The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
0.6mm Pitch Board-to-Fine-Coaxial Cable Connectors
DF21 Series
(7)
(4.55)
Nov.1.2016 Copyright 2018
Dec.1.2018
2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF21-*P-0.6SD(05)
+DF21-*P-0.6SD-GND(05)
DF21-*S-0.6V(56)
■Features
1.High Interconnection Reliability
Effective contact mating length of 1.55 mm, innovative bellow style contact design, built-in interlocking feature of
mated connectors assures high electrical and mechanical reliability, providing needed rigidity to resist
excessive twisting.
Superior reliability of the termination of the fine coaxial cable is accomplished with batch soldering.
2. Shielded design
Metal shell encloses the connector and makes contact with all external conductors of the fine coaxial cable
permitting reliable ground connection to the board side of mated assemblies.
3. Reliable mating/unmating
The connectors are self-align during mating.
Optional pull-out tab permits connection and disconnection in narrow spaces.
Polarized configuration prevents incorrect mating.
4. Board placement with Automatic Equipment.
The upper surface provides flat area for placement of embossed tape packaged connectors with vacuum
nozzles of automatic equipment.
■Applications
Notebook computers, liquid crystal displays (LCD), video and
audio devices, medical instruments, portable devices and
any other device requiring reliable connection and
termination with fine pitch coaxial cable.
Receptacle
Flat surface
for placement
with Automatic
Equipment
Metal Hold-down
B305
All non-RoHS
products
or will
the Connectors
DF21
Series●0.6mm
Pitch
Cable
■Product Specifications
Operating temperature range
Current rating
Ratings
AWG #40: 0.3 A
AWG #36: 0.5 A
Wire size
Voltage rating
50 V AC
Dec.1.2018
Item
20% to 80%
Storage temperature range
-10ç to 60ç (Note 2)
Storage humidity range
40% to 70% (Note 2)
Specifications
Condition
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
500M ohms min.
No flashover or insulation breakdown
100m ohms max.
Measured at 100 V DC
Conduction of 150 V AC applied for 1 minute
Measured at 100 mA
4. Vibration
No electrical discontinuity of 1μs or more.
Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3
directions, 2 hours
5. Humidity
Contact resistance of 100m ohms max., insulation
resistance of 50 M ohms min.
Temperature of 40±2ç, humidity of 90% to 95%, left standing
for 96 hours
6. Temperature cycle
(-55ç : 30minutes /5 to 35ç : 2 to 3minutes /85ç : 30minutes
/5 to 35ç: 2 to 3minutes ) for 5 cycles
7. Durability
30 cycles (mating/unmating)
8. Resistance to
Reflow heat
No melting of the resin parts that will affect performance
Reflow: at the recommended temperature profile, Solder: at a
soldering iron temperature of 300ç for 3 seconds
9. Resistance to
Soldering heat
No deformation of the insulator parts affecting performance.
Solder bond: Within 5 seconds at 270ç max., Within 30 seconds at 200ç
min. Hand soldering: Soldering iron temperature 300°C, 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and
specifications for a specific part number shown.
■Materials
Item
Part
Insulator
LCP
Black
UL94V-0
Receptacles
Contacts
Phosphor bronze
Gold plating
Metal fittings
Phosphor bronze
Tin copper plating
Insulator
LCP
Black
UL94V-0
Contacts
Phosphor bronze
Gold plating
Metal shell
Phosphor bronze
Tin plating
Metal shell
Stainless steel
Tin copper plating
Plugs
Metal shell
Material
Finish
■Ordering information
●Receptacles/Plug
DF 21 - * P - 0.6 SD - GND
1
2
1 Series name
: DF21
2 Number of contacts
: 20, 30
3
3 Connector type
S : Single-row receptacle
P : Single-row plug
4 Contact pitch
4
5
6
5 Termination section
V : Straight SMT
SD : Fine coaxial cable
6 Plug mounting parts
GND : Metal shell-required
: 0.6 mm
Note: The metal shell is an absolutely necessary part at the time of wiring.
B306
-35ç to 85ç (Note 1)
Operating humidity range
Remarks
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on theDF21
Hirose website
RoHS search atPitch
or contact your
Hirose
Series●0.6mm
Cable
Connectors
■Receptacles
3.8
3.2
0.2
A
B
0.2
3
●Embossed Carrier Tape Dimensions
Ø1
.5
+1
.5
4±0.1
1.75±0.1
2±0.1
12±0.1
t=0.4±0.1
2±0.5
(Ø80)
0.2
0.8
Ø330±2
Ø13±
E±0.3
D±0.1
C±0.1
Product
name
label
Ø21±
(E+0.4) +20
(E+6.4)MAX
3.8
Unreeling direction
[Specifications number] - * *, (* *)
(56) : Embossed tape packaging (1,000 pieces per reel)
Unit: mm
Product No.
