SLG59H1005V
A 22 V, 50 mΩ, 3 A, Reverse Blocking Load Switch
with VIN Lockout Select and MOSFET Current Monitor Output
General Description
Pin Configuration
The SLG59H1005V is a high-performance, self-powered
50 mΩ NMOS load switch with back-to-back reverse-current
blocking designed for all 4.5 V to 22 V power rails up to 3 A.
Using a proprietary MOSFET design, the SLG59H1005V
achieves a stable 50 mΩ RDSON across a wide input voltage
range. In combining novel FET design and copper pillar
interconnects, the SLG59H1005V package also exhibits a low
thermal resistance for high-current operation.
Features
• Wide Operating Input Voltage: 4.5 V to 22 V
• Maximum Continuous Current: 3 A
• Automatic nFET SOA Protection
• 5 W SOA Protection Threshold
• Back-to-Back FET Reverse Current Blocking, when OFF
• Internal nFET Power Limiting
• High-performance MOSFET Switch
Low RDSON: 50 mΩ at VIN = 22 V
Low ΔRDSON/ΔVIN: < 0.05 mΩ/V
Low ΔRDSON/ΔT: < 0.06 mΩ/°C
• 4-Level, Pin-selectable VIN Overvoltage Lockout
• Capacitor-adjustable Inrush Current Control
• Two stage Current Limit Protection:
Resistor-adjustable Active Current Limit
Internal Short-circuit Current limit
• Open Drain FAULT Signaling
• MOSFET Current Analog Output Monitor: 10 µA/A
• Pb-Free / Halogen-Free / RoHS Compliant Packaging
ON
1 18
SEL0
2
GND
3
VIN
4
VIN
5
VIN
6
VIN
7
17
SLG59H1005V
Designed to operate over a -40°C to 85°C range, the
SLG59H1005V is available in a low thermal resistance,
RoHS-compliant, 1.6 x 3.0 mm STQFN package.
RSET IOUT
8
VIN
16
CAP
15
FAULT
14
SEL1
13
VOUT
12
VOUT
11
VOUT
10
VOUT
9
VOUT
18-pin STQFN
1.6 x 3.0 mm, 0.40mm pitch
(Top View)
Applications
Power-Rail Switching
Multifunction Printers
Large-format Copiers
Telecommunications Equipment
High-performance Computing
4.5 V and 22 V Point-of-Load Power Distribution
• Motor Drives
Block Diagram and a 20 V / 3 A Typical Application Circuit
CLOAD
22 µF
20 V ±10%
3A
VIN
VOUT
CIN= C1 + C2 + C3
C1
47 µF
C2
1 to
22 µF
Charge
Pump
C3
0.1 µF
Linear Ramp Control
CAP
CSLEW
10 nF
VLOGIC
SEL0
SEL1
ON
ON
RIOUT
84.5 kΩ
3 V FS - Connect
to System ADC
CIOUT
180 pF
VLOGIC
RSET
RSET
30.1 kΩ
RPU1
10 kΩ
IOUT
VIN OVLO
24V
State Machine
(CL/SC Detection and
Over Temperature
Protection)
RPU2
100 kΩ
FAULT
Connect to
System GPI
CMOS Input
OFF
GND
Datasheet
CFR0011-120-01
Revision 1.04
Page 1 of 36
2-Feb-2022
©2022 Renesas Electronics Corporation
SLG59H1005V
Pin Description
Pin #
1
Pin
Name
ON
Type
Pin Description
Input
A low-to-high transition on this pin initiates the operation of the SLG59H1005V’s state machine. ON
is an asserted HIGH, level-sensitive CMOS input with ON_VIL < 0.3 V and ON_VIH > 0.9 V. As the
ON pin input circuit does not have an internal pull-down resistor, connect this pin to a
general-purpose output (GPO) of a microcontroller, an application processor, or a system controller
– do not allow this pin to be open-circuited.
2
SEL0
Input
As level-sensitive, CMOS inputs with VIL < 0.3 V and VIH > 1.65 V, the SEL0 (LSB) and the SEL1
(MSB) pins select one of four VIN overvoltage lockout thresholds. Please see the Applications
Section for additional information and the Electrical Characteristics table for the VIN overvoltage
thresholds. A logic LOW on either pin is achieved by connecting the pin of interest to GND; a logic
HIGH on either pin is achieved by connecting a 10 kΩ external resistor from the pin in question to
the system’s local logic supply.
