SLG59M1713V
SLG59M1713V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFQFN16
    A 4 MM 2 A NFET POWER CONTROL
SLG59M1713V 数据手册
SLG59M1713V An Ultra-small, 4 mΩ, 2 A Integrated Power Switch with Multiple Protection Features General Description Pin Configuration Operating from a 2.5 V to 5.5 V power supply and fully specified over the -40 °C to 85 °C temperature range, the SLG59M1713V is a high-performance 4 mΩ, 2 A single-channel nFET integrated power switch with adjustable inrush current control which is achieved by adjusting the VOUT slew rate with an external capacitor. Using a proprietary MOSFET design, the SLG59M1713V achieves a stable 4 mΩ RDSON across a wide input/supply voltage range. Incorporating two-stage current protection as well as thermal protection, the SLG59M1713V is designed for all 0.8 V to 5.5V power rail applications. Using Silego’s proprietary CuFET™ technology for high-current operation, the SLG59M1713V is packaged in a space-efficient, low thermal resistance, RoHS-compliant 1.6 mm x 2.5 mm STQFN package ON 1 NC 2 VIN 3 VIN 4 VIN 5 VIN 6 16 15 SLG59M1713V VDD GND 7 VIN 14 CAP 13 NC 8 12 VOUT 11 VOUT 10 VOUT 9 VOUT VOUT 16-pin FC-STQFN (Top View) Features • • • • • • Low Typical RDSON nFET: 4 mΩ Maximum Continuous Switch Current: Up to 2 A Supply Voltage: 2.5 V ≤ VDD ≤ 5.5 V Wide Input Voltage Range: 0.8 V ≤ VIN ≤ VDD Capacitor-adjustable Start-up and Inrush Current Control Two-stage Overcurrent Protection: • Fixed threshold, 4 A Active Current Limit • Fixed 0.5 A Short-circuit Current Limit • Internal VOUT Discharge • Operating Temperature: -40 °C to 85 °C • Low θJA, 16-pin 1.6 mm x 2.5 mm STQFN Packaging • Pb-Free / Halogen-Free / RoHS compliant Applications • Notebook Power Rail Switching • Tablet Power Rail Switching • Smartphone Power Rail Switching Block Diagram 2 A @ 4 mΩ VOUT VIN CIN +2.5 to 5.5 V CLOAD VDD Charge Pump Linear Ramp Control CAP CSLEW 4 nF Over Current and Over Temperature Protection SW Closed ON CMOS Input SW Open GND Silego Technology, Inc. 000-0059M1713-100 Rev 1.00 Revised February 23, 2017 SLG59M1713V Pin Description Pin # Pin Name Type Pin Description 1 VDD Power With an internal 1.9 V UVLO threshold, VDD supplies the power for the operation of the power switch and internal control circuitry where its range is 2.5 V ≤ VDD ≤ 5.5 V. Bypass the VDD pin to GND with a 0.1 μF (or larger) capacitor 2 NC NC 3-7 VIN MOSFET Drain terminal of Power MOSFET (Pins 3-7 fused together). Connect a 10 μF (or larger) low ESR capacitor from this pin to GND. Capacitors used at VIN should be rated at 10 V or higher. 8-12 VOUT MOSFET Source terminal of Power MOSFET (Pins 8-12 fused together) Connect a low ESR capacitor (up to 500 μF) from this pin to GND. Capacitors used at VOUT should be rated at 10 V or higher. 13 NC NC 14 CAP Input A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP pin to GND sets the VOUT slew rate and overall turn-on time of the SLG59M1713V. For best performance, the range for CSLEW values are 2 nF ≤ CSLEW ≤ 22 nF. Capacitors used at the CAP pin should be rated at 10 V or higher. 15 GND GND Ground Input A low-to-high transition on this pin closes the power switch. ON is an asserted-HIGH, level-sensitive CMOS input with VIL < 0.3 V and VIH > 0.85 V. Connect this pin to the output of a general-purpose output (GPO) from a microcontroller or other application processor. While there is an internal pull down circuit to ground (~4 MΩ), do not allow this pin to be open-circuited. 