3.5mm Pitch Miniature Double Row Connector for
Secondary Power (Compliant with UL/CSA Standard)
MDF6 Series
Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Inner type positive lock
Mis-insertion protector
Fig.1
■Features
1. Miniature type with 3.5mm pitch
A miniature, space-saving connector with a 3.5mm ∞ 5mm pitch set in a double row alignment configuration.
2. 7A Current Capacity
Despite its small size as a power connector, the current capacity is rated at 7A when using 16 AWG wire.
3. Box Type Header
The box type header is highly resistant to twisting forces and is polarized to prevent mis-insertions.
4. Internal Latch Mechanism
The internal latch mechanism is designed to offer better protection from accidental un-matings and provides for a
reliable and stable connection.
■Applications
Secondary power units for various equipment
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2015.8w
1
MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard)
Product Specifications
16 AWG : 7A
Current rating
Cable Size
(Note 1)
Rating
18 AWG : 6A
Operating Temperature Range
-30 to +85ç (Note2)
Operating Humidity Range
-40 to 80%
Storage Temperature Range
-10 to +60ç (Note3)
Storage Humidity Range
-40 to 70% (Note3)
20 AWG : 5A
22 AWG : 4A
300V AC
Voltage rating
■UL CSA Safety Standard File No.
UL
: E52653
CSA
: LR95109
Standard Value Applicant to the UL CSA Safety Standard
Current rating
Rating
Voltage rating
20 to 22 AWG : 4A
UL : 250V AC, CSA : 30V AC
Item
16 to 18 AWG : 6A
Cable Size
Specifications
Conditions
1. Insulation Resistance
1,000Mø min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
1,500V AC/1 minute
3. Contact Resistance
30mø max.
100mA
4. Single Insertion/Extraction
Force
0.4N(40gf) min., 4.9N(500gf) max.
Measured with a steel pin with dimenions of
1.52 ∞ 0.76 +/-0.002mm
5. Vibration Resistance
No electrical discontinuity of 1μs or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
2 hours in each of the 3 axis directions.
6. Humidity (Steady state)
Contact resistance : 30mø max.
Insulation resistance : 1,000Mø min.
96 hours at temperature of 40±2ç and humidity
of 90% to 95%
7. Temperature Cycle
(-55ç : 30 minutes ➝ 5 to 35ç : 10 minutes
85ç : 30 minutes ➝ 5 to 35ç : 10 minutes) 5 cycles
8. Mating Cycles
Tin/tin-copper plated 30 cycles
9. Resistance to Soldering
heat
No deformation of components affecting
performance.
Flow : 250ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Note 1 : The rated current will change depending on the cable size used. The header rating is only 7A.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range includes non-conducting condition of installed connectors in storage, shipment or during
transportation.
Material / Finish
Product
Part
Crimping Socket
Crimping Contact for Socket
Pin Header
Material
Finish
Remarks
Insulator
Polyamide resin
White (Natural)
UL94V-0
Contact
Phosphor bronze
Tin plating
Insulator
Polyamide resin
White (Natural)
UL94V-0
Contact
Brass
Tin-copper plating
■Product Number Structure
●Connector
MDF6
●Contact
- * DS - 3.5 C
q
q Series Name
w
: MDF 6
w No. of Contacts : 4 to 20
e Connector Type
2
e
r
r Contact Pitch
t
: 3.5mm
t Contact type
C
MDF6 - 1618 SCF
: Crimping socket
DS : Double row socket
DSA : Straight pin header
DP : Double row pin header
DS
: Right angle pin header
q
q Applicable Cable Size
w
w Packaging Type
1618 : 16 to 18 AWG
SCF : Socket Contact, Reel
2022 : 20 to 22 AWG
SC : Socket Contact, Pack
■Double Row Socket
Cavity No. mark
4.2
10.4
8.2
5
A
B
C
P=3.5
14.2
5.5
Photo: With crimp contacts assembled
Part No.
HRS No.
MDF6-4DS-3.5C
MDF6-6DS-3.5C
MDF6-8DS-3.5C
MDF6-10DS-3.5C
MDF6-12DS-3.5C
MDF6-14DS-3.5C
MDF6-16DS-3.5C
MDF6-18DS-3.5C
MDF6-20DS-3.5C
547-0074-1
547-0075-4
547-0076-7
547-0077-0
547-0078-2
547-0079-5
547-0080-4
547-0081-7
547-0082-0
B
C
RoHS
8.1
11.6
15.1
18.6
22.1
25.6
29.1
32.6
36.1
3.5
7.0
10.5
14.0
17.5
21.0
24.5
28.0
31.5
Yes
Polarity mark
Contact No. mark
BCrimp Contact
●Applicable Cable (Tin plating Annealed Copper Wire)
16.3
1.2 2.3
Conductor Size (Wire construction)
16 AWG (26/0.254mm)
18 AWG (34/0.18mm)
20 AWG (21/0.18mm)
22 AWG (17/0.16mm)
2.6
1.4
11.5
Jacket Diameter
Ø2.5 to Ø2.0mm
Ø1.9 to Ø1.5mm
Note : If other cables are used instead of the applicable cable, please
contact Hirose sales department.
2.4
Unit : mm
No. of
Packing
A
Contacts
4
10.5
6
14.0
8
17.5
10
21.0
100pcs/pack 24.5
12
14
28.0
16
31.5
18
35.0
●Recommended Cable
Applicable cable indicated
Part No.
MDF6-1618SCF
MDF6-1618SC
MDF6-2022SCF
MDF6-2022SC
HRS No.