3
GND
GND
Pin 3 is the main ground connection for the SLG59H1005V’s internal charge pump, its gate driver
and current-limit circuits as well as its internal state machine. Therefore, use a short, stout connection
from Pin 3 to the system’s analog or power plane.
4-8
9-13
14
VIN
VIN supplies the power for the operation of the SLG59H1005V, its internal control circuitry, and the
drain terminal of the back-to-back, reverse-blocking nFET load switch. With 5 pins fused together
MOSFET
at VIN, connect a 47 µF (or larger) low-ESR capacitor from this pin to ground. Capacitors used at
VIN should be rated at 50 V or higher.
VOUT MOSFET
Drain terminal of n-channel MOSFET (5 pins fused for VOUT). Connect a 22 µF (or larger) low-ESR
capacitor from this pin to ground. Capacitors used at VOUT should be rated at 50 V or higher.
SEL1
Please see SEL0 Pin Description above
Input
FAULT
An open drain output, FAULT is asserted within TFAULTLOW when a VIN overvoltage, a current-limit,
or an over-temperature condition is detected. FAULT is deasserted within TFAULTHIGH when the
Output
fault condition is removed. Connect an 100 kΩ external resistor from the FAULT pin to local system
logic supply.
CAP
A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP pin to GND sets
the VOUT slew rate and overall turn-on time of the SLG59H1005V. For best performance, the range
Output for CSLEW values are 10 nF ≤ CSLEW ≤ 20 nF – please see typical characteristics for additional
information. Capacitors used at the CAP pin should be rated at 10 V or higher. Please consult
Applications Section on how to select CSLEW based on VOUT slew rate and loading conditions.
17
IOUT
IOUT is the SLG59H1005V’s power MOSFET load current monitor output. As an analog current
output, this signal when applied to a ground-reference resistor generates a voltage proportional to
the current through the n-channel MOSFET. The IOUT transfer characteristic is typically 10 μA/A with
Output
a voltage compliance range of 0.5 V ≤ VIOUT ≤ 4 V. Optimal IOUT linearity is exhibited for
0.5 A ≤ IDS ≤ 3 A. In addition, it is recommended to bypass the IOUT pin to GND with a 0.18 nF
capacitor.
18
RSET
15
16
Input
A 1%-tolerance, metal-film resistor between 30 kΩ and 91 kΩ sets the SLG59H1005V’s active
current limit. A 91 kΩ resistor sets the SLG59H1005V’s active current limit to 1 A and a 30 kΩ resistor
sets the active current limit to 3 A.
Ordering Information
Part Number
Type
Production Flow
SLG59H1005V
STQFN 18L FC
Industrial, -40 °C to 85 °C
SLG59H1005VTR
STQFN 18L FC (Tape and Reel)
Datasheet
CFR0011-120-01
Revision 1.04
Page 2 of 36
2-Feb-2022
SLG59H1005V
Absolute Maximum Ratings
Parameter
Description
VIN to GND
Load Switch Input Voltage to GND
VOUT to GND
Conditions
Min.
Typ.
Max.
Unit
Continuous
-0.3
30
V
32
V
-0.3
VIN
V
-0.3
7
V
-65
150
°C
Maximum pulsed VIN, pulse
width < 0.1 s
Load Switch Output Voltage to GND
ON, SEL[1,0], CAP,
ON, SEL[1,0], CAP, RSET, IOUT,
RSET, IOUT, and
and FAULT Pin Voltages to GND
FAULT to GND
TS
Storage Temperature
ESDHBM
ESDCDM
MSL
ESD Protection
Human Body Model
2000
V
ESD Protection
Charged Device Model
500
V
Moisture Sensitivity Level
θJA
1
1.6 x 3.0 mm 18L STQFN; Determined with the device mounted onto a 1 in2, 1 oz. copper pad
of FR-4 material
Thermal Resistance
TJ,MAX
Maximum Junction Temperature
MOSFET IDSCONT
Continuous Current from VIN to
VOUT
MOSFET IDSPEAK Peak Current from VIN to VOUT
40
°C/W
150
°C
TJ < 150 °C
3
A
Maximum pulsed switch current,
pulse width < 1 ms
5
A
Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating
only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this
specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability.
