24295
    SWITCHCRAFT
    MEGA CON-X RECEP CAP
24295 数据手册
Switchcraft : Specification Page 1 of 2 U.S. Manufacturer of Industrial and Pro Audio/Broadcast Products Since 1946. Mega-Con-X Cable Connector Utilizing a separate o-ring,Mega Con X connectors are available up to 31-#20 pins/sockets. Can be ordered with quick connect type or threaded type coupling. Meets NEMA 6P when mated. Typical Specifications • • • • Rating: 0.9 thru 2.3A, 600V Conductor Size: 20 thru 24 AWG Configuration: 31 - #20 Contacts Certification: ◦ UL Recognized File #E150822 - 600V AC/DC ◦ CSA Certified File #181200 - 600V ◦ U.L. Temperature 75ºC max. ◦ Not for current interruption Material Specifications Cable Pin/Socket • • • • • • • • Mechanical Backshell (Threaded): Nylon, UL Recognized, Black Strap: Nylon, UL Recognized, Black Screws: Stainless Steel Grommet: Santoprene Rubber, Black Coupling Ring: Nylon, UL Recognized, Black Contacts: Brass, Gold over Nickel Connector Body: Nylon, UL Recognized, Black O-Ring: Neoprene Rubber, Black Panel Mount • • • • • Contacts: Brass, Gold over Nickel Panel Body: Nylon, UL Recognized, Black Gasket: Neoprene Rubber, Black Hex Nut: Nylon, UL Recognized, Black Gasket, O-Ring, & Grommet materials are suitable for storage -40ºC to +90ºC (40ºF to +194ºF). • Consult factory for higher temperature requirements. Mechanical Specifications • Durability: Minimum 300 mate/unmate cycles without mechanical or electrical failure • Vibration: Coupling rings have overriding locking feature to prevent loosening or separation of connector • Hex Nut Torque: All series hex nut to withstand 10-12 inch/lb tightening torque http://www.conxall.com/Specification.aspx?Parent=853 8/7/2012 Switchcraft : Specification Page 2 of 2 Electrical Specifications • Voltage: 600V • Current: See Electrical Current Rating Chart Environmental Specifications • Storage Temperature Rating: -40ºC to +115ºC (-40ºF to +239ºF) • Corrosion: 300 Hr salt spray contacts • Weathertight: Consult factory with specific application Molded Cable Assemblies • Watertight: NEMA 6P, 13: IEC IP67 http://www.conxall.com/Specification.aspx?Parent=853 8/7/2012
24295 价格&库存
很抱歉,暂时无法提供与“24295”相匹配的价格&库存,您可以联系我们找货