16 ON No Connect No Connect Ordering Information Part Number Type Production Flow SLG59M1713V STQFN 16L Industrial, -40 °C to 85 °C SLG59M1713VTR STQFN 16L (Tape and Reel) Industrial, -40 °C to 85 °C 000-0059M1713-100 Page 2 of 18 SLG59M1713V Absolute Maximum Ratings Parameter VDD VIN to GND VOUT to GND ON, CAP to GND TS Description Conditions Min. Typ. Max. Unit -- -- 6 V Power Switch Input Voltage to GND -0.3 -- 6 V Power Switch Output Voltage to GND -0.3 -- VIN V ON and CAP Pin Voltages to GND -0.3 -- 6 V Power Supply Pin to GND -65 -- 150 °C ESDHBM ESD Protection Human Body Model 2000 -- -- V ESDCDM ESD Protection Charged Device Model 500 -- -- V MSL θJA WDIS IDSMAX Storage Temperature Moisture Sensitivity Level Package Thermal Resistance, Junction-to-Ambient 1 1.6 x 2.5 mm 16L STQFN; Determined using 1 in2, 1.2 oz. copper pads under each VIN and VOUT on FR4 pcb material -- 35 -- °C/W Package Power Dissipation -- -- 1.2 W Max Continuous Switch Current -- -- 2 A -- -- 3 A MOSFET IDSPK Peak Current from Drain to Source Maximum pulsed switch current, pulse width < 1 ms, 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter VDD VDD(UVLO) IDD RDSON Description Conditions Power Supply Voltage Min. Typ. Max. Unit 2.5 -- 5.5 V VDD Undervoltage Lockout Threshold VDD ↑ 1.6 1.9 2.2 V VDD ↓ 1.5 1.8 2.2 V Power Supply Current when OFF VDD = VIN = 5.5 V; ON = 0 -- 1 2 μA Power Supply Current, ON (Steady State) VDD = VIN = ON = 5.5 V; No Load -- 120 170 μA VDD = VIN = 5 V; TA 25°C MOSFET @100 mA -- 4 5.5 mΩ 5 6.8 mΩ ON Resistance VDD = VIN = 5 V; TA 85°C MOSFET @100 mA MOSFET IDS Current from VIN to VOUT Continuous -- -- 2 A IFET_OFF MOSFET OFF Leakage Current VDD = VIN = 5.5 V; VOUT = 0 V; ON = 0 V -- -- 2 μA 0.8 -- VDD V VIN ILIMIT Drain Voltage Active Current Limit, IACL VOUT > 0.3 V 3 4 5 A Short-circuit Current Limit, ISCL VOUT < 0.3 V -- 0.5 -- A 000-0059M1713-100 Page 3 of 18 SLG59M1713V Electrical Characteristics (continued) TA = -40 °C to 85 °C (unless otherwise stated) Parameter TON_Delay VOUT(SR) TTotal_ON TOFF_Delay CLOAD Description Conditions ON pin Delay Time 50% ON to VOUT Ramp Start VDD = VIN = 5 V; CSLEW = 4 nF; RLOAD = 20 Ω, CLOAD = 10 μF VOUT Slew Rate Total Turn-on Time Min. Typ. Max. Unit -- 200 -- μs 10% VOUT to 90% VOUT ↑ Set by External CSLEW1 V/ms Example: CSLEW = 4 nF; VDD = VIN = 5 V; RLOAD = 20 Ω, CLOAD = 10 μF 2.5 V/ms 50% ON to 90% VOUT ↑ Set by External CSLEW1 ms Example: CSLEW = 4 nF; VDD = VIN = 5 V; RLOAD = 20 Ω, CLOAD = 10 μF 1.4 1.7 2 ms 2.9 3.5 OFF Delay Time 50% ON to VOUT Fall Start; VDD = VIN = 5 V; RLOAD = 20 Ω, no CLOAD -- 8 15 μs Output Load Capacitance CLOAD connected from VOUT to GND -- -- 500 μF RDISCHRG Output Discharge Resistance 180 220 260 Ω ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V ION(LKG) ON Pin Leakage Current -- 1.5 -- μA Thermal shutoff turn-on temperature -- 125 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C THERMON ON = ON_VIH or ON = GND Notes: 1. Refer to typical Timing Parameter vs. CSLEW performance charts for additional information when available. TON_Delay, Slew Rate, and TTotal_ON Timing Details ON 50% ON 50% ON TOFF_Delay 90% VOUT VOUT 90% VOUT TON_Delay 10% VOUT 10% VOUT VOUT(SR) (V/ms) TFALL TTotal_ON 000-0059M1713-100 Page 4 of 18 SLG59M1713V Typical Performance Characteristics RDSON vs. VDD and Temperature RDSON vs. VIN and VDD 000-0059M1713-100 Page 5 of 18 SLG59M1713V VOUT Slew Rate vs. Temperature, VDD, VIN, and CSLEW TTotal_ON vs. CSLEW, VIN, VDD, and Temperature 000-0059M1713-100 Page 6 of 18 SLG59M1713V Timing Diagram - Basic Operation including Active Current Limit Protection HIGH VDD 1.9 V LOW Time VIN ON TTotal_ON TRISE HIGH VOUT 90% TON_Delay 0.25 V IACL 