4.5 V ≤ VIN ≤ 22 V; CIN = 47 µF, TA = -40 °C to 85 °C, unless otherwise noted. Typical values are at TA = 25 °C
Parameter
VIN
VIN(OVLO)
Description
Conditions
VIN Overvoltage Lockout Threshold
Min.
Typ.
Max.
Unit
4.5
22
V
VIN ↑; SEL[1,0] = [0,0]
5.6
6
6.3
V
VIN ↑; SEL[1,0] = [0,1]
10.2
10.8
11.4
V
VIN ↑; SEL[1,0] = [1,0]
13.5
14.4
15.2
V
VIN ↑; SEL[1,0] = [1,1]
22.6
24
25.2
V
2
VIN(OVLOHYST)
Hysteresis
VIN(UVLO)
VIN Undervoltage Lockout
Threshold
VIN ↓
3
3.2
3.4
V
IQ
Quiescent Supply Current
ON = HIGH;
IDS = 0 A
0.5
0.6
mA
ISHDN
OFF Mode Supply Current
ON = LOW;
IDS = 0 A
1
3
µA
TA = 25 °C;
IDS = 0.1 A
50
52
mΩ
TA = 85 °C;
IDS = 0.1 A
65
68
mΩ
RDSON
Datasheet
CFR0011-120-01
ON Resistance
Revision 1.04
Page 3 of 36
2-Feb-2022
SLG59H1005V
Electrical Characteristics (continued)
Parameter
Description
Conditions
Min.
Typ.
Max.
Unit
MOSFET
IDS
Continuous
3
A
IREVERSE
MOSFET Reverse-Leakage Current
VIN = 0 V; VOUT = 22 V; ON = 0 V
3
µA
Active Current Limit, IACL
VOUT > 0.5 V; RSET = 30.1 kΩ
3
3.2
3.4
A
ILIMIT
Short-circuit Current Limit, ISCL
VOUT < 0.5 V
0.5
A
TACL
Active Current Limit Response Time
RSET = 51.6 kΩ
120
µs
IOUT
MOSFET Current Analog Monitor
Output
IDS = 1 A
9.3
10
10.7
µA
IDS = 3 A
28.5
30
31.5
µA
TIOUT
IOUT Response Time to Change in
Main MOSFET Current
CIOUT = 180 pF;
Step load 0 to 2.4 A; 0% to 90% IOUT
45
µs
CLOAD
Output Load Capacitance
TON_Delay
ON Delay Time
CLOAD connected from VOUT to GND
22
µF
50% ON to 10% VOUT ↑;
VIN = 4.5 V; CSLEW = 10 nF;
RLOAD = 100 Ω, CLOAD = 10 µF
0.3
0.5
ms
VIN = 22 V; CSLEW = 10 nF;
RLOAD = 100 Ω, CLOAD = 10µF
0.7
1.2
ms
Set by External CSLEW 1
ms
50% ON to 90% VOUT ↑
TTotal_ON
Total Turn ON Time
VOUT(SR)
VOUT Slew Rate
TOFF_Delay
OFF Delay Time
50% ON to 90% VOUT ↑;
1.5
2.1
ms
6.5
8
ms
V/ms
10% to 90% VOUT ↑;
VIN = 4.5 V to 22 V; CSLEW = 10 nF;
2.7
3.2
3.9
V/ms
15
µs
10.4
12.7
14.3
µs
50% ON to VOUT Fall Start ↓;
VIN = 4.5 V to 22 V
RLOAD = 100 Ω, No CLOAD
90% VOUT to 10% VOUT ↓;
TFALL
VOUT Fall Time
ON = HIGH-to-LOW;
TFAULTLOW FAULT Assertion Time
Abnormal Step Load Current event to
FAULT↓; IACL = 1 A; VIN = 22 V;
RSET = 91 kΩ; switch in 20 Ω load
80
µs
TFAULTHIGH FAULT De-assertion Time
Delay to FAULT↑ after fault condition
is removed; IACL = 1 A; VIN = 22 V;
RSET = 91 kΩ; switch out 20 Ω load
180
µs
IFAULT = 1 mA
0.2
V
FAULTVOL
FAULT Output Low Voltage
ON_VIH
ON Pin Input High Voltage
0.9
5
V
ON_VIL
ON Pin Input Low Voltage
-0.3
V
SEL[1,0]_VIH SEL[1,0] pins Input High Voltage
1.65
4.5
V
SEL[1,0]_VIL SEL[1,0] pins Input Low Voltage
-0.3
0.3
V
Datasheet
CFR0011-120-01
Revision 1.04
Page 4 of 36
2-Feb-2022
SLG59H1005V
Parameter
Description
Conditions
ION(Leakage)
ON Pin Leakage Current
1 V ≤ ON ≤ 5 V or ON = GND
Min.
