SLG59M1527V
SLG59M1527V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN14
    IC PWR SWITCH N-CHAN 1:1 14STDFN
SLG59M1527V 数据手册
 SLG59M1527V Dual 4.5 A Load Switch General Description Pin Configuration The SLG59M1527V is designed for load switching application. The part comes with two 4.5 A rated MOSFETs switched on by two ON control pins. Each MOSFETs turn on time is independently adjusted by an external capacitor. Features • • • • • • • D1 1 14 D1 2 13 S1 S1 ON1 3 12 CAP1 4 11 GND ON2 5 10 CAP2 D2 6 9 D2 7 8 S2 S2 VDD Two 4.5 A independent MOSFETs Two Integrated VGS Charge Pumps Two internal discharges per channel for gate and source Independent Ramp Control Protected by thermal shutdown with current limit Pb-Free / RoHS Compliant Halogen-Free • STDFN-14L, 1 x 3 x 0.55 mm 14-pin STDFN (Top View) Applications • • • • Ideal for switching ON and OFF S0 +5.0 and 3.3 V power rails with associated support circuitry discharges. Ideal for switching ON and OFF power rails 5 V or less. Can use either channel up to 4.5 A with combined maximum current of 8.5 A Maximum load capacitance of 1000 µF for each Channel Source terminal. Block Diagram 4.5A VDD D1 4.5A S1 Charge Pump D2 Charge Pump Out ON1 CMOS Input ON2 CMOS Input GND S2 Out CAP1 CSLEW CAP2 CSLEW Do not probe CAP1 (PIN 12) or CAP2 (PIN 10) with low impedance probe. Datasheet CFR0011-120-01 Revision 1.06 Page 1 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Pin Description Pin # Pin Name Type Pin Description 1, 2 D1 MOSFET Drain/Input terminal of Power MOSFET Channel 1. Connect a 10 μF (or larger) low ESR capacitor from this pin to GND. Capacitors used at D1 should be rated at 10 V or higher. 3 ON1 Input A low-to-high transition on this pin closes the Channel 1 of load switch. ON1 is an asserted-HIGH, level-sensitive CMOS input with ON_VIL < 0.3 V and ON_VIH > 0.85 V. Connect this pin to the output of a general-purpose output (GPO) from a microcontroller or other application processor. While there is an internal pull down circuit to ground (~4 MΩ), it is allowed this pin to be open-circuited. 4 VDD VDD VDD supplies the power for the operation of the load switch and internal control circuitry where its range is 2.5 V ≤ VDD ≤ 5.5 V. Bypass the VDD pin to GND with a 0.1 μF (or larger) capacitor. 5 ON2 Input A low-to-high transition on this pin closes the Channel 2 of load switch. ON2 is an asserted-HIGH, level-sensitive CMOS input with ON_VIL < 0.3 V and ON_VIH > 0.85 V. Connect this pin to the output of a general-purpose output (GPO) from a microcontroller or other application processor. While there is an internal pull down circuit to ground (~4 MΩ), it is allowed this pin to be open-circuited. 6, 7 D2 MOSFET Drain/Input terminal of Power MOSFET Channel 2. Connect a 10 μF (or larger) low ESR capacitor from this pin to GND. Capacitors used at D2 should be rated at 10 V or higher. 8, 9 S2 MOSFET Source/Output terminal of Power MOSFET Channel 2. Connect a 10 μF (or larger) low ESR capacitor from this pin to GND. Capacitors used at S2 should be rated at 10 V or higher. 10 CAP2 Input A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP2 pin to GND, sets the VS2 slew rate and overall turn on time of the SLG59M1527V. For best performance, the range for CSLEW values are 1 nF ≤ CSLEW ≤ 22 nF. Capacitors used at the CAP2 pin should be rated at 10V or higher. 11 GND GND Ground connection. Connect this pin to system analog or power ground plane. 12 CAP1 Input A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP1 pin to GND, sets the VS1 slew rate and overall turn on time of the SLG59M1527V. For best performance, the range for CSLEW values are 1 nF ≤ CSLEW ≤ 22 nF. Capacitors used at the CAP1 pin should be rated at 10V or higher. 