DF11Z-16DP-2V(21)
DF11Z-16DP-2V(21)
    HRS(广濑)
    CONN HDR 16POS
DF11Z-16DP-2V(21) 数据手册
A HR B DESCRIPTION OF REVISIONS BY CHKD DATE COUNT DESCRIPTION OF REVISIONS BY CHKD DATE DIS-H-000128 DIS-H-002465 CONTACT No.2 I~ DR +I c--J 1.5 ±0.3 CODE No. CL543-2017-3-21 CL543-2018-6-21 CL543-2019-9-21 CL543-2020-8-21 CL543-2021-0-21 CL543-2022-3-21 CL543-2023-6-21 CL543-2024-9-21 CL543-2025-1-21 CL543-2026-4-21 CL543-2027-7-21 CL543-2028-0-21 CL543-2029-2-21 CL543-2030-1-21 CL543-2031-4-21 '"'"' = +I AW = c--J = IN G CONTACT No.1 1.5±0.3 8 ±0.5 c '="'"' +I en FO NUMBER OF CONTACT PART No. DF11Z- 4DP-2V DF11Z- 6DP-2V DF11Z- 8DP-2V DF11Z-10DP-2V DF11Z-12DP-2V DF11Z-14DP-2V DF11Z-16DP-2V DF11Z-18DP-2V DF11Z-20DP-2V DF11Z-22DP-2V DF11Z-24DP-2V DF11Z-26DP-2V DF11Z-28DP-2V DF11Z-30DP-2V DF11Z-32DP-2V 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 A 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 B c 8.5 10.5 12.5 14.5 16.5 18.5 20.5 22.5 24.5 26.5 28.5 30.5 32.5 34.5 36.5 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 D 8.7 10.7 12.7 14.7 16.7 18.7 20.7 22.7 24.7 26.7 28.7 30.7 32.7 34.7 36.7 B RECOMMENDED PATTERN(2:1) A±0.1 c -0 0 ';@'; = 31'1" ·I •o 1?y;lW 0 ·1 I A problem has occurred in the display of PDF. Please...... download the latest data on the Hirose Connectors web site. J ~I) = +I c--J r-- D ~ P=2±0.05 R I I. E c--J +I 2 BRASS 1 POLYAMIDE NO. / ~/ I J -0 +I '"'"' = - --- -0 c±0.1 +l c--J D±0.1 2±0.1 D 2 ±0.1 RE NC SURFACE: TIN PLATED 1JL mmin UNDER PLATING:NICKEL PLATED 0.5JL mmin UL94V-O,NATURAL(BEIGE) FINISH, REMARKS MATERIAL F SCALE -E3- 5 - 1 UNITS mm 4 5 5 4 3 POLYESTER BRASS MATERIAL DESIGNED CHECKED FINISH, REMARKS E APPROVED F.Matsuki I.Denpouya T.Miyazaki T.Miyazaki '05.01.18 '05.01.18 DRAWING NO. PART NO. '05.01.20 RELEASED '05.01.20 DF11Z-*DP-2V(21) EDC3-306017-02 IRS E CLEAR(COVER TAPE) CLEAR(EMBOSSED CARRIER TAPE) TIN PLATED 1~ m min [DJ NO. DRAWN TO 3 +I c--J NOTESO> IF THERE IS PATTERN ON~ PART, THERE IS A POSSIBILITY THAT IT WILL MAKE CONTACT WITH THE LEADS. 2 :LEAD CO-PLANARITY INCLUDE REINFORCED METAL FITTINGS SHALL BE 0. 1mm MAX. = en 2 1 RE FE - ~I C±0.3 +I .l n u_ I = +I +0.05 -0.15 1.1 ±0.1 I~ ~ I c--J ¢1 ~ c--J CODE NO. (OLD) - 8 7 6 1 3 A±0.3 en DRAWING FOR REFERENCE: This is subject to change without notice 08/11/2012 5 COUNT S CAV No. 4 3 2 F CODE NO. CL543- HIROSE ELECTRIC CO., LTD 6 7 8 ~ A 2 HR I [ 1 1 c I I DRAWING FOR REFERENCE: This is subject to change without notice 08/11/2012 ---+--.:......: --I I Ill I I DR 7.8 ±0 .3 2 ±0.1 5±0.3 ~ 16 ±0.1 +I r-- I IN G I'll I I I, I I ttt----: I II I = .,.., rK AW I Ill DATE CHKD 9.4 ±0.3 1 I I BY K-K r-- LIJ L DESCRIPTION OF REVISIONS "' 11~11 1 