Typ.
Max.
Unit
1
µA
THERMON
Thermal Protection Shutdown
Threshold
125
°C
THERMOFF
Thermal Protection Restart Threshold
100
°C
Notes:
1. Refer to typical Timing Parameter vs. CSLEW performance charts for additional information when available.
TTotal_ON, TON_Delay and Slew Rate Measurement
ON*
50% ON
50% ON
TOFF_Delay
90% VOUT
VOUT
90% VOUT
TON_Delay
10% VOUT
10% VOUT
VOUT(SR) (V/ms)
TFALL
TTotal_ON
*Rise and Fall Times of the ON Signal are 100 ns
Datasheet
CFR0011-120-01
Revision 1.04
Page 5 of 36
2-Feb-2022
SLG59H1005V
Typical Performance Characteristics
RDSON vs. Temperature and VIN
IACL vs. Temperature and RSET
Datasheet
CFR0011-120-01
Revision 1.04
Page 6 of 36
2-Feb-2022
SLG59H1005V
IACL vs. RSET and VIN
IOUT vs. MOSFET IDS and VIN
Datasheet
CFR0011-120-01
Revision 1.04
Page 7 of 36
2-Feb-2022
SLG59H1005V
IOUT vs. Temperature and MOSFET IDS
VOUT Slew Rate vs. Temperature, VIN, and CSLEW
Datasheet
CFR0011-120-01
Revision 1.04
Page 8 of 36
2-Feb-2022
SLG59H1005V
TTotal_ON vs. CSLEW, VIN, and Temperature
Datasheet
CFR0011-120-01
Revision 1.04
Page 9 of 36
2-Feb-2022
SLG59H1005V
Timing Diagram - Basic Operation including Active Current Limit Protection
HIGH
VIN
LOW
Time
ON
TRISE
HIGH
VOUT
90%
TON_Delay
10%
IACL
Abnormal Step Load
Current Event
IACL
Operation
IDS
ISCL
ISCL
FAULT
TFAULTLOW
TFAULTHIGH
Nominal Steady State
Operation Resumes
ACL Threshold Triggered
Datasheet
CFR0011-120-01
Revision 1.04
Page 10 of 36
2-Feb-2022
SLG59H1005V
Timing Diagram - Active Current Limit & Thermal Protection Operation
HIGH
VIN
LOW
Time
Operation Resumes
ON
TTotal_ON
Operation
TRISE
VOUT
Thermal Protection
Operation
90%
TON_Delay
10%
Abnormal Step Load
Current Event
IACL
IACL
IDS
ISCL
ISCL
FAULT
TFAULTLOW
TFAULTHIGH
Die temp > THERMON
Datasheet
CFR0011-120-01
Revision 1.04
Page 11 of 36
Die temp < THERMOFF
2-Feb-2022
SLG59H1005V
Timing Diagram - Basic Operation including Active Current + Internal FET SOA Protection
HIGH
VIN
LOW
Time
ON
TRISE
HIGH
VOUT
Decreasing RLOAD drops VOUT
90%
TON_Delay
SOA
Threshold
10%
IACL
Abnormal Step Load
Current Event
Operation
IACL
SOA
Protection
IDS
ISCL
ISCL
0.2s
FAULT
TFAULTLOW
TFAULTHIGH
Operation resumes once
overload condition is
removed
FET SOA Threshold
Triggered and FET is
turned off
Datasheet
CFR0011-120-01
Revision 1.04
Page 12 of 36
Automatic restart after
0.2s “cool off” delay
and normal operation
resumes if overload
2-Feb-2022
SLG59H1005V
SLG59H1005V Application Diagram
Figure 1. Test setup Application Diagram
Typical Turn-on Waveforms
Figure 2. Typical Turn ON operation waveform for VIN = 4.5 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 13 of 36
2-Feb-2022
SLG59H1005V
Figure 3. Typical Turn ON operation waveform for VIN = 4.5 V, CSLEW = 18 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 4. Typical Turn ON operation waveform for VIN = 9 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 14 of 36
2-Feb-2022
SLG59H1005V
Figure 5. Typical Turn ON operation waveform for VIN = 9 V, CSLEW = 18 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 6. Typical Turn ON operation waveform for VIN = 12 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 15 of 36
2-Feb-2022
SLG59H1005V
Figure 7. Typical Turn ON operation waveform for VIN = 12 V, CSLEW = 18 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 8. Typical Turn ON operation waveform for VIN = 20 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 16 of 36
2-Feb-2022
SLG59H1005V
Figure 9. Typical Turn ON operation waveform for VIN = 20 V, CSLEW = 18 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Typical Turn-off Waveforms