13, 14 S1 MOSFET Source/Output terminal of Power MOSFET Channel 1. Connect a 10 μF (or larger) low ESR capacitor from this pin to GND. Capacitors used at S1 should be rated at 10 V or higher. Ordering Information Part Number Type Production Flow SLG59M1527V STDFN-14L Industrial, -40 °C to 85 °C SLG59M1527VTR STDFN-14L (Tape and Reel) Industrial, -40 °C to 85 °C Datasheet CFR0011-120-01 Revision 1.06 Page 2 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Absolute Maximum Ratings Parameter Description VDD Power Supply Voltage TS Storage Temperature ESDHBM WDIS IDSMAX ESD Protection Conditions Human Body Model Min. Typ. Max. Unit -- -- 6 V -65 -- 150 °C 2000 -- -- V -- -- 1.2 W 4.5 A 6 A Package Power Dissipation Max Continuous Switch Current MOSFET IDSPK Peak Current from Drain to Source For no more than 10 continuous seconds out of every 100 seconds -- -- Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C, unless otherwise noted. Typical values are at TA = 25 °C Parameter VDD IDD RDSON[1,2] MOSFET IDS VD[1,2] TON_Delay Description Conditions Power Supply Voltage Typ. Max. Unit 2.5 -- 5.5 V Power Supply Current when OFF -- 0.1 1 μA Power Supply Current, both channels when ON, no Load -- 50 75 μA TA = 25 °C; IDS = 100 mA -- 14.5 18 mΩ TA = 70 °C; IDS = 100 mA -- 17 22 mΩ TA = 85 °C; IDS = 100 mA -- 18 23 mΩ TA = 85 °C; IDS = 4.5 A -- 19.3 25.1 mΩ Continuous -- -- 4.5 A 0.9 -- VDD V -- 300 500 μs ON Resistance Current from D[1,2] to S[1,2] Load Switch input Voltage ON Delay Time 50% ON to VS[1,2] Ramp Start 50% ON to 90% VS[1,2] TTotal_ON Min. Total Turn On Time Example: CSLEW = 4 nF, VDD = VD[1,2] = 5 V; CLOAD = 10 μF; RLOAD = 20 Ω 10% VS to 90% VS Set by External CSLEW -- 2.0 1 -- Set by External CSLEW 1 ms ms V/ms VS(SR) VS[1,2] Slew Rate Example: CSLEW = 4 nF, VDD = VD[1,2] = 5 V; CLOAD = 10 μF; RLOAD = 20 Ω -- 3.0 -- V/ms CLOAD Output Load Capacitance CLOAD connected from S[1,2] to GND -- -- 1000 μF RDISCHRG Output Discharge Resistance VDD = 2.5 V to 5.5 V; VS[1,2] = 0.4 V Input bias 100 150 300 Ω ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V Datasheet CFR0011-120-01 Revision 1.06 Page 3 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Electrical Characteristics (continued) TA = -40 °C to 85 °C, unless otherwise noted. Typical values are at TA = 25 °C Parameter Description Conditions Min. Typ. Max. Unit Active Current Limit, IACL MOSFET will automatically limit current when VS[1,2] > 250 mV -- 6.0 -- A Short Circuit Current Limit, ISCL MOSFET will automatically limit current when VS[1,2] < 250 mV -- 0.5 -- A Thermal shutoff turn-on temperature -- 125 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C THERMTIME Thermal shutoff time -- -- 1 ms -- -- 15 μs ILIMIT THERMON TOFF_Delay 50% ON to VS[1,2] Fall Start; VDD = VD[1,2] = 5 V OFF Delay Time Notes: 1. Refer to typical Timing Parameter vs. CSLEW performance charts for additional information when available. TON_Delay, VS(SR), and TTotal_ON Timing Details ON[1,2]* 50% ON 50% ON TOFF_Delay 90% VS VS[1,2] 90% VS TON_Delay 10% VS 10% VS VS(SR) (V/ms) TFALL TTotal_ON *Rise and Fall Times of the ON Signal are 100 ns Datasheet CFR0011-120-01 Revision 1.06 Page 4 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Slew Rate vs. CSLEW TTotal_ON vs. CSLEW Datasheet CFR0011-120-01 Revision 1.06 Page 5 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch RDSON[1,2] vs. IDS @ TA = 85 °C SLG59M1527V Power-Up/Power-Down Sequence Considerations To ensure glitch-free power-up under all conditions, apply VDD first, followed by VD[1,2] after VDD exceeds 1 V. Then allow VD[1,2] to reach 90% of its max value before toggling the ON pin from Low-to-High. Likewise, power-down in reverse order. If VDD and VD[1,2] need to be powered up simultaneously, glitching can be minimized by having a suitable load capacitor. A 10 μF CLOAD will prevent glitches for rise times of VDD and VD[1,2] higher than 2 ms. If the ON pin is toggled HIGH before VDD and VD[1,2] have reached their steady-state values, the load switch timing parameters may differ from datasheet specifications. The slew rate of output VS[1,2] follows a linear ramp set by a capacitor connected to the CAP pin. A larger capacitor value at the CAP pin produces a slower ramp, reducing inrush current from capacitive loads. SLG59M1527V Current Limiting The SLG59M1527V has two modes of current limiting, differentiated by the output (Source pin) voltage. 