SLG59M1557V
SLG59M1557V
    DIALOGSEMICONDUCTOR(戴乐格)
    STDFN4_1X1MM
    IC PWR SWITCH P-CHAN 1:1 4STDFN
SLG59M1557V 数据手册
SLG59M1557V Ultra-small 28.5 mΩ, 1.0 A Load Switch with Discharge  General Description Pin Configuration ON 1 Features VIN 2 • One 1.0 A MOSFET • Ultra Low Quiescent Current • Low RDSON • 28.5 mΩ @ 5.0 V • 36.4 mΩ @ 3.3 V • 44.3 mΩ @ 2.5 V • 60.8 mΩ @ 1.8 V • 77.6 mΩ @ 1.5 V • VIN = 1.5 V to 5.5 V • Integrated Discharge Resistor • Pb-Free / Halogen-Free / RoHS compliant • STDFN 4L, 1.0 x 1.0 x 0.55 mm SLG59M1557V The SLG59M1557V is designed for load switching applications with ultra low quiescent current. The part comes with one 28.5 mΩ 1.0 A rated P-channel MOSFET controlled by a single ON control pin. The product is packaged in an ultra-small 1.0 x 1.0 mm package. 4 GND 3 VOUT 4-pin STDFN (Top View) Block Diagram VOUT VIN 1.0 A ON ©2022 Renesas Electronics Corporation 000-0059M1557-104 Fixed Slew Rate Control Rev 1.04 Revised February 4, 2022 SLG59M1557V  Pin Description Pin # Pin Name Type Pin Description 1 ON Input Turns on MOSFET. 2 VIN MOSFET Power MOSFET input 3 VOUT MOSFET Power MOSFET output 4 GND GND Ground Ordering Information Part Number Type Production Flow SLG59M1557V STDFN 4L Industrial, -40 °C to 85 °C SLG59M1557VTR STDFN 4L (Tape and Reel) Industrial, -40 °C to 85 °C 000-0059M1557-104 Page 2 of 10 SLG59M1557V  Absolute Maximum Ratings Parameter Description VIN Power Supply TS Storage Temperature ESDHBM WDIS ESD Protection Conditions Human Body Model Min. Typ. Max. Unit -- -- 6 V -65 -- 140 °C 2000 -- -- V -- -- 0.5 W -- -- 1.5 A Package Power Dissipation MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter Description Conditions VIN Power Supply Voltage -40 °C to 85 °C IDD Power Supply Current (PIN 2) ION_LKG RDSON RDSON IDS TON_Delay TTotal_ON when OFF, VIN = 5.5 V, No load Static Drain to Source ON Resistance @ TA 85°C Operating Current ON pin Delay Time Total Turn On Time 000-0059M1557-104 Typ. Max. Unit 1.5 -- 5.5 V -- 0.02 1 µA -- 0.05 0.5 µA -- -- 0.1 µA @ 5.5 V, 100 mA -- 28.5 32.0 mΩ @ 3.3 V, 100 mA -- 36.4 40.0 mΩ @ 2.5 V, 100 mA -- 44.3 49.0 mΩ @ 1.8 V, 100 mA -- 60.8 65.0 mΩ @ 1.5 V, 100 mA -- 77.6 82.0 mΩ @ 5.5 V, 100 mA -- 34.0 36.0 mΩ @ 3.3 V, 100 mA -- 43.8 46.0 mΩ @ 2.5 V, 100 mA -- 53.3 56.0 mΩ @ 1.8 V, 100 mA -- 72.2 76.0 mΩ @ 1.5 V, 100 mA -- 90.7 94.0 mΩ when ON = VIN, No load ON Pin Input Leakage Static Drain to Source ON Resistance @ TA 25°C Min. VIN = 1.5 V to 5.5 V -- -- 1.0 A 50% ON to Ramp Begin VIN = 5 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 10 15 27 µs 50% ON to Ramp Begin VIN = 3.3 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 17 31 40 µs 50% ON to Ramp Begin VIN = 1.5 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 44 69 96 µs 50% ON to 90% VOUT VIN = 5 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 114 122 134 µs 50% ON to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 µF, RL = 10Ω 146 156 176 µs 50% ON to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 292 332 399 µs Page 3 of 10 SLG59M1557V  TA = -40 °C to 85 °C (unless otherwise