DATA SHEET
Power Entry Module with EMC- Filter FN280
Compact filtered power entry module
Complies with IEC/EN 60601-1
Approvals & Compliances
Rated currents up to 10 A
Single or dual-fuse holder
Fuses Ø5 x 20 mm
2-pole rocker switch
General purpose application
Optional earth line choke (E type)
Optional medical versions (B type)
(CQC except HI-types)
Features and Benefits
High conducted attenuation performance, based
on chokes with high saturation resistance and
excellent thermal behavior
Rear/front or snap-in mounting
Performance indicators
Custom-specific versions are available on request
Typical Applications
Portable electrical and electronic equipment
Consumer goods
EDP and office equipment
Single-phase power supplies, switch-mode power
supplies
Test and measurement equipment
Medical equipment
Technical Specifications
Typical electrical schematic
Maximum continuous operating voltage
250 VOLT, 50/60 Hz
Operating frequency
DC to 400 Hz
Rated currents
1 to 10 A @ 40°C max
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec
Protection category
IP 40 according to IEC 60529
Temperature range (operation and storage)
-25°C to +85°C (25/85/21)
Design corresponding to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
Flammability corresponding to
UL 94 V-2 or better
MTBF @ 40°C/230 V (Mil-HB-217F)
1,500,000 hours
Fuse holder
1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6),
power acceptance 1.6W @ Ta 23°C per pole for 2 fuses.
2.5W, if only 1 pole is used.
Marking
) Marking max. 250 V ~ (text is print. below fuse symbol)
Rocker switch description
Function
2-pole, dark not illuminated
Marking I - 0
Electrical specifications
Inrush current 82 A
6,000 on-off operations according to UL 1054, TV5
10,000 on-off operations according to ENEC
Switch ratings
USA (UL) and Canada (C-UL)
10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP
Europe (ENEC)
10 A (4 A), 250 VAC*
Mechanical life
50,000 cycles
Value in () relates to the inductive current charge: cosφ = 0.65
2
Schaffner Group
DATA SHEET
24. Nov
2022
Filter Selection Table
Filter
Rated current
Leakage current*
@ 40°C (25°C)
@ 230 VAC/50 Hz
L1
L2
Cx
[A]
[μA]
[mH]
[mH]
[nF]
FN 281-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
FN 281-2-06
2 (2.4)
373
2
220
2.2
1000
FN 281-4-06
4 (4.8)
373
1
220
2.2
1000
FN 281-6-06
Inductance**
Capacitance**
Resistance**
Output
Fuses***
Weight
Cy
R
connections
[nF]
[kΩ]
[Qty]
[g]
1
90
-06
1
90
-06
1
90
6 (7.2)
373
0.45
220
2.2
1000
-06
1
90
10 (11.6)
373
0.34
220
2.2
1000
-06
1
90
FN 282-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
2
90
FN 282-2-06
2 (2.4)
373
2
220
2.2
1000
-06
2
90
FN 282-4-06
4 (4.8)
373
1
220
2.2
1000
-06
2
90
FN 281-10-06
FN 282-6-06
6 (7.2)
373
0.45
220
2.2
1000
-06
2
90
10 (11.6)
373
0.34
220
2.2
1000
-06
2
90
FN 283-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
1
90
FN 283-2-06
2 (2.4)
373
2
220
2.2
1000
-06
1
90
FN 283-4-06
4 (4.8)
373
1
220
2.2
1000
-06
1
90
FN 283-6-06
6 (7.2)
373
0.45
220
2.2
1000
-06
1
90
10 (11.6)
373
0.34
220
2.2
1000
-06
1
90
FN 284-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
2
90
FN 284-2-06
2 (2.4)
373
2
220
2.2
1000
-06
2
90
FN 284-4-06
4 (4.8)
373
1
220
2.2
1000
-06
2
90
FN 284-6-06
6 (7.2)
373
0.45
220
2.2
1000
-06
2
90
10 (11.6)
373
0.34
220
2.2
1000
-06
2
90
FN 285-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
1
90
FN 285-2-06
2 (2.4)
373
2
220
2.2
1000
-06
1
90
FN 285-4-06
4 (4.8)
373
1
220
2.2
1000
-06
1
90
FN 282-10-06
FN 283-10-06
FN 284-10-06
FN 285-6-06
6 (7.2)
373
0.45
220
2.2
1000
-06
1
90
10 (11.6)
373
0.34
220
2.2
1000
-06
1
90
FN 286-1-06
1 (1.2)
373
7.5
220
2.2
1000
-06
2
90
FN 286-2-06
2 (2.4)
373
2
220
2.2
1000
-06
2
90
FN 286-4-06
4 (4.8)
373
1
220
2.2
1000
-06
2
90
FN 285-10-06
FN 286-6-06
6 (7.2)
373
0.45
220
2.2
1000
-06
2
90
FN 286-10-06
10 (11.6)
373
0.34
220
2.2
1000
-06
2
90
FN 283 E-1-06
1 (1.2)
373
7.5
0.4
220
2.2
1000
-06
1
100
FN 283 E-2-06
2 (2.4)
373
2
0.4
220
2.2
1000
-06
1
100
FN 283 E-4-06
4 (4.8)
373
1
0.4
220
2.2
1000
-06
1
100
FN 283 E-6-06
6 (7.2)
373
0.45
0.4
220
2.2
1000
-06
1
100
FN 284 E-1-06
1 (1.2)
373
7.5
0.4
220
2.2
1000
-06
2
100
FN 284 E-2-06
2 (2.4)
373
2
0.4
220
2.2
1000
-06
2
100
FN 284 E-4-06
4 (4.8)
373
1
0.4
220
2.2
1000
-06
2
100
FN 284 E-6-06
6 (7.2)
373
0.45
0.4
220
2.2
1000
-06
2
100
FN 282 B-1-06
1 (1.2)
2
7.5
220
1000
-06
2
90
FN 282 B-2-06
2 (2.4)
2
2
220
1000
-06
2
90
FN 282 B-4-06
4 (4.8)
2
1
220
1000
-06
2
90
6 (7.2)
2
0.45
220
1000
-06
2
90
10 (11.6)