1. Standard Current Limiting Mode (with Thermal Protection) When VS[1,2] > 250 mV, the output current is initially limited to the Active Current Limit specification given in the Electrical Characteristics table. The current limiting circuit is very fast and responds within a few micro-seconds to sudden loads. When overload is sensed, the current limiting circuit increases the FET resistance to keep the current from exceeding the Active Current Limit. Datasheet CFR0011-120-01 Revision 1.06 Page 6 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch However, if an overload condition persists, the die temperature rise due to the increased FET resistance while at maximum current can activate Thermal Protection. If the die temperature exceeds the THERMON specification, the FET is shut completely OFF, allowing the die to cool. When the die cools to the THERMOFF temperature, the FET is allowed to turn back on. This process may repeat as long as the overload condition is present. 2. Short Circuit Current Limiting Mode (with Thermal Protection) When VS[1,2] < 250 mV (which is the case with a hard short, such as a solder bridge on the power rail), the current is limited to approximately 500 mA. Thermal Protection is also present, but since the Short Circuit Current Limit is much lower than Standard Current Limit, activation may only occur at higher ambient temperatures. Power Dissipation The junction temperature of the SLG59M1527V depends on factors such as board layout, ambient temperature, external air flow over the package, load current, and the RDSON-generated voltage drop across each power MOSFET. While the primary contributor to the increase in the junction temperature of the SLG59M1527V is the power dissipation of its power MOSFETs, its power dissipation and the junction temperature in nominal operating mode can be calculated using the following equations: PDTOTAL = (RDSON1 x IDS12) + (RDSON2 x IDS22) where: PDTOTAL = Total package power dissipation, in Watts (W) RDSON[1,2] = Channel 1 and Channel 2 Power MOSFET ON resistance, in Ohms (Ω), respectively IDS[1,2] = Channel 1 and Channel 2 Output current, in Amps (A), respectively and TJ = PDTOTAL x θJA + TA Power Dissipation (continued) where: TJ = Die junction temperature, in Celsius degrees (°C) θJA = Package thermal resistance, in Celsius degrees per Watt (°C/W) – highly dependent on pcb layout TA = Ambient temperature, in Celsius degrees (°C) In nominal operating mode, the SLG59M1527V’s power dissipation can also be calculated by taking into account the voltage drop across each switch (VDx-VSx) and the magnitude of that channel’s output current (IDSx): PDTOTAL = [(VD1-VS1) x IDS1] + [(VD2-VS2) x IDS2] or PDTOTAL = [(VD1 – (RLOAD1 x IDS1)) x IDS1] + [(VD2 – (RLOAD2 x IDS2)) x IDS2] where: PDTOTAL = Total package power dissipation, in Watts (W) VD[1,2] = Channel 1 and Channel 2 Input Voltage, in Volts (V), respectively RLOAD[1,2] = Channel 1 and Channel 2 Output Load Resistance, in Ohms (Ω), respectively IDS[1,2] = Channel 1 and Channel 2 output current, in Amps (A), respectively VS[1,2] = Channel 1 and Channel 2 output voltage, or RLOAD[1,2] x IDS[1,2] , respectively For more information on GreenFET load switch features, please visit our website and see App Note “AN-1068 GreenFET and High Voltage GreenFET Load Switch Basics”. Datasheet CFR0011-120-01 Revision 1.06 Page 7 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Layout Guidelines: 1. The VDD pin needs a 0.1µF (or larger) external capacitor to smooth pulses from the power supply. Locate this capacitor as close as possible to the SLG59M1527V's pin 4. 2. Since the D1, D2, S1 and S2 pins dissipate most of the heat generated during high-load current operation, it is highly recommended to make power traces as short, direct, and wide as possible. A good practice is to make power traces with an absolute minimum widths of 15 mils (0.381 mm) per Ampere. A representative layout, shown in Figure 1, illustrates proper techniques for heat to transfer as efficiently as possible out of the device; 3. To minimize the effects of parasitic trace inductance on normal operation, it is recommended to connect input CIN and output CLOAD low-ESR capacitors as close as possible to the SLG59M1527V's D1, D2, S1 and S2 pins; 4. The GND pin should be connected to system analog or power ground plane. 