10% Abnormal Step Load Current Event IACL Active Current Limit Operation IDS ISCL ISCL FAULT TFAULTLOW ACL Threshold Triggered 000-0059M1713-100 TFAULTHIGH Nominal Steady State Operation Resumes Page 7 of 18 SLG59M1713V Timing Diagram - Active Current Limit & Thermal Protection Operation HIGH VDD 1.9 V LOW Time VIN Nominal Steady State Operation Resumes ON TTotal_ON TRISE VOUT Active Current Limit Operation Thermal Protection Operation 90% TON_Delay 10% IACL Abnormal Step Load Current Event IACL IDS ISCL ISCL FAULT TFAULTLOW Die temp > THERMON 000-0059M1713-100 TFAULTHIGH Die temp < THERMOFF Page 8 of 18 SLG59M1713V SLG59M1713V Power-Up/Power-Down Sequence Considerations To ensure glitch-free power-up under all conditions, apply VDD first, followed by VIN after VDD exceeds 1.9 V. Then allow VIN to reach 90% of its max value before toggling the ON pin from Low-to-High. Likewise, power-down in reverse order. If VDD and VIN need to be powered up simultaneously, glitching can be minimized by having a suitable load capacitor. A 10 μF CLOAD will prevent glitches for rise times of VDD and VIN less than 2 ms. If the ON pin is toggled HIGH before VDD and VIN have reached their steady-state values, the IPS timing parameters may differ from datasheet specifications. The slew rate of output VOUT follows a linear ramp set by a capacitor connected to the CAP pin. A larger capacitor value at the CAP pin produces a slower ramp, reducing inrush current from capacitive loads. SLG59M1713V Current Limiting Operation The SLG59M1713V has two types of current limiting triggered by the output VOUT voltage. 1. Standard Current Limiting Mode (with Thermal Shutdown Protection) When the VOUT voltage > 300 mV, the output current is initially limited to the Active Current Limit (IACL) specification listed in the Electrical Characteristics table. The ACL monitor’s response time is very fast and is triggered within a few microseconds to sudden (transient) changes in load current. When a load current overload is detected, the ACL monitor increases the FET resistance to keep the current from exceeding the power switch’s IACL threshold. During active current-limit operation, VOUT is also reduced by IACL x RDSONACL. This observed behavior is illustrated in the timing diagrams on Pages 7 and 8. However, if a load-current overload condition persists where the die temperature rises because of the increased FET resistance, the power switch’s internal Thermal Shutdown Protection circuit can be activated. If the die temperature exceeds the listed THERMON specification, the FET is shut OFF completely, thereby allowing the die to cool. When the die cools to the listed THERMOFF temperature threshold, the FET is allowed to turn back on. This process may repeat as long as the output current overload condition persists. 2. Short Circuit Current Limiting Mode (with Thermal Shutdown Protection) When the VOUT voltage < 300 mV (which is the case with a hard short, such as a solder bridge on the power rail), the power switch’s internal Short-circuit Current Limit (SCL) monitor limits the FET current to approximately 500 mA (the ISCL threshold). While the internal Thermal Shutdown Protection circuit remains enabled and since the ISCL threshold is much lower than the IACL threshold, thermal shutdown protection may become activated only at higher ambient temperatures. SLG59M1713V Start-up Inrush Current Considerations with Capacitive Loads In distributed power applications, the SLG59M1713V is generally implemented on the outboard or downstream side of switching regulator dc/dc converters with internal