SLG59M1515V
SLG59M1515V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN8
    IC PWR SWITCH N-CHANNEL 1:1 8DFN
SLG59M1515V 数据手册
SLG59M1515V 20 mΩ, 2.0 A Fast Turn On Load Switch with Discharge  General Description Pin Configuration VDD 1 ON 2 D 3 D 4 Features • 1.0 x 1.6 x 0.55 mm STDFN 8L package (2 fused pins for drain and 2 fused pins for source) • Logic level ON pin capable of supporting 0.85 V CMOS Logic • Discharged Load when off • Fast Turn On time • 25 µs, Tune Cap = 0.1 nF, CLOAD = 1 µF @ 100 mA • 95 µs, Tune Cap = 0.5 nF, CLOAD = 10 µF @ 2.5 A • Low RDSONwhile supporting 2.0 A • 20 mΩ, VDD = 5 V, VD = 1 V • 27.5 mΩ, VDD = 3.3 V, VD = 1 V • Pb-Free / Halogen-Free / RoHS compliant • Operating Temperature: -40 °C to 85°C • Operating Voltage: 2.5 V to 5.5 V • Power Rail Switching VD = 0.85 V to VD = VDD - 1.5 V SLG59M1515V The SLG59M1515V is a 20 mΩ 2.0 A single-channel load switch with configurable slew rate control. The device can enable fast power rail turn on with big cap loading. Internal circuit limits max inrush current to prevent device damage. The product is packaged in an ultra-small 1.0x1.6mm package. 8 GND 7 CAP 6 S 5 S 8-pin STDFN (Top View) Applications • Fast Turn On/Off power rail switching with big Cap loading • Frequent wake & sleep power cycle • Mobile devices and portable devices Block Diagram 2.0 A @ 20 mΩ D S VDD +2.5 V to 5.5 V ON ©2022 Renesas Electronics Corporation 000-0059M1515-102 TUNE CAP Input Circuit Rev 1.02 Revised February 14, 2022 SLG59M1515V  Pin Description Pin # Pin Name Type Pin Description 1 VDD PWR VDD power for load switch control (2.5 V to 5.5 V) 2 ON Input Turns MOSFET ON (4 MΩ pull down resistor) CMOS input with VIL < 0.3 V, VIH > 0.85 V 3 D MOSFET Drain of Power MOSFET (fused with pin 4) 4 D MOSFET Drain of Power MOSFET (fused with pin 3) 5 S MOSFET Source of Power MOSFET (fused with pin 6) 6 S MOSFET Source of Power MOSFET (fused with pin 5) 7 CAP CAP Tuning Cap 8 GND GND Ground Ordering Information Part Number Type Production Flow SLG59M1515V STDFN 8L Industrial, -40 °C to 85 °C SLG59M1515VTR STDFN 8L (Tape and Reel) Industrial, -40 °C to 85 °C 000-0059M1515-102 Page 2 of 9 SLG59M1515V  Absolute Maximum Ratings Parameter VDD TS Description Conditions Min. Typ. Max. Unit -- -- 7 V Power Supply -65 -- 150 °C 2000 -- -- V -- -- 0.4 W For no more than 20 µs with 1% duty cycle -- -- 25.0 A MOSFET IDSPK Peak Current from Drain to Source For no more than 50 µs with 1% duty cycle -- -- 12.5 A For no more than 1 ms with 1% duty cycle -- -- 3.5 A ESDHBM WDIS Storage Temperature ESD Protection Human Body Model Package Power Dissipation Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter Description Conditions VDD Power Supply Voltage -40 °C to 85 °C IDD Power Supply Current (PIN 1) Static Drain to Source ON Resistance, TA = 25°C RDSON Static Drain to Source ON Resistance, TA = 70°C Static Drain to Source ON Resistance, TA = 85°C IDS Operating Current VD Drain Voltage TON_Delay ON Delay Time 000-0059M1515-102 Min. Typ. Max. Unit 2.5 -- 5.5 V when OFF -- -- 1 µA when ON, No load -- -- 10 µA VDD = 5 V, VD = 1.05 V, VDD - VD = 4.0 V, RL = 0.5 Ω -- 20 22 mΩ VDD = 3.3 V, VD = 1.05 V, VDD - VD = 2.3 V, RL = 0.5 Ω -- 27.5 29 mΩ VDD = 5 V, VD = 1.05 V, VDD - VD = 4.0 V, RL = 0.5 Ω -- 23.5 25 mΩ VDD = 3.3 V, VD = 1.05 V, VDD - VD = 2.3 V, RL = 0.5 Ω -- 31 33 mΩ VDD = 5 V, VD = 1.05 V, VDD - VD = 4.0 V, RL = 0.5 Ω -- 24.5 26 mΩ VDD = 3.3 V, VD = 1.05 V, VDD - VD = 2.3 V, RL = 0.5 Ω -- 33 35 mΩ VD = 0.85 V to 3.3 V -- -- 2.0 A 0.85 -- VDD - 1.5 V 50% ON to 10% VS, Internal