5. 2 oz. copper is recommended for high current operation. SLG59M1527V Evaluation Board: А GreenFET Evaluation Board for SLG59M1527V is designed according to the statements above and is illustrated on Figure 1. Please note that evaluation board has D_Sense and S_Sense pads. They cannot carry high currents and dedicated only for RDSON evaluation. Please solder your SLG59M1527V here Figure 1. SLG59M1527V Evaluation Board Datasheet CFR0011-120-01 Revision 1.06 Page 8 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch 1 2 3 4 5 Dual 1 1 VDD C1 10 9 8 7 6 VDD CAP2 GND CAP1 ON1 S2 ON2 S1 D1 D2 CAP Array 1 C2 100nF S Sense1.1 1 D Sense1.1 1 D Sense1.2 1 R2_Array 1 3 5 7 9 ON2 2 4 6 8 10 U1 1 2 3 4 5 6 7 D1 D1 ON1 VDD ON2 D2 D2 1 3 5 7 9 S1 S1 CAP1 GND CAP2 S2 S2 14 13 12 11 10 9 8 2 4 6 8 10 CAP Array 2 1 3 5 7 9 S Sense1.2 1 C3 2 4 6 8 10 C5 C7 100nF D Sense2.2 1 3 2 1 U2 1 2 3 4 D Sense2.1 1 VIN2 ON2 ON1 VIN1 VOUT2 GND NC VOUT1 RL1 S Sense2.2 1 S Sense2.1 1 RL2 C4 RL1 8 7 6 5 RL2 C6 ON4 D1 3 2 1 3 2 1 D1 S1 S1 S2 1 1 1 1 1 1 D2 S2 1 1 2 3 4 5 D Sense3 1 2 3 4 5 Quad V_IN GND ON1 ON2 ON3 V4_OUT V3_OUT V2_OUT V1_OUT ON4 U3 VO1 ON1 ON2 VO2 VIN GND VO4 ON4 ON3 VO3 S Sense3.1 10 9 8 7 6 1 S Sense3.2 1 S Sense3.3 1 1 10 9 8 7 6 VO3 S Sense3.4 1 ON3 D2 1 ON1 2 4 6 8 10 1 1 3 5 7 9 1 R1_Array VO4 RL3 C8 RL4 C9 3 2 1 Figure 2. SLG59M1527V Evaluation Board Connection Circuit Datasheet CFR0011-120-01 Revision 1.06 Page 9 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Basic Test Setup and Connections Figure 3. SLG59M1527V Evaluation Board Connection Circuit EVB Configuration 1. Connect oscilloscope probes to D1/VIN, D2, S1/VO1, S2/VO2, ON1, ON2 etc.; 2. Turn on Power Supply 1 and set desired VDD from 2.5 V…5.5 V range; 3. Turn on Power Supply 2, 3 and set desired VD[1,2] from 0.9 V…VDD range; 4. Toggle the ON[1,2] signal High or Low to observe SLG59M1527V operation. Datasheet CFR0011-120-01 Revision 1.06 Page 10 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Package Top Marking System Definition Part Code Pin 1 Identifier PPDDL Lot # Date Code Part Number: SLG59M1527V Production Part Code: KU Datasheet CFR0011-120-01 Revision 1.06 Page 11 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Package Drawing and Dimensions 14 Lead STDFN Package 1 mm x 3 mm (Fused Lead) Datasheet CFR0011-120-01 Revision 1.06 Page 12 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Tape and Reel Specifications Package Type # of Pins Nominal Package Size Units per Reel STDFN 14L 14 1x3x0.55mm 3000 Trailer A Leader B Pocket Tape (mm) Max Reel & Units Hub Size Length Length Pockets Pockets Width Pitch per Box (mm) (mm) (mm) 3000 178/60 100 400 100 400 8 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Length Width Package [mm] [mm] Type STDFN 14L Pocket Depth [mm] Index Hole Pitch [mm] Pocket Pitch [mm] Index Hole Diameter [mm] Index Hole Index Hole to Tape to Pocket Tape Width Edge Center [mm] [mm] [mm] A0 B0 K0 P0 P1 D0 E F W 1.15 3.15 0.7 4 4 1.5 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 1.65 mm3 (nominal). More information can be found at www.jedec.org. Datasheet CFR0011-120-01 Revision 1.06 Page 13 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1527V Dual 4.5 A Load Switch Revision History Date Version 2/3/2022 1.06 Updated Company name and logo Fixed typos 12/10/18 1.05 Updated style and formatting Updated Charts Added Layout Guidelines 3/17/16 1.04 Added RDSon @ 4.5 A Added Application Notes Added RDSon vs IDS chart 12/15/15 1.03 Added Marking Information 4/20/14 1.02 Updated Block Diagram to separate CAP and OUT lines from Charge Pump 10/8/14 1.01 Updated VD Min from 1.0 V to 0.9 V 4/21/14 1.0 Production Release Datasheet CFR0011-120-01 Change Revision 1.06 Page 14 of 14 3-Feb-2022 ©2022 Renesas Electronics Corporation IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1527V 价格&库存
很抱歉,暂时无法提供与“SLG59M1527V”相匹配的价格&库存,您可以联系我们找货