Figure 10. Typical Turn OFF operation waveform for VIN = 4.5 V, CSLEW = 10 nF, no CLOAD , RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 17 of 36
2-Feb-2022
SLG59H1005V
Figure 11. Typical Turn OFF operation waveform for VIN = 4.5 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 12. Typical Turn OFF operation waveform for VIN = 9 V, CSLEW = 10 nF, no CLOAD , RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 18 of 36
2-Feb-2022
SLG59H1005V
Figure 13. Typical Turn OFF operation waveform for VIN = 9 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 14. Typical Turn OFF operation waveform for VIN = 12 V, CSLEW = 10 nF, no CLOAD , RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 19 of 36
2-Feb-2022
SLG59H1005V
Figure 15. Typical Turn OFF operation waveform for VIN = 12 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Figure 16. Typical Turn OFF operation waveform for VIN = 20 V, CSLEW = 10 nF, no CLOAD , RLOAD = 100 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 20 of 36
2-Feb-2022
SLG59H1005V
Figure 17. Typical Turn OFF operation waveform for VIN = 20 V, CSLEW = 10 nF, CLOAD = 10 μF, RLOAD = 100 Ω
Typical ACL Operation Waveforms
Figure 18. Typical ACL operation waveform for VIN = 4.5 V, CLOAD = 10 μF, IACL = 1 A, RSET = 91 kΩ
Datasheet
CFR0011-120-01
Revision 1.04
Page 21 of 36
2-Feb-2022
SLG59H1005V
Figure 19. Typical ACL operation waveform for VIN = 9 V, CLOAD = 10 μF, IACL = 1 A, RSET = 91 kΩ
Figure 20. Typical ACL operation waveform for VIN = 12 V, CLOAD = 10 μF, IACL = 1 A, RSET = 91 kΩ
Datasheet
CFR0011-120-01
Revision 1.04
Page 22 of 36
2-Feb-2022
SLG59H1005V
Figure 21. Thermally induced SOA shutdown for VIN = 20 V, CLOAD = 10 μF, IACL = 1 A, RSET = 91 kΩ
Typical SOA Waveforms
Figure 22. Typical SOA waveform during powerup on heavy load for VIN = 9 V, CLOAD = 10 μF, RSET = 30.1 kΩ, RLOAD = 3.8 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 23 of 36
2-Feb-2022
SLG59H1005V
Figure 23. Extended typical SOA waveform during powerup on heavy load for VIN = 9 V, CLOAD = 10 μF,
Figure 24. Typical SOA waveform during powerup on heavy load for VIN = 12 V, CLOAD = 10 μF, RSET = 30.1 kΩ, RLOAD = 3.8 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 24 of 36
2-Feb-2022
SLG59H1005V
Figure 25. Extended typical SOA waveform during powerup on heavy load for VIN = 12 V, CLOAD = 10 μF,
RSET = 30.1 kΩ, RLOAD = 5 Ω
Figure 26. Typical SOA waveform during powerup on heavy load for VIN = 20 V, CLOAD = 10 μF, RSET = 30.1 kΩ, RLOAD = 8 Ω
Datasheet
CFR0011-120-01
Revision 1.04
Page 25 of 36
2-Feb-2022
SLG59H1005V
Figure 27. Extended typical SOA waveform during powerup on heavy load for VIN = 20 V, CLOAD = 10 μF,
Datasheet
CFR0011-120-01
Revision 1.04
Page 26 of 36
2-Feb-2022
SLG59H1005V
Applications Information
High Voltage GreenFET Safe Operating Area Explained
Renesas’s High Voltage GreenFET load switches incorporate a number of internal protection features that prevents them from
damaging themselves or any other circuit or subcircuit downstream of them. One particular protection feature is their Safe
Operation Area (SOA) protection. SOA protection is automatically activated under overpower and, in some cases, under
overcurrent conditions. Overpower SOA is activated if package power dissipation exceeds an internal 5 W threshold longer than
2.5 ms. High Voltage GreenFET devices will quickly switch off (open circuit) upon overpower detection and automatically resume
(close) nominal operation once overpower condition no longer exists.
