SOMDM3730-20-2880AGXR
    BEACONEMBEDDEDWORKS
    DM37x Embedded Module ARM® Cortex®-A8, DM3730 TMS320C64x (DSP) 1GHz 512MB 512MB
SOMDM3730-20-2880AGXR 数据手册
PRODUCT BRIEF Logic PD :: Texas Instruments www.logicpd.com/products DM3730 / AM3703 Torpedo™ SOM System on Module Boasts PC-like speeds up to 1 GHz and low power consumption of less than 5 mW The DM3730 Torpedo SOM is available in several standard configurations, including TI’s Sitara™ AM3703 ARM microprocessor. By remaining footprint compatible with Logic PD’s existing OMAP35x Torpedo SOM, the DM3730 Torpedo SOM extends the roadmaps of existing products and provides an upgrade path from today’s products to future technologies. + Product-ready System on Module with a TI DM3730 or AM3703 ARM® Cortex™-A8 processor running up to 1 GHz + Android, Linux™, and Windows® Embedded CE Board Support Packages (BSPs) + Commercial temp (0˚C to 70˚C) Industrial temp (-40˚C to 85˚C) Extended temp (-40˚C to 70˚C) The Torpedo System on Module (SOM) is an ultra-compact form factor based on Texas Instruments’ DaVinci™ DM3730 and Sitara™ AM3703 processors. The DM3730 Torpedo SOM occupies less than one square inch, but boasts PC-like speeds up to 1 GHz with long battery life. Partnered with such high performance is a startlingly low power consumption of less than 5 mW when in suspend state. This balance of speed and power is accomplished through Logic PD’s vast system design experience; understanding the most detailed workings of each component and their interaction with one another creates a product that operates at optimal efficiency. DM3730 / AM3703 TORPEDO SOM :: HIGHLIGHTS: + Ultra-compact form factor (15 x 27 x 3.8 mm) + Footprint compatible with OMAP35x Torpedo SOM + Long product lifecycle ZOOM™ DM3730 TORPEDO DEVELOPMENT KIT :: FEATURES: + Application baseboard + DM3730 Torpedo SOM DM3730 Torpedo + Wireless SOM DM3730 / AM3703 Torpedo™ SOM *Enlarged to show detail The ultra-compact Torpedo SOM is an ideal offthe-shelf solution for applications in markets where space is a premium. From point-of-care medical devices to hand-held radios to mobile Internet devices, the Torpedo SOM allows for the powerful versatility and compact designs needed in today’s market-changing products. The Zoom™ DM3730 Torpedo Development Kit includes all of the necessary accessories to immediately begin development, helping customers deliver their products to market sooner. + 4.3” WQVGA LCD with 4-wire touchscreen + Wattson™ power measurement application + Necessary accessories to immediately get up and running + See Zoom DM3730 Torpedo Development Kit Product Brief for more information DM3730 / AM3703 Torpedo™ SOM Block Diagram Power HS OTG Audio I/O ADC (x4) Keypad* (4x4) PMIC TPS65950 LED Inductors (x3) Processor PoP technology NAND Flash / mDDR SDRAM DM3730/AM3703 Processor LCD JTAG ETM 40-pin Debug Connector Two 100-pin High Density Connectors 32kHz 26MHz Crystal Oscillator Product Features 27 mm Camera Interface + TMS320C64x DSP core running up to 800 MHz (DM3730 only) 15 mm TOP VIEW :: ACTUAL SIZE I2C Level Shifter TV-out / S-Video + TI DaVinci™ DM3730 or Sitara™ AM3703 ARM® Cortex™-A8 core running up to 1 GHz Memory + Mobile DDR / NAND flash (PoP technology) 256 MB / 512 MB Display + Programmable color LCD controller supports up to a 24 bpp TFT interface ID Chip GPMC 16-bit Bus UARTs (x3) McBSPs (x2) SD / MMC (x3) SPI (x3) / I2C (x2) + POWER SGX™ graphics accelerator (DM3730 only) + Hardware supports XGA 1024x768 at 24-bit color + TV-out / S-Video interface BOTTOM VIEW :: ACTUAL SIZE *optional, not populated by default Camera + Parallel camera interface Audio (Block diagram is not drawn to scale; for reference purposes only.) + I2S compliant audio codec (16-bit stereo DAC, 13-bit ADC) DM3730 / AM3703 Torpedo SOM Ordering Information User Interface Model Number Speed (MHz) SDRAM (MB) NAND Flash (MB) Temp. (°C) + Optional 4x4 keypad interface (requires trade-offs with other features) SOMAM3703-20-1780AGCR 800 256 512 0°–70°2 PC Card Expansion SOMDM3730-20-2780AGCR 1000 256 512 0°–70° + Multiple SD/MMC card support SOMDM3730-20-1780AGIR 800 256 512 -40°–85°3 2 NOTES: 1. Custom configurations are available by special order. Please contact Logic PD Sales for details. 2. Junction temperature of the DM3730/AM3703 processor must stay below 90°C. 3. Junction temperature of the DM3730/AM3703 processor must stay below 105°C. USB + One USB 2.0 high-speed On-the-Go interface Serial I/O + UARTs, SPI, I2C, McBSPs GPIO + Programmable I/O depending on peripheral requirements + General purpose memory controller (GPMC) interface Zoom™ DM3730 Torpedo Development Kit Ordering Information Debug Model Number SOM Configuration Suggested Resale SDK-DM3730-30-256512R SOMDM3730-32-2780AKCR SOMDM3730-20-2780AGCR $997 + 40-pin debug connector on top side of SOM + JTAG & ETM support Software + LogicLoader™ (bootloader/monitor) + Android BSP + Linux™ BSP + Windows® Embedded CE BSP LOGIC PD WEBSITE :: DESIGN RESOURCES: Mechanical 6201 Bury Dr. | Eden Prairie, MN 55346 T : 952.941.8071 F : 952.941.8065 l www.logicpd.com + Logic PD Products : www.logicpd.com/products + 15 mm wide x 27 mm long x 3.8 mm high + Logic PD Technical Support : support.logicpd.com RoHS Compliant © 2018 Logic PD, Inc. All rights reserved. PN: 1018060 Rev G + Logic PD Sales : www.logicpd.com/contact/
SOMDM3730-20-2880AGXR 价格&库存
很抱歉,暂时无法提供与“SOMDM3730-20-2880AGXR”相匹配的价格&库存,您可以联系我们找货
