TAI-TECH
P1
SMD Power Inductor
TMPV0603SV-Series(N)-D
1. Features
1. Low loss realized with low DCR.
2. High performance realized by metal dust core.
3. Ultra low buzz noise, due to composite construction.
Halogen
4. 100% Lead(Pb)-Free and RoHS compliant.
5. High reliability -Reliability test complied to AEC-Q200.
Halogen-free
2. Applications
Automotive applications.
3. Dimensions
Series
Recommend PC Board Pattern
A(mm) A1(mm) B(mm)
TMPV0603SV 7.1±0.3
6.6±0.2
6.6±0.2
C(mm)
D(mm) D1(mm) E(mm)
E1(mm)
2.8±0.2
1.6±0.3
4.3±0.3
1R0
M
N
D
E
F
1.8±0.3
3.0±0.2
4. Part Numbering
TMPV
0603
SV
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F、G: Code
L(mm)
G(mm)
H(mm)
8.4
2.7
3.4
Note: 1.PCB layout is referred to standard IPC-7351B
2. The above PCB layout reference only.
3. Recommend solder paste thickness at
0.15mm and above.
D
G
BxC
Standard.
1R0=1.0uh
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking direction cannot decide polarity.
Marking: Black.1R0 and 2019 (20:YY,19:WW, follow production date).
5. Specification
Part Number
Inductance
L0 A(uH)
±20%
TMPV0603SV-R47MN-D
0.47
TMPV0603SV-1R0MN-D
1.00
TMPV0603SV-1R5MN-D
Heat Rating
Current DC
※ Irms( A )
Saturation
Current DC
I sat ( A )
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
19.0
19.0
3.4
3.74
14.0
14.0
6.0
6.6
1.50
11.5
13.0
10.6
11.7
TMPV0603SV-2R2MN-D
2.20
9.0
10.5
15.0
16.5
TMPV0603SV-3R3MN-D
3.30
7.8
9.5
22.0
24.2
TMPV0603SV-4R7MN-D
4.70
6.4
7.2
29.0
32.0
TMPV0603SV-6R8MN-D
6.80
5.2
6.1
42.0
46.2
TMPV0603SV-8R2MN-D
8.20
4.8
5.6
49.0
54.0
TMPV0603SV-100MN-D
10.0
4.2
4.7
63.0
69.3
TMPV0603SV-150MN-D
15.0
3.7
4.0
100.0
110.0
TMPV0603SV-220MN-D
22.0
2.9
3.0
150.0
165.0
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 165℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components.
Therefore temperature rise should be verified in application conditions.
TAI-TECH
6. Typical Performance Curves
P2
很抱歉,暂时无法提供与“TMPV0603SV-R22MN-D”相匹配的价格&库存,您可以联系我们找货
