SOMDM3730-31-2780AKCR
    BEACONEMBEDDEDWORKS
    SYSTEM ON MODULE WIRELESS TORP
SOMDM3730-31-2780AKCR 数据手册
PRODUCT BRIEF Logic PD :: Texas Instruments www.logicpd.com/products DM3730 / AM3703 Torpedo™ + Wireless SOM System on Module AWARDS WON IN 2012: + CONNECT Most Innovative Product + Design News Golden Mousetrap Award WiLink™ 7.0 wireless solution on a single board that is less than one square inch + Embedded Computing Design Top Embedded Innovation DM3730 / AM3703 TORPEDO + WIRELESS SOM :: HIGHLIGHTS: Combine a powerful applications processor with PC-like speeds and a wireless chipset with 802.11a/b/g/n, Bluetooth 4.0/BLE, and GPS support; toss in Android™ and Linux™ BSPs developed using processes compliant with the ISO 13485 medical system standard; and the outcome is an innovative off-the-shelf solution that reduces your development time and risk. The award-winning Torpedo + Wireless System on Module (SOM) is an ultra-compact form factor built around the Texas Instruments (TI) DaVinciTM DM3730 processor or SitaraTM AM3703 parocessor and WiLinkTM 7.0 wireless solution. Confining these two systems to a single board isolates the complex design, manufacturing, and wireless certifications from the rest of your product. The DM3730/AM3703 Torpedo + Wireless SOM occupies less than one square inch, but boasts PC-like speeds up to 1 GHz with long battery life. Partnered with such high performance is a startlingly low power consumption in suspend state. This balance of speed and power is accomplished through Logic PD’s vast system design experience; understanding the most detailed workings of each component and their interaction with one another creates a product that operates at optimal efficiency. + Product-ready System on Module with a TI DM3730 or AM3703 ARM® Cortex™-A8 processor running up to 1 GHz + Android™ & Linux™ Board Support Packages (BSPs) + Wireless connectivity: 802.11a/b/g/n, Bluetooth 4.0/BLE, & GPS DM3730 / AM3703 Torpedo™ + Wireless SOM The WL1283 wireless chipset provides access to all the wireless protocols required in today’s connected world. 802.11a/b/g/n, Bluetooth, and GPS signals are natively integrated with this SOM and with Logic PD BSPs. By using the same connectors as Logic PD’s existing OMAP35x and DM3730/AM3703 Torpedo SOMs, the DM3730/AM3703 Torpedo + Wireless SOM extends the roadmaps of existing products and provides an upgrade path from today’s products to future technologies. The ultra-compact DM3730/AM3703 Torpedo + Wireless SOM is an ideal off-the-shelf solution for applications in markets where wireless connectivity is required and space is a premium. From point-of-care medical products to handheld communication devices, the DM3730/ AM3703 Torpedo + Wireless SOM allows for the powerful versatility and compact designs needed in today’s market-changing products. + FCC & IC modular certified + Industrial, commercial, & extended temp configurations + Ultra-compact form factor (15 x 33 x 3.8 mm installed) + Same connectors as DM3730 / AM3703 Torpedo SOM + Long product lifecycle ZOOM™ DM3730 TORPEDO DEVELOPMENT KIT :: FEATURES: + Application baseboard + DM3730 Torpedo + Wireless SOM DM3730 Torpedo SOM + 4.3” WQVGA LCD with 4-wire touchscreen + Wattson™ power measurement application + Necessary accessories to immediately get up and running DM3730 / AM3703 Torpedo™ + Wireless SOM Block Diagram PMIC TPS65950 LED Inductors (x3) PoP technology NAND Flash / mDDR SDRAM DM3730/AM3703 Processor LCD Camera Interface GPMC 16-bit Bus McBSPs (x2) JTAG ETM ID Chip SD / MMC (x2) SPI (x3) / I2C (x2) Three W.FL Connectors 26 MHz Oscillator + TI DaVinci™ DM3730 or Sitara™ AM3703 ARM® Cortex™-A8 core running up to 1 GHz + TMS320C64x DSP core running up to 800 MHz (DM3730 only) 33 mm + POWER SGX™ graphics accelerator (DM3730 only) 15 mm TOP VIEW :: ACTUAL SIZE 40-pin Debug Connector Two 100-pin High Density Connectors 32 kHz 26 MHz Crystal Oscillator Power HS OTG Audio I/O ADC (x4) Keypad* (4x4) Processor Wireless WL1283 Module UARTs (x3) Product Features Memory + Mobile DDR / NAND flash (PoP technology) 256 MB / 512 MB Wireless Connectivity + WL1283 wireless module featuring 802.11a/b/g/n, Bluetooth 4.0/BLE, & GPS Display + Programmable color LCD controller supports up to 24 bpp TFT interface BOTTOM VIEW :: ACTUAL SIZE *optional, not populated by default + Hardware supports XGA 1024x768 at 24-bit color Camera + Parallel camera interface (Block diagram is not drawn to scale; for reference purposes only.) Audio + I2S-compliant audio codec (16-bit stereo DAC, 13-bit ADC) DM3730 / AM3703 Torpedo + Wireless SOM Ordering Information User Interface + Optional 4x4 keypad interface Model Number1 Speed (MHz) SDRAM (MB) NAND Flash (MB) Temp. (°C) SOMAM3703-32-1780AKIR 800 256 512 -40°–85°2 + Multiple SD/MMC card support SOMDM3730-32-2780AKCR 1000 256 512 0°–70° USB 3 PC Card Expansion + One USB 2.0 high-speed On-the-Go interface NOTES: 1. Custom configurations are available by special order. Please contact Logic PD Sales for details. 2. Junction temperature of the DM3730/AM3703 processor must stay below 105°C. 3. Junction temperature of the DM3730/AM3703 processor must stay below 90°C. Serial I/O + UARTs, SPI, I2C, McBSPs GPIO + Programmable I/O depending on peripheral requirements + General purpose memory controller (GPMC) interface Zoom™ DM3730 Torpedo Development Kit Ordering Information Model Number SOM Configuration Suggested Resale SDK-DM3730-30-256512R SOMDM3730-32-2780AKCR SOMDM3730-20-2780AGCR $997 Debug + 40-pin debug connector on top side of SOM + JTAG & ETM support Software + Android™ BSP + Linux™ BSP + LogicLoader™ (bootloader/monitor) + Wattson™ power measurement application LOGIC PD WEBSITE :: DESIGN RESOURCES: 6201 Bury Dr. | Eden Prairie, MN 55346 T : 952.941.8071 F : 952.941.8065 l www.logicpd.com Mechanical (Installed) + Logic PD Products : www.logicpd.com/products + 15 mm wide x 33 mm long x 3.8 mm high © 2018 Logic PD, Inc. All rights reserved. PN: 1020571 Rev O + Logic PD Sales : www.logicpd.com/contact/ + Logic PD Technical Support : support.logicpd.com FCC & IC Modular Certified RoHS Compliant
SOMDM3730-31-2780AKCR 价格&库存
很抱歉,暂时无法提供与“SOMDM3730-31-2780AKCR”相匹配的价格&库存,您可以联系我们找货