One possible way to have an overpower condition trigger SOA protection is when High Voltage GreenFET products are enabled
into heavy output resistive loads and/or into large load capacitors. It is under these conditions to follow carefully the “Safe Start-up
Loading” guidance in the Applications section of the datasheet. During an overcurrent condition, High Voltage GreenFET devices
will try to limit the output current to the level set by the external RSET resistor. Limiting the output current, however, causes an
increased voltage drop across the FET’s channel because the FET’s RDSON increased as well. Since the FET’s RDSON is larger,
package power dissipation also increases. If the resultant increase in package power dissipation is higher/equal than 5 W for
longer than 2.5 ms, internal SOA protection will be triggered and the FET will open circuit (switch off). Every time SOA protection
is triggered, all High Voltage GreenFET devices will automatically attempt to resume nominal operation after 160 ms.
Safe Start-up Condition
SLG59H1005V has built-in protection to prevent over-heating during start-up into a heavy load. Overloading the VOUT pin with
a capacitor and a resistor may result in non-monotonic VOUT ramping. In general, under light loading on VOUT, VOUT ramping
can be controlled with CSLEW value. The following equation serves as a guide:
CSLEW =
TRISE
x 4.9 µA x
VIN
3
where
TRISE = Total rise time from 10% VOUT to 90% VOUT
VIN = Input Voltage
CSLEW = Capacitor value for CAP pin
When capacitor and resistor loading on VOUT during start up, the following tables will ensure VOUT ramping is monotonic without
triggering internal protection:
Safe Start-up Loading for VIN = 12 V (Monotonic Ramp)
Slew Rate (V/ms)
CSLEW (nF)2
CLOAD (µF)
RLOAD (Ω)
1
33.3
500
16.7
250
11.1
160
8.3
120
6.7
100
Datasheet
CFR0011-120-01
Revision 1.04
Page 27 of 36
2-Feb-2022
SLG59H1005V
Safe Start-up Loading for VIN = 22 V (Monotonic Ramp)
Slew Rate (V/ms)
CSLEW (nF)2
CLOAD (µF)
RLOAD (Ω)
0.5
66.7
500
80
1.0
33.3
250
80
1.5
22.2
160
80
2.0
16.7
120
80
2.5
13.3
100
80
Note 2: Select the closest-value tolerance capacitor.
Setting the SLG59H1005V’s Active Current Limit
RSET (kΩ)
Active Current Limit (A)3
91
1
45
2
30
3
Note 3: Active Current Limit accuracy is ±15% over voltage range and over temperature range.
Setting the SLG59H1005V’s Input Overvoltage Lockout Threshold
As shown in the table below, SEL[1,0] selects the VIN overvoltage threshold at which the SLG59H1005V’s internal state machine
will turn OFF (open circuit) the power MOSFET if VIN exceeds the selected threshold.
SEL1
SEL0
VIN(OVLO) (Typ)
6V
10.8 V
1
14.4 V
1
1
24 V
For example, SEL[1,1] would be the most appropriate setting for applications where the steady-state VIN can extend up to 20 V
without causing any damage to the SLG59H1005V since the IC is 29-V tolerant.
With an activated SLG59H1005V (ON=HIGH) and at any time VIN crosses the programmed VIN overvoltage threshold, the state
machine opens the load switch and asserts the FAULT pin within TFAULTLOW.
In applications with a deactivated or inactive SLG59H1005V (VIN > VIN(UVLO) and ON=LOW) and if the applied VIN is higher than
the programmed VIN(OVLO) threshold, the SLG59H1005V’s state machine will keep the load switch open circuited if the ON pin
is toggled LOW-to-HIGH. In these cases, the FAULT pin will also be asserted within TFAULTLOW and will remain asserted until
VIN resumes nominal, steady-state operation.