547-0070-0
547-0071-3
547-0072-6
547-0073-9
●Strip Length
UL1061, UL1007
Applicable Cable
AWG Size
Jacket Diameter
16 to 18
2.5 to 2.0
20 to 22
1.9 to 1.5
2.7 to 4.4mm
Packaging Type
RoHS
5,000pcs/reel
100pcs/pack
5,000pcs/reel
100pcs/pack
Yes
BApplicable Crimping Tool
Type
Main press unit
Part No.
HRS No.
Applicable Contact
----------------CM105
901-0005-4
AP105-MDF6-1618S
901-4512-4
MDF6-1618SCF
Applicator
AP105-MDF6-2022S
901-4513-7
MDF6-2022SCF
MDF6-TA1618HC
550-0203-5
MDF6-1618SC
Manual Crimping Tool
MDF6-TA2022HC
550-0204-8
MDF6-2022SC
Extraction Tool
DF-C-PO(A)
550-0170-8
MDF6-****SC(F)
Note : Hirose does not guarantee products if tools other than the ones designed or recommended by Hirose are used.
3
A
B
P=3.5
10.9
5
■Double Row Pin Header:
Straight Type
2.3
5.8
Polarity mark
13
5.6
10.5
0.76×1.52
+0.1
●Applicable Through Hole Diameter of PCB : Ø1.3 +0
3.2
5
2.7
Cavity No. mark
●Applicable Thickness of PCB : 1.6±0.2
Contact No. mark
HRS No.
No. of Contacts
Packing
A
547-0083-2 05
4
10.5
547-0084-5 05
6
14.0
547-0085-8 05
8
17.5
547-0086-0 05
10
21.0
100pcs/pack 24.5
547-0087-3 05
12
547-0088-6 05
14
28.0
547-0089-9 05
16
31.5
547-0090-8 05
18
35.0
547-0091-0 05
2.3
11.3
Unit : mm
RoHS
Yes
A
B
P=3.5
3.5
Right Angle Type
B
3.5
7.0
10.5
14.0
17.5
21.0
24.5
28.0
31.5
5
Part No.
MDF6-4DP-3.5DSA(05)
MDF6-6DP-3.5DSA(05)
MDF6-8DP-3.5DSA(05)
MDF6-10DP-3.5DSA(05)
MDF6-12DP-3.5DSA(05)
MDF6-14DP-3.5DSA(05)
MDF6-16DP-3.5DSA(05)
MDF6-18DP-3.5DSA(05)
MDF6-20DP-3.5DSA(05)
5.8
5.6
10.5
19.95
Polarity mark
0.76×1.52
5
22
3.5
□0.76
+0.1
●Applicable Board Hole Diameter of PCB : Ø1.3 +0
Contact No. mark
Cavity No. mark
□0.76
Part No.
MDF6-4DP-3.5DS(05)
MDF6-6DP-3.5DS(05)
MDF6-8DP-3.5DS(05)
MDF6-10DP-3.5DS(05)
HRS No.
No. of Contacts
Packing
A
547-0270-0 05
4
10.5
547-0271-2 05
6
14.0
100pcs/pack
547-0272-5 05
8
17.5
547-0273-8 05
10
21.0
B
3.5
7.0
10.5
14.0
Unit : mm
RoHS
Yes
4
■Application Pattern
Cable
25.7
3.5
3.5
16.7
13.6
Cable
5.5
5
2.7
2.05
5
14.95
BPrecautions
1. Recommended Soldering Condition
■Flow : 250ç for 10 seconds max.
■Manual soldering : 300ç for 3 seconds max.
2. Cleaning Condition
Please Refer to the "Nylon Connector Use Hand book".
3. Connection Condition
4. Cautions
■The color phase of this product is slightly different from that of the
formed product according to the manufacturing lot and future storage
conditions, but the difference doesn't affect the performance.
5. Precautions
■Please Refer to the "Nylon Connector Use Hand book".
■Please Refer to the documents "Crimp Condition" and "Crimp Quality
Standards" for the cable assembly procedures.
5
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS
2688 Westhills Court, Simi Valley, CA 93065-6235
Phone : +1-805-522-7958
Fax : +1-805-522-3217
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
3255 Scott Boulevard, Building 7, Suite 101
Santa Clara, CA 95054
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE
580 Waters Edge Lane, Suite 205 Lombard IL
60148
Phone : +1-630-282-6701
Mail : inquiries@hirose.com
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253, Livonia,
MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Herzog-Carl-Strasse 4 D-73760 Ostfildern
(Scharnhauser Park)
Phone : +49-711-4560-02-1
Fax : +49-711-4560-02-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE
Muggenhofer Str. 136 90429 Nuernberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
Regus La Garenne Colombes,Place de La Belgique,
71 Boulevard National La Garenne Colombes, 92250, France
Phone : +33 (0) 1 7082 3170
Fax : +33 (1) 7082 3101
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
1601, Henderson Metropolitan, NO.300, East Nanjing
Road, Huangpu District, Shanghai, China 200001
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO., LTD.
250, Huimanggongwon-ro, Siheung-si,
Gyeonggi-do, Korea, 429-849
Phone : +82-31-496-7000,7124
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
10 Anson Road #26-16, International Plaza Office NO.519, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
079903, Singapore
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
1-10-07, Suntech @ Penang Cybercity (1164),Lintang
Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia.
Phone : +604-619-2564
Fax : +604-619-2574
6
THAILAND:
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Phone : +66-2-686-1255
Fax : +66-2-686-3433
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2015. Contents are subject to change without notice for the purpose of improvements.