overcurrent protection. As an adjustable output voltage slew-rate, integrated power switch, it is important to understand the start-up operation of the SLG59M1713V with capacitive loads. An equivalent circuit of the SLG59M1713V’s slew-rate control loop with capacitors at its VIN and VOUT pins is shown in Figure 1: 000-0059M1713-100 Page 9 of 18 SLG59M1713V SLG59M1713V Start-up Inrush Current Considerations with Capacitive Loads (continued) CSLEW Figure 1. SLG59M1713V’s Equivalent Slew-rate Control Loop Circuit. For a desired VOUT slew-rate (VOUT(SR)), a corresponding CSLEW value is selected. At the VOUT pin and with ON = LOW, the internal FET is OFF, VOUT is initially at 0V, and there is no stored charge on CLOAD. When a low-to-high transition is applied to the IC’s ON pin, an internal current source (I1) is enabled which, in turn, charges the external slew-rate capacitor, CSLEW. The SLG59M1713V’s internal micropower op amp sets the circuit’s VOUT(SR) based on the slew rate of the nodal voltage at its non-inverting pin (the voltage at the CAP pin). As a function of VOUT(SR) and CLOAD, a 1st-order expression for the circuit’s FET current (and inrush current) when a low-to-high transition on the ON pin is applied becomes: Start-up Current IDS or IINRUSH = VOUT(SR) x CLOAD From the expression above and for a given VOUT(SR), CLOAD determines the magnitude of the inrush current; that is, for large values of CLOAD, large inrush currents can result. If the inrush currents are large enough to trigger the overcurrent protection of an upstream dc/dc converter, the system can be shut down. In applications where the desired VOUT(SR) is fast and CLOAD is very large (>200 µF), there is a secondary effect on the observed VOUT(SR) attributed to the SLG59M1713V’s internal short-circuit current limit monitor (its SCL monitor). If the resultant inrush current is larger than the IC’s ISCL threshold, the SCL current monitor limits the inrush current and the current to charge CLOAD until the ISCL OFF threshold is crossed (~0.3V). During the time the SCL monitor’s been activated, the inrush current profile may exhibit an observable reduction in VOUT(SR) as shown in Figure 2 where CSLEW was set to 4nF and 470 µF was chosen for CLOAD. 000-0059M1713-100 Page 10 of 18 SLG59M1713V SLG59M1713V Start-up Inrush Current Considerations with Capacitive Loads (continued) Figure 2. A SLG59M1713V with CSLEW set to 4nF and 470µF for CLOAD. CLOAD-to-CSLEW ratio is greater than 33,600. Note that the internal SCL monitor’s been triggered and VOUT(SR) is reduced until VOUT reaches ~0.3V. A closer analysis of the IC’s internal slew-control large-scale yields the following: ISCL I1 = MSR x CLOAD CSLEW where ISCL = IC’s short-circuit current limit threshold, typically 0.5A; MSR = An internal slew-rate multiplier from the IC’s CAP pin to the VOUT pin; I1 = An internal current source to charge the external capacitor (CSLEW). Rearranging the equation to isolate both CLOAD and CSLEW yields the following: CLOAD ISCL = I xM CSLEW 1 SR For the SLG59M1713V device, the right-hand side of the expression is approximately 33,600 after taking into account part-to-part variations because of process, voltage, and temperature. Referring to the configuration of Figure 2’s scope capture, the CLOAD-to-CSLEW ratio is 117,500 (470µF/4nF) where it is evident that the SCL monitor circuit is charging CLOAD shortly after a low-to-high ON transition. If it is desired to avoid a reduction in VOUT(SR), the choices are decreasing CLOAD and/or increasing CSLEW so that the ratio is always less than 33,600 including taking into account external capacitor tolerances for initial accuracy and temperature. As shown in Figure 3, it was chosen to reduce VOUT(SR) by increasing CSLEW to 15nF while keeping CLOAD at 470µF. With this configuration, the ratio of CLOAD to CSLEW is about 31,333 (smaller than 33,600). Upon a low-to-high transition on the ON pin, the VOUT increases smoothly with no evidence of SCL monitor’s interaction. 