In all cases, the SLG59H1005V’s VIN undervoltage lockout threshold is fixed at VIN(UVLO).
Datasheet
CFR0011-120-01
Revision 1.04
Page 28 of 36
2-Feb-2022
SLG59H1005V
Power Dissipation
The junction temperature of the SLG59H1005V depends on different factors such as board layout, ambient temperature, and
other environmental factors. The primary contributor to the increase in the junction temperature of the SLG59H1005V is the power
dissipation of its power MOSFET. Its power dissipation and the junction temperature in nominal operating mode can be calculated
using the following equations:
PD = RDSON x IDS2
where:
PD = Power dissipation, in Watts (W)
RDSON = Power MOSFET ON resistance, in Ohms (Ω)
IDS = Output current, in Amps (A)
and
TJ = PD x θJA + TA
where:
TJ = Junction temperature, in Celsius degrees (°C)
θJA = Package thermal resistance, in Celsius degrees per Watt (°C/W)
TA = Ambient temperature, in Celsius degrees (°C)
In current-limit mode, the SLG59H1005V’s power dissipation can be calculated by taking into account the voltage drop across
the load switch (VIN-VOUT) and the magnitude of the output current in current-limit mode (IACL):
PD = (VIN-VOUT) x IACL or
PD = (VIN – (RLOAD x IACL)) x IACL
where:
VIN = Input Voltage, in Volts (V)
RLOAD = Load Resistance, in Ohms (Ω)
IACL = Output limited current, in Amps (A)
VOUT = RLOAD x IACL
Datasheet
CFR0011-120-01
Revision 1.04
Page 29 of 36
2-Feb-2022
SLG59H1005V
Layout Guidelines:
1. Since the VIN and VOUT pins dissipate most of the heat generated during high-load current operation, it is highly recommended
to make power traces as short, direct, and wide as possible. A good practice is to make power traces with absolute minimum
widths of 15 mils (0.381 mm) per Ampere. A representative layout, shown in Figure 28, illustrates proper techniques for heat
to transfer as efficiently as possible out of the device;
2. To minimize the effects of parasitic trace inductance on normal operation, it is recommended to connect input CIN and output
CLOAD low-ESR capacitors as close as possible to the SLG59H1005V's VIN and VOUT pins;
3. The GND pin should be connected to system analog or power ground plane.
4. 2 oz. copper is recommended for high current operation.
SLG59H1005V Evaluation Board:
А High Voltage GreenFET Evaluation Board for SLG59H1005V is designed according to the statements above and is illustrated
on Figure 28. Please note that evaluation board has D_Sense and S_Sense pads. They cannot carry high currents and dedicated
only for RDSON evaluation.
Figure 28. SLG59H1005V Evaluation Board
Datasheet
CFR0011-120-01
Revision 1.04
Page 30 of 36
2-Feb-2022
SLG59H1005V
GND
1
1
IOUT/POUT
1
R5
10k
R3
30.1k
C4
10nF
R4
N.P.
R2
100k
R1
84.5k
PDS/CAP FAULT#
1
GND
1
GND
1
1
2
3
SEL1
1
2
3
ON
R6
5V1
SEL0
1
2
3
C3
180pF
U1
D_SENSE
CAP Array
DRAIN
1
3
5
7
9
2
4
6
8
10
1
C2
2 2u F
1
C5
2 2u F
ON
SEL0
GND
VIN
VIN
VIN
VIN
VIN
18
17
16
15
14
13
12
11
10
9
1
1
C1
4 7 uF
1
2
3
4
5
6
7
8
RSET
IOUT
CAP
FAULT
SEL1
VOUT
VOUT
VOUT
VOUT
VOUT
SOURCES_SENSE
1
2
3
4
1
2
3
4
GND
D/VIN
GND
1
2
3
4
1
2
3
4
RSET Array
S/VOUT
1
3
5
7
9
2
4
6
8
10
Figure 29. SLG59H1005V Evaluation Board Connection Circuit
Basic Test Setup and Connections
Figure 30. SLG59H1005V Evaluation Board Connection Circuit
EVB Configuration
1. Based on VIN voltage, set SEL0, SEL1 to GND or 5 V to configure OVLO;
2. Connect oscilloscope probes to D/VIN, S/VOUT, ON, etc.;
3. Turn on Power Supply and set desired VIN from 4.5 V…22 V range;
4 .Toggle the ON signal High or Low to observe SLG59H1005V operation.
