
IP2X
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
6
ROHS COMPLIANT
1. COUNTERPART REFERENCE UTL PLUG
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING:PHASE CONTACTS ARE MALE VERSION AND GROUND CONTACT IS FEMALE VERSION
6. UNIT IN MM
7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm
8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY
9. CAPACITY C : Ø6.5 / Ø12
30,6
ECHELLE 2/1
5
4
VIEW IN MOUNTED AND
MATED CONDITIONS
4
BACKSHELL ONLY
UTL10JCP1 (*)
BASKHELL WITH CABLE GLAND
UTL10JC (*)
102,5 FOR INFORMATION
5
O'RING
UTL10SEAL (*)
WRENCH SIZE 25
3
THREADED PLUG
UTL1103G1P (*)
3
CountryJurisdiction
& Control List
FR
NOT LISTED
WRENCH SIZE 25
WRENCH SIZE 24
P/N :
2
A
12/02/18
ISS
DATE
Designed by:
TITLE
Scale
1/1
UTL1JC103G1P
Creation
Latest modification - by:
R.M.
Date:
12/02/18
1
H
G
F
E
D
C
FORMAT
A2
2
FREE HANGING WITH THREADED BACKSHELL SIZE 10
UTL CONNECTOR
General linear
Tolerances:
WWW.SOURIAU.COM
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
CUSTOMER DRAWING
MOD N $
SOURIAU DRG N°
UTL1-0101A-C
B
NPRDS / PROJECT
BE170912A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL1JC103G1P”相匹配的价格&库存,您可以联系我们找货
