MDF6-6DS-3.5C
MDF6-6DS-3.5C
    HRS(广濑)
    P=3.5mm
    CONN SOCKET 6POS 3.5MM CRIMP
MDF6-6DS-3.5C 数据手册
3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) MDF6 Series Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Inner type positive lock Mis-insertion protector Fig.1 ■Features 1. Miniature type with 3.5mm pitch A miniature, space-saving connector with a 3.5mm ∞ 5mm pitch set in a double row alignment configuration. 2. 7A Current Capacity Despite its small size as a power connector, the current capacity is rated at 7A when using 16 AWG wire. 3. Box Type Header The box type header is highly resistant to twisting forces and is polarized to prevent mis-insertions. 4. Internal Latch Mechanism The internal latch mechanism is designed to offer better protection from accidental un-matings and provides for a reliable and stable connection. ■Applications Secondary power units for various equipment In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.8w 1 MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) Product Specifications 16 AWG : 7A Current rating Cable Size (Note 1) Rating 18 AWG : 6A Operating Temperature Range -30 to +85ç (Note2) Operating Humidity Range -40 to 80% Storage Temperature Range -10 to +60ç (Note3) Storage Humidity Range -40 to 70% (Note3) 20 AWG : 5A 22 AWG : 4A 300V AC Voltage rating ■UL CSA Safety Standard File No. UL : E52653 CSA : LR95109 Standard Value Applicant to the UL CSA Safety Standard Current rating Rating Voltage rating 20 to 22 AWG : 4A UL : 250V AC, CSA : 30V AC Item Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 16 to 18 AWG : 6A Cable Size Specifications Conditions 1. Insulation Resistance 1,000Mø min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 1,500V AC/1 minute 3. Contact Resistance 30mø max. 100mA 4. Single Insertion/Extraction Force 0.4N(40gf) min., 4.9N(500gf) max. Measured with a steel pin with dimenions of 1.52 ∞ 0.76 +/-0.002mm 5. Vibration Resistance No electrical discontinuity of 1μs or more Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 axis directions. 6. Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 1,000Mø min. 96 hours at temperature of 40±2ç and humidity of 90% to 95% 7. Temperature Cycle Contact resistance : 30mø max. Insulation resistance : 1,000Mø min. (-55ç : 30 minutes ➝ 5 to 35ç : 10 minutes 85ç : 30 minutes ➝ 5 to 35ç : 10 minutes) 5 cycles 8. Mating Cycles Contact resistance : 30mø max. Tin/tin-copper plated 30 cycles 9. Resistance to Soldering heat No deformation of components affecting performance. Flow : 250ç for 10 seconds Manual soldering : 300ç for 3 seconds Note 1 : The rated current will change depending on the cable size used. The header rating is only 7A. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range includes non-conducting condition of installed connectors in storage, shipment or during transportation. Material / Finish Product Part Crimping Socket Crimping Contact for Socket Pin Header Material Finish Remarks Insulator Polyamide resin White (Natural) UL94V-0 Contact Phosphor bronze Tin plating ––––– Insulator Polyamide resin White (Natural) UL94V-0 Contact Brass Tin-copper plating ––––– ■Product Number Structure ●Connector MDF6 ●Contact - * DS - 3.5 C q q Series Name w : MDF 6 w No. of Contacts : 4 to 20 e Connector Type 2 e r r Contact Pitch t : 3.5mm t Contact type C MDF6 - 1618 SCF : Crimping socket DS : Double row socket DSA : Straight pin header DP : Double row pin header DS : Right angle pin header q q Applicable Cable Size w w Packaging Type 1618 : 16 to 18 AWG SCF : Socket Contact, Reel 2022 : 20 to 22 AWG SC : Socket Contact, Pack MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) ■Double Row Socket Cavity No. mark 4.2 10.4 8.2 5 A B C P=3.5 14.2 5.5 Photo: With crimp contacts assembled Part No. HRS No. MDF6-4DS-3.5C MDF6-6DS-3.5C MDF6-8DS-3.5C MDF6-10DS-3.5C MDF6-12DS-3.5C MDF6-14DS-3.5C MDF6-16DS-3.5C MDF6-18DS-3.5C MDF6-20DS-3.5C 547-0074-1 547-0075-4 547-0076-7 547-0077-0 547-0078-2 547-0079-5 547-0080-4 547-0081-7 547-0082-0 B C RoHS 8.1 11.6 15.1 18.6 22.1 25.6 29.1 32.6 36.1 3.5 7.0 10.5 14.0 17.5 21.0 24.5 28.0 31.5 Yes Polarity mark Contact No. mark BCrimp Contact ●Applicable Cable (Tin plating Annealed Copper Wire) 16.3 1.2 2.3 Conductor Size (Wire construction) 16 AWG (26/0.254mm) 18 AWG (34/0.18mm) 20 AWG (21/0.18mm) 22 AWG (17/0.16mm) 2.6 1.4 11.5 Jacket Diameter Ø2.5 to Ø2.0mm Ø1.9 to Ø1.5mm Note : If other cables are used instead of the applicable cable, please contact Hirose sales department. 