7 6 == + B -- 5 MC10:1) L-L S L _j I, I 4 3 I I 1 ~ = +I '-" FO ~ CODE No. PART No. CL543-2017-3-21 DF11Z- 4DP-2V CL543-2018-6-21 DF11Z- 6DP-2V CL543-2019-9-21 DF11Z- 8DP-2V CL543-2020-8-21 DF11Z-10DP-2V CL543-2021-0-21 DF11Z-12DP-2V CL543-2022-3-21 DF11Z-14DP-2V CL543-2023-6-21 DF11Z-16DP-2V CL543-2024-9-21 DF11Z-18DP-2V CL543-2025-1-21 DF11Z-20DP-2V CL543-2026-4-21 DF11Z-22DP-2V CL543-2027-7-21 DF11Z-24DP-2V CL543-2028-0-21 DF11Z-26DP-2V CL543-2029-2-21 DF11Z-28DP-2V CL543-2030-1-21 DF11Z-30DP-2V CL543-2031-4-21 DF11Z-32DP-2V NUMBEROF CONTACT E 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 24.0 24.0 24. 0 32.0 32.0 44.0 44. 0 44.0 44.0 44.0 56.0 56.0 56.0 56.0 56.0 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 F G H 28.4 28.4 40.4 40 .4 40.4 40.4 40.4 52.4 52.4 52.4 52.4 52.4 11.5 11.5 11. 5 14.2 14.2 20.2 20. 2 20.2 20.2 20.2 26.2 26.2 26.2 26.2 26.2 J 24.4 PS 24.4 A-PET 24. 4 PS 32.4 PS 32.4 PS 44.4 PS 44. 4 A-PET 44.4 A-PET 44.4 PS 44.4 PS 56.4 PS 56.4 A-PET 56.4 A-PET 56.4 PS 56.4 PS c ~ = = +I +I LL.. ..,_, NOTES 3 1 REEL:500 CONNECTORS. THE BIGINNING OF THE REEL, 15 COMPONENTS I I I occurred I A problem has in the display of PDF. Please download the latest data 4onAT the Hirose Connectors web SHALL site. · BE EMPTY. II' I I I I II I AT THE END OF THE REEL, 10 COMPONENTS SHALL BE EMPTY. l I []>WHEN THE TAPE WIDTH IS 32, 44 AND 56mm, SPROCKET HOLES SHALL BE SET ON BOTH SIDES OF REEL AS SHOWN ON THIS D DRAWING. L_Lf__l__j ~THE MATERIAL OF THE EMBOSSED CARRIER TAPE REFERS TO THE TABLE. [[>DETAIL OF PART No. LABEL IS WRITTEN IN JAPANESE. f---H--I-$--$--1$t--$---$--$-$-$- : -$-~8 THE REEL IS POLYETHYLENE PACKAGED WITH AN DRY AGENT INSIDE FOR MOISTURE-PROOF PACKAGING. []>M i-K ~9 FOR THE STORAGE OF 168 HOURS OR MORE AFTER OPENING THE PACKAGE, KEEP THE PRODUCTS UNDER MOISTURE PROOF STYLE AND DIMENSION OF REEL DIRECTION OF UNREELING 2±0.5 CONDITIONS. SUPPLIER ~10 EXCEPT ON THE MATING SURFACE, COMPONENT INFLATION DOES E PART No. QUANTITY NOT AFFECT THE PRODUCTS PERFORMANCE. LABEL PART No. u .- 1 - - CODE No . --DATE OF MANUFACTURED = - r---= -e. CODE NO. (OLD) DESIGNED CHECKED APPROVED RELEASED DRAWN [[>DETAIL OF PART No. LABEL 111 --~,iii R rf- RE FE ~ L_.J RE NC I c==> ~ I f- - TO '--- '-- --- '----- j::~.F.JB $ BEI=8 F *P37\~:fii w *P37\~ F3 B CL543-****-*-21 DF11Z-*DP-2V(21) 500 KO ~~ l::: D iz ~ ~ 'f% J:'C :fHt jH+6) MAX ~ ~s~~L~E~~~ 3 4 I.Denpouya T.Miyazaki T.Miyazaki '05.01.18 '05.01.18 PART NO. DRAWING NO. '05.01.20 CODE NO. CL543- HIROSE ELECTRIC CO., LTD 6 7 D E '05.01.20 DF11Z-*DP-2V(21) EDC3-306017-02 FREE 5 E F.Matsuki UNITS mrn 2 B 8 F
DF11Z-16DP-2V(21) 价格&库存
很抱歉,暂时无法提供与“DF11Z-16DP-2V(21)”相匹配的价格&库存,您可以联系我们找货
