A
HR
B
DESCRIPTION OF REVISIONS
BY
CHKD
DATE
COUNT
BY
CHKD
DATE
DIS-H-000128
DIS-H-002465
CONTACT No.2
I~
DR
+I
c--J
1.5 ±0.3
CODE No.
CL543-2017-3-21
CL543-2018-6-21
CL543-2019-9-21
CL543-2020-8-21
CL543-2021-0-21
CL543-2022-3-21
CL543-2023-6-21
CL543-2024-9-21
CL543-2025-1-21
CL543-2026-4-21
CL543-2027-7-21
CL543-2028-0-21
CL543-2029-2-21
CL543-2030-1-21
CL543-2031-4-21
+I
AW
c--J
IN
G
CONTACT No.1
1.5±0.3
8 ±0.5
c
+I
en
FO
NUMBER OF
CONTACT
PART No.
DF11Z- 4DP-2V
DF11Z- 6DP-2V
DF11Z- 8DP-2V
DF11Z-10DP-2V
DF11Z-12DP-2V
DF11Z-14DP-2V
DF11Z-16DP-2V
DF11Z-18DP-2V
DF11Z-20DP-2V
DF11Z-22DP-2V
DF11Z-24DP-2V
DF11Z-26DP-2V
DF11Z-28DP-2V
DF11Z-30DP-2V
DF11Z-32DP-2V
21
21
21
21
21
21
21
21
21
21
21
21
21
21
21
A
2
4
6
8
10
12
14
16
18
24
26
28
30
4
6
8
10
12
14
16
18
24
26
28
30
32
B
c
8.5
10.5
12.5
14.5
16.5
18.5
20.5
22.5
24.5
26.5
28.5
30.5
32.5
34.5
36.5
4
6
8
10
12
14
16
18
24
26
28
30
32
D
8.7
10.7
12.7
14.7
16.7
18.7
20.7
22.7
24.7
26.7
28.7
30.7
32.7
34.7
36.7
B
RECOMMENDED PATTERN(2:1)
A±0.1
c
-0 0
31'1"
·I •o
1?y;lW 0 ·1
I
A problem has occurred in the display of PDF. Please...... download the latest data on the Hirose
Connectors web
site.
J
~I)
+I
c--J
r--
D
P=2±0.05
R
I
I.
E
c--J
+I
2
BRASS
1
POLYAMIDE
NO.
I
J
-0
+I
-0
c±0.1
+l
c--J
D±0.1
2±0.1
D
2 ±0.1
RE
NC
SURFACE: TIN PLATED 1JL mmin
UNDER PLATING:NICKEL PLATED 0.5JL mmin
UL94V-O,NATURAL(BEIGE)
FINISH, REMARKS
MATERIAL
F
SCALE
-E3-
5
1
UNITS
mm
4
5
5
4
3
POLYESTER
BRASS
MATERIAL
DESIGNED
CHECKED
FINISH, REMARKS
E
APPROVED
F.Matsuki
I.Denpouya T.Miyazaki T.Miyazaki
'05.01.18
'05.01.18
DRAWING NO.
PART NO.
'05.01.20
RELEASED
'05.01.20
DF11Z-*DP-2V(21)
EDC3-306017-02
IRS
E
CLEAR(COVER TAPE)
CLEAR(EMBOSSED CARRIER TAPE)
TIN PLATED 1~ m min
[DJ
NO.
DRAWN
TO
3
+I
c--J
NOTESO> IF THERE IS PATTERN ON~ PART, THERE IS A POSSIBILITY
THAT IT WILL MAKE CONTACT WITH THE LEADS.
2 :LEAD CO-PLANARITY INCLUDE REINFORCED METAL FITTINGS
SHALL BE 0. 1mm MAX.
en
2
1
RE
FE
~I
C±0.3
+I
.l n u_
I
+I
+0.05
-0.15
1.1 ±0.1
I~
I
c--J
¢1
c--J
CODE NO. (OLD)
8
7
6
1
3
A±0.3
en
DRAWING FOR REFERENCE: This is subject to change without notice
08/11/2012
5
COUNT
S
CAV No.
4
3
2
F
CODE NO.
CL543-
HIROSE ELECTRIC CO., LTD
6
7
8
A
2
HR
I
1
1
c
I
I
08/11/2012
---+--.:......: --I
I
Ill
I I
DR
7.8 ±0 .3
2 ±0.1
5±0.3
16 ±0.1
+I
r--
I
IN
G
I'll
I I
I, I
I
ttt----:
I
II I
rK
AW
I
Ill
DATE
CHKD
9.4 ±0.3
1
I I
BY
K-K
r--
LIJ
L
11~11
1
7
6
B
5
MC10:1)
L-L
S
L _j I, I
4
3
I
I
1
+I
FO
CODE No.