Logic Delay, VDD = 5 V, VD = 1.05 V, Tune Cap = 0.1 nF -- 12 15 µs 50% ON to 10% VS, Internal Logic Delay, VDD = 5 V, VD = 1.05 V, Tune Cap = 0.5 nF -- 32 35 µs Page 3 of 9 SLG59M1515V  TA = -40 °C to 85 °C (unless otherwise stated) Parameter Description Conditions Min. 50% ON to 90% VS TTotal_ON Total Turn On Time Typ. Max. Unit Configurable 50% ON to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 1 µF, Current Load = 50 mA, Tune Cap = 0.1 nF -- 32 39 µs 50% ON to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 1 µF, Current Load = 100 mA, Tune Cap = 0.1 nF -- 32 39 µs 50% ON to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 4.7 µF, Current Load = 2.5 A, Tune Cap = 0.5 nF -- 102 123 µs 50% ON to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 10 µF, Current Load = 2.5 A, Tune Cap = 0.5 nF -- 102 123 µs 10% VS to 90% VS Configurable 10% VS to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 1 µF, Current Load = 50 mA, Tune Cap = 0.1 nF -- 65 78 V/ms 10% VS to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 1 µF, Current Load = 100 mA, Tune Cap = 0.1 nF -- 65 78 V/ms 10% VS to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 4.7 µF, Current Load = 2.5 A, Tune Cap = 0.5 nF -- 13 16 V/ms 10% VS to 90% VS, VDD = 5 V, VD = 1.0 V, CL = 10 µF, Current Load = 2.5 A, Tune Cap = 0.5 nF -- 13.5 16.5 V/ms Source to GND -- -- 10 µF Discharge Resistance 100 150 300 Ω ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin TSLEWRATE Slew Rate CAPSOURCE Source Cap RDIS TOFF_Delay OFF Delay Time THERM_OFF Thermal Protection Shutoff -0.3 0 0.3 V 50% ON to VS Fall, CL = 10 µF, RL = 20 Ω, VDD = 5 V, VD = 1.0 V, No Tune CAP -- 120 150 µs Programmable, automatic shutoff temperature -- 125 -- °C -- -- ±20 % -- -- 100 µs THERThermal Sensor Accuracy M_OFF_ACC THERM_DT Thermal Disable Time 000-0059M1515-102 Thermal sensor disable for the ON rising edge to 100 µs. Prevent therm shutdown from inrush current Page 4 of 9 SLG59M1515V  V/ms Tune Cap vs Slew Rate Slew Rate (V/ms) Vs. Cap, VDD = 5V, VD = 1V, TA = 25C, 10%VS to 90%VS 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 CL = 4.7uF; IDS = 2.5A CL = 10uF; IDS = 2.5A CL = 1uF; IDS = 0.1A CL = 1uF; IDS = 0.05A 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 Cap (nF) Tune Cap vs Ttotal_on Ttotal_on vs Cap. 50%ON to 90%VS, TA = 25C VDD = 5V, VD = 1V 0.800 Ttotal_on (ms) 0.700 0.600 0.500 0.400 0.300 CL = 4.7uF; IDS = 2.5A 0.200 CL = 10uF; IDS = 2.5A CL = 1uF; IDS = 0.1A 0.100 CL = 1uF; IDS = 0.05A 0.000 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 Cap (nF) 000-0059M1515-102 Page 5 of 9 SLG59M1515V  TTotal_ON, TON_Delay and Slew Rate Measurement (TBD) ON 50% ON 50% ON TOFF_DELAY 90% VS VS 90% VS TON_DELAY 10% VS 10% VS Slew Rate (V/ms) TFALL TTotal_ON 000-0059M1515-102 Page 6 of 9 SLG59M1515V  Package Top Marking System Definition ABC Serial Number Pin 1 Identifier 000-0059M1515-102 Page 7 of 9 SLG59M1515V  Package Drawing and Dimensions 8 Lead STDFN Package 1.0 x 1.6 mm (Fused Lead) 000-0059M1515-102 Page 8 of 9 SLG59M1515V  Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 8L 1x1.6mm 0.4P FC Green 8 1.0 x 1.6 x 0.55 3,000 3,000 178 / 60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 8L 1x1.6mm 0.4P FC Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.12 1.72 0.7 4 4 1.55 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.88 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1515-102 Page 9 of 9 IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1515V 价格&库存
很抱歉,暂时无法提供与“SLG59M1515V”相匹配的价格&库存,您可以联系我们找货