000-0059M1713-100 Page 11 of 18 SLG59M1713V SLG59M1713V Start-up Inrush Current Considerations with Capacitive Loads (continued) Figure 3. A SLG59M1713V with CSLEW set to 15nF and 470µF retained for CLOAD. CLOAD-to-CSLEW ratio is smaller than 33,600. Note smooth VOUT transition. Power Dissipation The junction temperature of the SLG59M1713V depends on different factors such as board layout, ambient temperature, and other environmental factors. The primary contributor to the increase in the junction temperature of the SLG59M1713V is the power dissipation of its power MOSFET. Its power dissipation and the junction temperature in nominal operating mode can be calculated using the following equations: PD = RDSON x IDS2 where: PD = Power dissipation, in Watts (W) RDSON = Power MOSFET ON resistance, in Ohms (Ω) IDS = Output current, in Amps (A) and TJ = PD x θJA + TA where: TJ = Junction temperature, in Celsius degrees (°C) θJA = Package thermal resistance, in Celsius degrees per Watt (°C/W) TA = Ambient temperature, in Celsius degrees (°C) 000-0059M1713-100 Page 12 of 18 SLG59M1713V Power Dissipation (continued) During active current-limit operation, the SLG59M1713V’s power dissipation can be calculated by taking into account the voltage drop across the power switch (VIN-VOUT) and the magnitude of the output current in active current-limit operation (IACL): PD = (VIN-VOUT) x IACL or PD = (VIN – (RLOAD x IACL)) x IACL where: PD = Power dissipation, in Watts (W) VIN = Input Voltage, in Volts (V) RLOAD = Load Resistance, in Ohms (Ω) IACL = Output limited current, in Amps (A) VOUT = RLOAD x IACL For more information on Silego GreenFET3 integrated power switch features, please visit our Application Notes page at our website and see App Note “AN-1068 GreenFET3 Integrated Power Switch Basics”. 000-0059M1713-100 Page 13 of 18 SLG59M1713V Package Top Marking System Definition Pin 1 Identifier PPPPP WWNNN ARR Part Code Date Code + LOT Code Assembly + Rev. Code PPPPP - Part ID Field WW - Date Code Field1 NNN - Lot Traceability Code Field1 A - Assembly Site Code Field 2 RR - Part Revision Code Field2 Note 1: Each character in code field can be alphanumeric A-Z and 0-9 Note 2: Character in code field can be alphabetic A-Z 000-0059M1713-100 Page 14 of 18 SLG59M1713V Package Drawing and Dimensions 16 Lead STQFN Package 1.6 mm x 2.5 mm (Fused Lead) 000-0059M1713-100 Page 15 of 18 SLG59M1713V SLG59M1713V 16-pin STQFN PCB Landing Pattern 000-0059M1713-100 Page 16 of 18 SLG59M1713V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STQFN 16L 1.6x2.5mm 0.4P FCA Green 1.6x2.5x 0.55mm 16 3000 3000 178/60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Package Type STQFN 16L 1.6x2.5mm 0.4P FCA Green D0 Pocket BTM Pocket BTM Length Width Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.8 2.8 0.7 4 4 1.55 1.75 3.5 8 P0 Y E W F Section Y-Y Y P1 A0 B0 CL K0 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 2.2 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1713-100 Page 17 of 18 SLG59M1713V Revision History Date Version 2/23/2017 1.00 000-0059M1713-100 Change Production Release Page 18 of 18
SLG59M1713V 价格&库存
很抱歉,暂时无法提供与“SLG59M1713V”相匹配的价格&库存,您可以联系我们找货