Datasheet
CFR0011-120-01
Revision 1.04
Page 31 of 36
2-Feb-2022
SLG59H1005V
Package Top Marking System Definition
Pin 1 Identifier
1005V
WWNNN
ARR
Part Code
Date Code + LOT Code
Assembly + Rev. Code
1005V - Part ID Field
WW - Date Code Field1
NNN - Lot Traceability Code Field1
A - Assembly Site Code Field 2
RR - Part Revision Code Field2
Note 1: Each character in code field can be alphanumeric A-Z and 0-9
Note 2: Character in code field can be alphabetic A-Z
Datasheet
CFR0011-120-01
Revision 1.04
Page 32 of 36
2-Feb-2022
SLG59H1005V
Package Drawing and Dimensions
18 Lead TQFN Package 1.6 x 3 mm (Fused Lead)
JEDEC MO-220, Variation WCEE
Datasheet
CFR0011-120-01
Revision 1.04
Page 33 of 36
2-Feb-2022
SLG59H1005V
SLG59H1005V 18-pin STQFN PCB Landing Pattern
Note: All dimensions shown in micrometers (µm)
Datasheet
CFR0011-120-01
Revision 1.04
Page 34 of 36
2-Feb-2022
SLG59H1005V
Tape and Reel Specifications
Max Units
Leader (min)
Nominal
Reel &
Package # of
Package Size
Hub Size
Length
Type
Pins
per Reel per Box
Pockets
[mm]
[mm]
[mm]
STQFN
18L
1.6x3mm
0.4P FC
Green
18
1.6 x 3 x 0.55
3,000
3,000
178 / 60
100
400
Trailer (min)
Pockets
Length
[mm]
Tape
Width
[mm]
100
400
8
Part
Pitch
[mm]
4
Carrier Tape Drawing and Dimensions
Package
Type
Pocket BTM Pocket BTM
Length
Width
STQFN 18L
1.6x3mm
0.4P FC
Green
Pocket
Depth
Index Hole
Pitch
Pocket
Pitch
Index Hole
Diameter
Index Hole Index Hole
to Tape
to Pocket Tape Width
Edge
Center
A0
B0
K0
P0
P1
D0
E
F
W
1.78
3.18
0.76
4
4
1.5
1.75
3.5
8
Refer to EIA-481 specification
Recommended Reflow Soldering Profile
Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 2.64 mm3 (nominal). More
information can be found at www.jedec.org.
Datasheet
CFR0011-120-01
Revision 1.04
Page 35 of 36
2-Feb-2022
SLG59H1005V
Revision History
Date
Version
2/2/2022
1.04
Updated Company name and logo
Added SOA Protection Threshold to Features
Fixed typos
12/21/2018
1.03
Updated style and formatting
Updated Charts
Added Scope shots
Added Layout Guidelines
Fixed typos
4/19/2017
1.02
Updated Block Diagram
Updated Charts
Updated SOA operation Timing Diagrams
3/21/2017
1.01
Updated Features
2/24/2017
1.00
Production Release
Datasheet
CFR0011-120-01
Change
Revision 1.04
Page 36 of 36
2-Feb-2022
IMPORTANT NOTICE AND DISCLAIMER
RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL
SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING
REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND
OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED,
INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible
for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3)
ensuring your application meets applicable standards, and any other safety, security, or other requirements. These
resources are subject to change without notice. Renesas grants you permission to use these resources only for
development of an application that uses Renesas products. Other reproduction or use of these resources is strictly
prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property.
Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims,
damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject
to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources
expands or otherwise alters any applicable warranties or warranty disclaimers for these products.
(Rev.1.0 Mar 2020)
Corporate Headquarters
Contact Information
TOYOSU FORESIA, 3-2-24 Toyosu,
Koto-ku, Tokyo 135-0061, Japan
www.renesas.com
For further information on a product, technology, the most
up-to-date version of a document, or your nearest sales
office, please visit:
www.renesas.com/contact/
Trademarks
Renesas and the Renesas logo are trademarks of Renesas
Electronics Corporation. All trademarks and registered
trademarks are the property of their respective owners.
© 2021 Renesas Electronics Corporation. All rights reserved.
