A
B
C
D
E
F
G
H
MASS
MATERIALS
SHELL
O'RING
BACKSHELL BODY
CABLE GLAND
MATING SEAL
LOCKING LATCH
8
7
MATING FACE
WIRING FACE
26,75 0,5
PLUG
SHELL
LOCKING
LATCH
71,7 FOR INFORMATION
SEALING IN UNMATED CONDITIONS
OPEN FACE SEALING
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
16,1 0,3
CABLE GLAND
BACKSHELL BODY
6
CAPACITY C
5%
36 g
BLACK POLYAMID
NBR
BLACK POLYAMID
BLACK POLYAMID + NBR
SILICON
STAINLESS STEEL
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
23,25 0,3
A.5;
; Validé
NOTES
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC60529
IEC61984
8
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
IP67 WITH R*M25* CONTACTS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
UL94
UL746C
7
ELECTRICAL
TOUCH PROOF
NOMINAL CURRENT
IEC60529
UL1977
NOMINAL CURRENT
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
CONNECTOR BREAKING CAPACITY
UL1977
IEC61984
277V 13A WITH AWG14/16 WIRES
250VAC 13A 4KV 4
IP2X
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
6
ROHS COMPLIANT
1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING:PHASE CONTACTS ARE MALE VERSION AND GROUND CONTACT IS FEMALE VERSION
6. UNIT IN MM
7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm
8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY
9. CAPACITY C : Ø6.5 / Ø12
ECHELLE 2/1
5
5
4
4
VIEW IN MOUNTED AND
MATED CONDITIONS
BACKSHELL ONLY
UTL10JCP1 (*)
BASKHELL WITH CABLE GLAND
UTL10JC (*)
102,5 FOR INFORMATION
O'RING
UTL10SEAL (*)
WRENCH SIZE 25
3
THREADED PLUG
UTL6TH103G1P (*)
3
WRENCH SIZE 25
CountryJurisdiction
& Control List
FR
NOT LISTED
WRENCH SIZE 24
P/N : UTL6JC103G1S
2
A
12/02/18
ISS
DATE
Designed by:
TITLE
Scale
3/1
Creation
Latest modification - by:
R.M.
Date:
12/02/18
1
H
G
F
E
D
C
FORMAT
A2
2
PLUG WITH THREADED BACKSHELL SIZE 10
UTL CONNECTOR
General linear
Tolerances:
WWW.SOURIAU.COM
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
CUSTOMER DRAWING
MOD N $
SOURIAU DRG N°
UTL1-0099A-C
B
NPRDS / PROJECT
BE170912A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL6JC103G1P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+209.398601+25.37792
- 10+181.4840410+21.99484
- 25+160.1252325+19.40627
- 50+143.2755050+17.36418