stated) Parameter TRISE Description Rise Time Min. Typ. Max. Unit 10% VOUT to 90% VOUT VIN = 5.0 V, VOUT_Cap = 0.1 µF, RL = 10 Ω Conditions 92 97 107 µs 10% VOUT to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 116 120 131 µs 10% VOUT to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 µF, RL = 10 Ω 228 253 296 µs VIN = 1.5 V to 5.5 V, VOUT = 0.4 V Input Bias 65 80 400 Ω RDIS Discharge Resistance ON_VIH Initial Turn On Voltage 0.85 -- VIN V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V 6.2 6.5 7.0 µs TDelay_OFF OFF Delay Time 000-0059M1557-104 50% ON to VOUT Fall, VIN = 5 V, RL =10 Ω, no CL Page 4 of 10 SLG59M1557V  VIN vs. Max IDS, Safe Operation Area Safe Operation Area VIN vs. Max IDS 8 7 6 5 VIN 4 SOA Boundary 3 2 1 0 0 0.5 1 1.5 2 Max IDS TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_DELAY 90% VOUT VOUT 90% VOUT TON_DELAY 10% VOUT 10% VOUT TRISE TFALL TTotal_ON 000-0059M1557-104 Page 5 of 10 SLG59M1557V  SLG59M1557V Power-Up/Power-Down Sequence Considerations A nominal power-up sequence is to apply VIN and toggle the ON pin LOW-to-HIGH after VIN is at least 90% of its final value. A nominal power-down sequence is the power-up sequence in reverse order. If VIN ramp is too fast, a voltage glitch may appear on the output pin at VOUT. To prevent glitches at the output, it is recommended to connect at least 0.1uF capacitor from the VOUT pin to GND and to keep the VIN ramp time less than 2 ms. SLG59M1557V Layout Suggestion Note: All dimensions shown in micrometers (µm) 000-0059M1557-104 Page 6 of 10 SLG59M1557V  Package Top Marking System Definition NN Pin 1 Identifier + Serial Number Line 1 Serial Number Line 2 NN -Part Serial Number Field Line 1 where each “N” character can be A-Z and 0-9 + - Part Serial Number Field Line 2 where “+” character can be +, -, =, or blank 000-0059M1557-104 Page 7 of 10 SLG59M1557V  Package Drawing and Dimensions 4 Lead STDFN Package 1.0 x 1.0 mm 000-0059M1557-104 Page 8 of 10 SLG59M1557V  Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 4L 1x1mm 0.4P FC Green 4 1.0 x 1.0 x 0.55 8000 8000 178 / 60 200 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 200 400 8 Part Pitch [mm] 2 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 4L 1x1mm 0.4P FC Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.16 1.16 0.63 4 2 1.5 1.75 3.5 8 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.55 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1557-104 Page 9 of 10 SLG59M1557V  Revision History Date Version 2/4/2022 1.04 11/14/2017 1.03 Updated Package Marking Definition 6/22/2016 1.02 Added section on Power Up/Down Sequence Considerations Removed IDS_lkg parameter (same as IDD when OFF) Updated Recommended Layout suggestion 9/11/2015 1.01 Updated IDD and Tdelay_ON 000-0059M1557-104 Change Updated Company name and logo Fixed typos Page 10 of 10 IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1557V 价格&库存
很抱歉,暂时无法提供与“SLG59M1557V”相匹配的价格&库存,您可以联系我们找货
SLG59M1557V
    • 8000+1.332238000+0.16160
    • 16000+1.3260016000+0.16084
    • 24000+1.3259724000+0.16084
    • 32000+1.3259532000+0.16083