CL No.
Number of Contacts
A
B
C
DF21-20S-0.6V(56)
687-0001-5-56
11.4
11.5
DF21-30S-0.6V(56)
687-0003-0-56
30
21.2
17.4
14.2
D
28.4
E
F
24
12.6
32
18.6
RoHS
YES
Note : One reel contains 1,000 pieces package unit. Please order by the package unit.
●Recommended PCB mounting pattern
B±0.03
0.35±0.02
1.6 +0.10
F±0.05
2.6±0.05
1.3 +0.10
P=0.6±0.03
2.3±0.05
Dec.1.2018
0.4
P=0.6
P=0.6
B307
All non-RoHS
products
or will
the Connectors
DF21
Series●0.6mm
Pitch
Cable
■Plugs
A
B
4.45
Unit: mm
Product No.
CL No.
Number of Contacts
A
B
C
DF21-20P-0.6SD(05)
687-1500-0-05
11.4
15
DF21-30P-0.6SD(05)
687-1502-6-05
30
28.5
17.4
21
YES
●Recommended Fine Coaxial Cable Preparation
C±0.5
B±0.15
Pitch maintaining
tape
Inner conductor
(Solder coating required)
0.4max
4.1MAX
2.75MIN
1.1
P=0.6±0.1
Ground bar
Insulator
Fine coaxial cable
1:
2:
2:
3:
00.0
0.55 -0.05
1.1MIN
Outer shield
(for individual conductor)
Note
Note
Note
Note
B308
RoHS
Note 1 : One package unit contains 100 pieces. Please order by the package unit.
Note 2: The metal shell is an absolutely necessary part at the time of wiring.
1.0 +0.10
-0.05
Dec.1.2018
6.8
P=0.6
C±0.3
Jacket
The pitch maintaining tape can be left in place during the termination process. Use high quality tape.
When using 2-conductor coaxial cable, some contact positions will not be usable.
Contact nearest Hirose sales office for recommendation on specific application.
Contact Hirose for Termination Procedures.
Hirose website
RoHS search atPitch
or contact your
Hirose
Series●0.6mm
Cable
Connectors
■Metal shell-Required for assembly of the Plug
Dec.1.2018
1.75
A
t=0.2
7
Unit: mm
Product No.
CL No.
Number of Contacts
A
DF21-20P-0.6SD-GND(05)
687-2500-6-05
DF21-30P-0.6SD-GND(05)
687-2502-1-05
30
23.7
RoHS
YES
Note 1: One package unit contains 100 pieces. Please order by the package unit.
B309
All non-RoHS
products
or will
the Connectors
DF21
Series●0.6mm
Pitch
Cable
BUsage Recommendations
1. Recommended
Temperature Profile
Temperture(ç)
250
IR re-flow
Preheating: 150 to160ç
Soldering:
250ç
60 to 120 sec
220ç min.
20 to 40 sec
250ç max.
10 sec max.
220ç
200
Dec.1.2018
150
60 sec max.
150ç
90 to 120 sec.
100
50
normal
temperture
100
150
200
250
300
Time(S)
Note 1: Up to 2 cycles of reflow soldering are possible under the same conditions, provided that
there is a return to normal temperature between the first and second cycle.
Note 2: The temperature profile indicates the board surface temperature at the point of contacts
with the connector terminals (for surface mounted plug assembly).
1. Receptacle Recommended
Soldering temperature: 340ç ±10°C, soldering time: within 5 sec.
Manual Soldering Conditions
2. Recommended Screen Thickness
0.15mm
3. Board Warping
Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points.
4. Cleaning Conditions
Refer to "Nylon Connector Use Handbook."
5. Plug Recommended
6. Handling and use
precautions
260ç ±5ç within 5 sec, 200ç min. within 25 sec.
■DO NOT mate/un-mate non-terminated plugs with non-mounted receptacles.
This may lead to damage or deformation of the contacts.
■DO NOT touch the exposed contacts of the receptacle with bare fingers. This may leave non-conductive film,
cause corrosion or electrostatic discharge, affecting performance of the connectors or sensitive electronic
components.
■DO NOT apply flux to the contact terminals when hand soldering the receptacle to the board. Wicking of the
flux into the electrical contact areas may lead to connection failures.
B310
Powered by TCPDF (www.tcpdf.org)
