8
7
4
5
6
1
2
3
REVISIONS
.300 7.62
.150 3.81
.040 1.02
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2187
03/01/11
TT
B
2779
6/25/2013
JH
C0
4180
INITIAL RELEASE
ADD TO-262 PACKAGE FOR REF, DIMENSION &
UPDATED TITLE & NOTE FORMAT
ADD S1713
2/21/2020
JH
F
PRELIMINARY
.370 9.40
.238 6.04
TO-262 WIDE LEAD PACKAGE
(FOR REF, NOT INCLUDED)
.788±.015 20.02±0.38
.030 0.76
A
E
E
.550 13.97
INSERTION DEPTH
.452 11.49
.690 17.53
D
D
.190±.025 4.83±0.64
.045 1.14
A
.025 0.64
.200 5.08
.668±.015 16.97±0.38
SECTION A-A
C
6X
.200 5.08
.150 3.81
C
.040 1.02 MIN
SULLINS P/N:
TCC03DKSN-S1478
TCC03DKSN-S1713
(SEE NOTE 13)
.300 7.62
PCB LAYOUT RECOMMENDED
B
A
NOTES:
1. INSULATOR MATERIAL: BROWN PPS
2. CONTACT MATERIAL: BERYLLIUM COPPER
3. PLATING: .000050" MIN NICKEL UNDERPLATE
CONTACT SURFACE: .000030" GOLD
TERMINATION: .000100" PURE TIN, MATTE
4. OPERATING TEMPERATURE: -65 C TO +175 C
5. PROCESSING TEMP: 260 C FOR 20 SECONDS MAX
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 850 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: SEE MODIFICATION
13. MODIFICATION: NO MOUNTING EARS, ONE SIDE ROUND & ONE SIDE SQUARE, CONTACT CENTER
.150", USE CANTILEVER SHORTING CONTACTS, .690" HEIGHT, .550" INSERTION DEPTH, .370" WIDTH
S1478 = MARK PARTS WITH LOT CODE ONLY
S1713 = MARK PARTS WITH PART NUMBER AND LOT CODE
8
7
6
5
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
03/01/11 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
TCC03DKSN-S1478, S1713
SIZE
C
CAGE CODE
54453
SCALE: 4:1
4
3
A
TO-262 WIDE LEAD SOCKET
2
DWG. NO.
C11574
REV
C0
SHEET 1 OF 1
1
FILE NAME: C11574, TCC03DKSN-S1478, S1713 SHORTING CONNECTOR
很抱歉,暂时无法提供与“TCC03DKSN-S1713”相匹配的价格&库存,您可以联系我们找货