PART No.
CL543-2017-3-21 DF11Z- 4DP-2V
CL543-2018-6-21 DF11Z- 6DP-2V
CL543-2019-9-21 DF11Z- 8DP-2V
CL543-2020-8-21 DF11Z-10DP-2V
CL543-2021-0-21 DF11Z-12DP-2V
CL543-2022-3-21 DF11Z-14DP-2V
CL543-2023-6-21 DF11Z-16DP-2V
CL543-2024-9-21 DF11Z-18DP-2V
CL543-2025-1-21 DF11Z-20DP-2V
CL543-2026-4-21 DF11Z-22DP-2V
CL543-2027-7-21 DF11Z-24DP-2V
CL543-2028-0-21 DF11Z-26DP-2V
CL543-2029-2-21 DF11Z-28DP-2V
CL543-2030-1-21 DF11Z-30DP-2V
CL543-2031-4-21 DF11Z-32DP-2V
NUMBEROF
CONTACT
E
4
6
8
10
12
14
16
18
24
26
28
30
32
24.0
24.0
24. 0
32.0
32.0
44.0
44. 0
44.0
44.0
44.0
56.0
56.0
56.0
56.0
56.0
21
21
21
21
21
21
21
21
21
21
21
21
21
21
21
F
G
H
28.4
28.4
40.4
40 .4
40.4
40.4
40.4
52.4
52.4
52.4
52.4
52.4
11.5
11.5
11. 5
14.2
14.2
20.2
20. 2
20.2
20.2
20.2
26.2
26.2
26.2
26.2
26.2
J
24.4 PS
24.4 A-PET
24. 4 PS
32.4 PS
32.4 PS
44.4 PS
44. 4 A-PET
44.4 A-PET
44.4 PS
44.4 PS
56.4 PS
56.4 A-PET
56.4 A-PET
56.4 PS
56.4 PS
c
+I
+I
LL..
..,_,
NOTES 3 1 REEL:500 CONNECTORS.
THE BIGINNING
OF THE
REEL, 15 COMPONENTS
I
I I occurred
I
A problem
has
in the display of PDF. Please download the latest data 4onAT the
Hirose
Connectors
web SHALL
site.
· BE EMPTY.
II' I
I
I
I
II
I
AT THE END OF THE REEL, 10 COMPONENTS SHALL BE EMPTY.
l
I
[]>WHEN THE TAPE WIDTH IS 32, 44 AND 56mm, SPROCKET HOLES
SHALL BE SET ON BOTH SIDES OF REEL AS SHOWN ON THIS
D
DRAWING.
L_Lf__l__j
~THE MATERIAL OF THE EMBOSSED CARRIER TAPE REFERS TO
THE TABLE.
[[>DETAIL OF PART No. LABEL IS WRITTEN IN JAPANESE.
f---H--I-$--$--1$t--$---$--$-$-$- : -$-~8 THE REEL IS POLYETHYLENE PACKAGED WITH AN DRY AGENT
INSIDE FOR MOISTURE-PROOF PACKAGING.
[]>M
i-K
~9 FOR THE STORAGE OF 168 HOURS OR MORE AFTER OPENING THE
PACKAGE, KEEP THE PRODUCTS UNDER MOISTURE PROOF
STYLE AND DIMENSION OF REEL
DIRECTION
OF
UNREELING
2±0.5
CONDITIONS.
SUPPLIER
~10 EXCEPT ON THE MATING SURFACE, COMPONENT INFLATION DOES
E PART No.
QUANTITY
NOT AFFECT THE PRODUCTS PERFORMANCE.
LABEL
PART No.
u
.- 1 - - CODE No .
--DATE OF MANUFACTURED
= - r---=
-e.
CODE NO. (OLD)
DESIGNED
CHECKED
APPROVED
RELEASED
DRAWN
111
--~,iii
R
rf-
RE
FE
L_.J
RE
NC
I
c==>
I
f-
TO
j::~.F.JB
BEI=8
F
*P37\~:fii
w
*P37\~
F3
B
CL543-****-*-21
DF11Z-*DP-2V(21)
500 KO
l::: D iz ~ ~ 'f% J:'C :fHt
jH+6) MAX
~s~~L~E~~~
3
4
'05.01.18
'05.01.18
PART NO.
DRAWING NO.
'05.01.20
CODE NO.
CL543-
6
7
D
E
'05.01.20
DF11Z-*DP-2V(21)
EDC3-306017-02
FREE
5
E
F.Matsuki
UNITS
mrn
2
B
8
F
很抱歉,暂时无法提供与“DF11Z-12DP-2V(21)”相匹配的价格&库存,您可以联系我们找货