2.4 Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm No. of Packing A Contacts 4 10.5 6 14.0 8 17.5 10 21.0 100pcs/pack 24.5 12 14 28.0 16 31.5 18 35.0 20 38.5 ●Recommended Cable Applicable cable indicated Part No. MDF6-1618SCF MDF6-1618SC MDF6-2022SCF MDF6-2022SC HRS No. 547-0070-0 547-0071-3 547-0072-6 547-0073-9 ●Strip Length UL1061, UL1007 Applicable Cable AWG Size Jacket Diameter 16 to 18 2.5 to 2.0 20 to 22 1.9 to 1.5 2.7 to 4.4mm Packaging Type RoHS 5,000pcs/reel 100pcs/pack 5,000pcs/reel 100pcs/pack Yes BApplicable Crimping Tool Type Main press unit Part No. HRS No. Applicable Contact ----------------CM105 901-0005-4 AP105-MDF6-1618S 901-4512-4 MDF6-1618SCF Applicator AP105-MDF6-2022S 901-4513-7 MDF6-2022SCF MDF6-TA1618HC 550-0203-5 MDF6-1618SC Manual Crimping Tool MDF6-TA2022HC 550-0204-8 MDF6-2022SC Extraction Tool DF-C-PO(A) 550-0170-8 MDF6-****SC(F) Note : Hirose does not guarantee products if tools other than the ones designed or recommended by Hirose are used. 3 MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) A B P=3.5 10.9 5 ■Double Row Pin Header: Straight Type 2.3 5.8 Polarity mark 13 5.6 10.5 0.76×1.52 +0.1 ●Applicable Through Hole Diameter of PCB : Ø1.3 +0 3.2 5 2.7 Cavity No. mark ●Applicable Thickness of PCB : 1.6±0.2 Contact No. mark HRS No. No. of Contacts Packing A 547-0083-2 05 4 10.5 547-0084-5 05 6 14.0 547-0085-8 05 8 17.5 547-0086-0 05 10 21.0 100pcs/pack 24.5 547-0087-3 05 12 547-0088-6 05 14 28.0 547-0089-9 05 16 31.5 547-0090-8 05 18 35.0 547-0091-0 05 20 38.5 2.3 11.3 Unit : mm RoHS Yes A B P=3.5 3.5 ■Double Row Pin Header: Right Angle Type B 3.5 7.0 10.5 14.0 17.5 21.0 24.5 28.0 31.5 5 Part No. MDF6-4DP-3.5DSA(05) MDF6-6DP-3.5DSA(05) MDF6-8DP-3.5DSA(05) MDF6-10DP-3.5DSA(05) MDF6-12DP-3.5DSA(05) MDF6-14DP-3.5DSA(05) MDF6-16DP-3.5DSA(05) MDF6-18DP-3.5DSA(05) MDF6-20DP-3.5DSA(05) 5.8 5.6 10.5 19.95 Polarity mark 0.76×1.52 5 22 Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.5 □0.76 +0.1 ●Applicable Board Hole Diameter of PCB : Ø1.3 +0 ●Applicable Thickness of PCB : 1.6±0.2 Contact No. mark Cavity No. mark □0.76 Part No. MDF6-4DP-3.5DS(05) MDF6-6DP-3.5DS(05) MDF6-8DP-3.5DS(05) MDF6-10DP-3.5DS(05) HRS No. No. of Contacts Packing A 547-0270-0 05 4 10.5 547-0271-2 05 6 14.0 100pcs/pack 547-0272-5 05 8 17.5 547-0273-8 05 10 21.0 B 3.5 7.0 10.5 14.0 Unit : mm RoHS Yes 4 MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) ■Application Pattern Cable 25.7 3.5 3.5 16.7 13.6 Cable 5.5 5 2.7 2.05 5 14.95 Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPrecautions 1. Recommended Soldering Condition ■Flow : 250ç for 10 seconds max. ■Manual soldering : 300ç for 3 seconds max. 2. Cleaning Condition Please Refer to the "Nylon Connector Use Hand book". 3. Connection Condition Please Refer to the "Nylon Connector Use Hand book". 4. Cautions ■The color phase of this product is slightly different from that of the formed product according to the manufacturing lot and future storage conditions, but the difference doesn't affect the performance. 5. Precautions ■Please Refer to the "Nylon Connector Use Hand book". ■Please Refer to the documents "Crimp Condition" and "Crimp Quality Standards" for the cable assembly procedures. 5 Aug.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF6 Series●3.5mm Pitch Miniature Double Row Connector for Secondary Power (Compliant with UL/CSA Standard) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6701 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO., LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 429-849 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-16, International Plaza Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India 079903, Singapore Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 6 THAILAND: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2015. Contents are subject to change without notice for the purpose of improvements.
MDF6-6DS-3.5C 价格&库存
很抱歉,暂时无法提供与“MDF6-6DS-3.5C”相匹配的价格&库存,您可以联系我们找货
MDF6-6DS-3.5C
  • 1+0.85840
MDF6-6DS-3.5C
    • 5+10.76739
    MDF6-6DS-3.5C
      • 25+1.10300
      • 50+0.88416
      • 100+0.84039
      • 200+0.78261
      • 800+0.68807