2
0.34
220
1000
-06
2
90
FN 282 B-6-06
FN 282 B-10-06
*** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
*** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
*** Filters are delivered without fuse.
3
Schaffner Group
DATA SHEET
24. Nov
2022
Filter
Rated current
Leakage current*
@ 40°C (25°C)
@ 230 VAC/50 Hz
L1
L2
Cx
[A]
[μA]
[mH]
[mH]
[nF]
FN 284 B-1-06
1 (1.2)
2
7.5
220
1000
FN 284 B-2-06
2 (2.4)
2
2
220
1000
FN 284 B-4-06
4 (4.8)
2
1
220
FN 284 B-6-06
Inductance**
Capacitance**
Resistance**
Output
Fuses***
Weight
Cy
R
connections
[nF]
[kΩ]
[Qty]
[g]
-06
2
90
-06
2
90
1000
-06
2
90
6 (7.2)
2
0.45
220
1000
-06
2
90
10 (11.6)
2
0.34
220
1000
-06
2
90
FN 286 B-1-06
1 (1.2)
2
7.5
220
1000
-06
2
90
FN 286 B-2-06
2 (2.4)
2
2
220
1000
-06
2
90
FN 286 B-4-06
4 (4.8)
2
1
220
1000
-06
2
90
FN 286 B-6-06
6 (7.2)
2
0.45
220
1000
-06
2
90
10 (11.6)
2
0.34
220
1000
-06
2
90
FN 284 B-10-06
FN 286 B-10-06
Product selector
For example: FN 281-6-06, FN 283 B-04-06, FN 283 E-1-06
Typical Filter Attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
1 A types
2 to 6 A types
10 A types
4
Schaffner Group
DATA SHEET
24. Nov
2022
Mechanical Data
FN 281/FN 282
FN 283/FN 284
FN 285/FN 286
Panel cut out
Dimensions
FN 281
FN 282
FN 283
FN 284
FN 285
FN 286
Tolerances
A
32
32
50
50
32
32
±0.3
B
82
82
65
65
65
65
±0.3
C
72
72
40
40
D
43.1
43.1
43.1
43.1
43.6
43.6
±0.3
E
28.5
28.5
28.5
28.5
28.5
28.5
±0.25
F
5.5
5.5
5.5
5.5
5
5
±0.3
G
59.95 max.
59.95 max.
59.95 max.
59.95 max.
59.95 max.
59.95 max.
H
Ø3.5
Ø3.5
Ø3.3
Ø3.3
I
13.4
16.2
13.4
16.2
13.9
16.7
J
22.5
22.5
22.5
22.5
22.5
22.5
M
R ≤2.5
R ≤2.5
R ≤2.5
R ≤2.5
R ≤2.5
R ≤2.5
N
60
60
60
60
61.5+0.2/-0*
61.5+0.2/-0*
+0.5/-0
P
29
29
29
29
29
29
+0.5/-0
R
M3
M3
M3
M3
S
90°
90°
90°
90°
* For a panel thickness between 0.8 and 3 mm
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
±0.1
±0.3
5
Schaffner Group
DATA SHEET
24. Nov
2022
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Sales and Application
Centers
China
Schaffner EMC Ltd. Shanghai
T20-3 C No 565 Chuangye Road Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93 Miniparc III Edificio E El
Soto de Moraleja Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tionsw are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780 37FL 98 North-Sathorn Rd Silom
Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN286-4-06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+301.243981+36.53636
- 10+252.5934210+30.63578
- 50+223.4321850+27.09896
- 100+205.93866100+24.97726
- 500+201.29258500+24.41376
- 1000+199.741191000+24.22560
- 2000+198.189812000+24.03744
- 4000+196.646504000+23.85026
