STDP4320BA
STDP4320BA
    MEGACHIPS(兆芯)
    LFBGA172
    IC DISPLAYPORT SPLITTER 172LFBGA
STDP4320BA 数据手册
STDP4320 DisplayPort 1.2a splitter Datasheet Rev A MegaChips’ Proprietary Information MegaChips reserves the right to make any change herein at any time without prior notice. MegaChips does not assume any responsibility or liability arising out of application or use of any product or service described herein except as explicitly agreed upon. MegaChips’ Proprietary Information Page 1 of 39 STDP4320 Features • • • • DisplayPort® dual mode receiver – DP 1.2a compliant – Link rate HBR2/HBR/RBR – SST or MST (up to eight streams) – 1, 2, or 4 lanes – AUX CH 1 Mbps – HPD out – HDMI/DVI operation (3.2 Gbps link rate) – Functions as eDP and MyDP receiver DisplayPort dual mode transmitters – Two transmitter ports – DP 1.2a compliant – Link rate HBR2/HBR/RBR – SST or MST (up to eight streams) – 1, 2, or 4 lanes – AUX CH 1 Mbps – HPD in – HDMI/DVI operation (3.2 Gbps link rate) with external level translator – Functions as eDP transmitter SPDIF audio output – Two SPDIF port pins – 192 kHz/24 bits – Compressed/LPCM • HDCP repeater with embedded keys • AUX to I2C bridge for EDID/MCCS pass through – Maps on DDC ports • Device configuration options – SPI Flash – I2C host interface • Deep color support – RGB/YCC (4:4:4) – 16-bit color – YCC (4:2:2) – 16-bit color • Spread spectrum on DisplayPort interface for EMI reduction • Bandwidth – Video resolution up to 4K2K @ 60 Hz – Audio 7.1 Ch up to 192 kHz sample rate • Low power operation – Standby 30 mW • Package – 172 LFBGA (12 x 12 mm) • Power supply voltages – 3.3 V I/O; 1.2 V core Applications • Conversion from DP SST to TMDS format and vice versa I2C SPI Audio-video router for PC/notebooks, docking stations, hub, 4K2K TVs, daisy chain monitors, digital signage I2C SLAVE GPIO / MFP CLOCK GEN OCM AUDIO PROC DP++ TX DP1.2 / HDMI 1.4 OUTPUT DP1.2 / HDMI 1.4 OUTPUT DP1.2 / HDMI 1.4 INPUT DP++ RX VIDEO PROC DP++ TX HDMI DDC IN SPDIF OUT HDCP C4320-DAT-01p 27MHz I2C MASTER MegaChips’ Proprietary Information Page 2 of 39 HDMI DDC OUT STDP4320 Contents 1. Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 2. Application overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 3. Feature attributes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 4. 5. 6. 7. 3.1 Input interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 3.2 Output interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 3.3 Supported video timings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 3.4 Supported audio timings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 3.5 Control channel interfaces . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 3.6 HDCP 1.3 support . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 3.7 Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 3.8 Power supply voltages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 3.9 ESD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 BGA footprint and pin lists . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 4.1 Ball grid array diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 4.2 Full pin list sorted by pin number . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 5.1 Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 5.2 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Package specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 6.1 Package drawing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 6.2 Package dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 6.3 Marking field template and descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 6.4 Classification reflow profile . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Electrical specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 7.1 Preliminary DC characteristics: absolute maximum ratings . . . . . . . . . . . 28 7.2 DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 7.3 AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 C4320-DAT-01p MegaChips’ Proprietary Information Page 3 of 39 STDP4320 7.3.1 DisplayPort receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 7.3.2 DisplayPort transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 7.3.3 HDMI receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 7.3.4 HDMI transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 7.3.5 Crystal specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 7.3.6 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 7.3.7 SPI interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 8. Ordering information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 9. Revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38 C4320-DAT-01p MegaChips’ Proprietary Information Page 4 of 39 STDP4320 List of Tables Table 1. Table 2. Table 3. Table 4. Table 5. Table 6. Table 7. Table 8. Table 9. Table 10. Table 11. Table 12. Table 13. Table 14. Table 15. Table 16. Table 17. Table 18. Table 19. Table 20. Table 21. Table 22. Table 23. Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 DisplayPort receiver pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 System function pins. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Multi-function pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Transmitter pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 System power and ground . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Reserved pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Field descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Absolute maximum ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 DC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 Maximum speed of operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 DisplayPort receiver electrical parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 DisplayPort transmitter electrical parameters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 HDMI receiver DC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 HDMI receiver AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 HDMI transmitter (DP++) DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 HDMI transmitter AC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 Crystal specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 SPI interface timing, VDD = 3.3 V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 Order codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 Document revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38 C4320-DAT-01p MegaChips’ Proprietary Information Page 5 of 39 STDP4320 List of Figures Figure 1. Figure 2. Figure 3. Figure 4. Figure 5. Figure 6. Figure 7. Figure 8. Figure 9. Figure 10. STDP4320 in video hub application . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 STDP4320 in 4K2K TV application . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 STDP4320 BGA diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Package drawing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Package dimensions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 Marking template . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 HDMI and DVI receiver AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 I2C timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 SPI input timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 SPI output timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 C4320-DAT-01p MegaChips’ Proprietary Information Page 6 of 39 STDP4320 1. Description The STDP4320 is a high-speed DisplayPort dual mode splitter IC targeted for audio-video demultiplexing and routing in applications such as notebooks, docking stations, video hub, 4K2K TVs, daisy chainable monitors, digital signage, etc. It consists of one dual mode input port and two dual mode output ports configurable as either DisplayPort or HDMI/DVI. STDP4320 is a VESA DP Standard Ver. 1.2a compliant device that supports advanced features such as MST, HBR2, 3D formats and GTC assist. Designs based on STDP4320 have the flexibility to offer either DP or HDMI/DVI connectors on its end product to interface with legacy and new generation video sources and sinks. In addition, STDP4320based products with a DisplayPort output connector are DP++ compliant and work with any HDMI or single link DVI sink through a passive level translator (dongle). The STDP4320 uses MegaChips’ latest generation DisplayPort dual mode receiver and transmitter technology that supports both DisplayPort and TMDS signal formats. This device receives MST format up to eight audio-video streams, which can be further routed on either of the two outputs in any combination of eight streams depending on the capability of downstream sinks. This device can also replicate the incoming video streams on both output ports simultaneously, thus allowing cloning on two downstream sinks. For example, a 4K2K 60 Hz video input is replicated on two output ports simultaneously. The DisplayPort receiver and transmitters support HBR2 speed, a data rate of 5.4 Gbps per lane with a total bandwidth of 21.6 Gbps link rate. In HDMI mode, this device supports link rates up to 3.2 Gbps corresponding to a pixel rate of 300 MHz, adequate for supporting video resolution up to FHD 120 Hz with all 3D formats. The device is also capable of delivering deep color video up to 16-bits per color. The STDP4320 allows audio transport from the source to the desired audio rendering devices over the video output port or through an SPDIF port. The STDP4320 supports RGB and YCbCr colorimetric formats with color depth of 16, 12, 10, and 8 bits. The STDP4320 features the HDCP 1.3 content protection scheme with embedded keys for secure transmission of protected audio-video content. It also operates as an HDCP repeater for the downstream sinks. The DDC ports in the STDP4320 allow the upstream source to access EDID and transfer MCCS commands to downstream sinks when the physical ports are either HDMI or DVI type. If both the upstream source and downstream sinks are DP type, I2C transactions take place over the AUX CH. If one of them is a DP type and the other is either a HDMI or DVI type, STDP4320 converts the I2C over AUX message protocol to I2C commands and sends it on the DDC port. C4320-DAT-01p MegaChips’ Proprietary Information Page 7 of 39 STDP4320 The device has an on-chip microcontroller with SPI, UART, and I2C interface. The STDP4320 uses an external SPI Flash ROM for storing device configuration firmware. It has an I2C slave port for external host communication. Other system interface signals include general-purpose IO for source, sink communication, detection, monitoring, etc. When the downstream sink is disconnected, STDP4320 automatically turns off the inactive port for power saving purposes. C4320-DAT-01p MegaChips’ Proprietary Information Page 8 of 39 STDP4320 2. Application overview Figure 1. STDP4320 in video hub application DP1.2 DP1.2 STDP4320 SPI Flash DP1.2 Crystal Figure 2. STDP4320 in 4K2K TV application C4320-DAT-01p MegaChips’ Proprietary Information Page 9 of 39 STDP4320 3. Feature attributes 3.1 Input interface • Single DP++ interface featuring – DisplayPort Ver. 1.2a compliant receiver; supports eDP and MyDP – HDMI 1.4 compliant receiver • Main link configuration – SST or MST (up to eight streams) – HBR2/HBR/RBR link rate – 1, 2, or 4 lanes • AUX CH: 1 Mbps Manchester transaction format • HPD: IRQ_HPD assertion • Video: EDID 1.4 and CEA861 video timing and formats from 24 to 48 bits/pixel in RGB, YCC422, or YCC444 colorimetry • Audio: DisplayPort 1.2a standard info frame packets and IEC60958/61937 type audio stream packets ranging from 16 to 24 bits/sample, 32 to 192 kHz sample rates • HDMI link rate: 3.2 Gbps/data pair max C4320-DAT-01p MegaChips’ Proprietary Information Page 10 of 39 STDP4320 3.2 Output interface • Two DP++ interfaces featuring – AC coupled DisplayPort Ver. 1.2a compliant transmitter: supports eDP – AC coupled HDMI 1.4 transmitter • DP main link configuration – SST or MST (up to eight streams) – HBR2/HBR/RBR link rate – 1, 2, or 4 lanes • AUX CH: Manchester transaction format • HPD: IRQ_HPD assertion • Video: EDID 1.4 and CEA861 video timing and formats from 24 to 48 bits/pixel in RGB, YCC422, or YCC444 colorimetry • Audio: DisplayPort 1.2a standard info frame packets and IEC60958/61937 type audio stream packets ranging from 16 to 24 bits/sample, 32 to 192 kHz sample rates • HDMI link rate: 3.2 Gbps/data pair max 3.3 Supported video timings • 4K2K 60 Hz: 24 bits/pixel in DP 1.2a configuration • 1920 x 1080 (FHD) 240 Hz, 24 bits/pixel • All 3D formats defined in DP 1.2a and HDMI 1.4 standards • All standard CEA861 timing formats 3.4 Supported audio timings • All audio formats as specified in DP 1.2a and HDMI 1.4 standards • SPDIF; 2-Ch LPCM, AC3, DTS, bit depth up to 24 bits, sample rate up to 192 kHz (applicable in DP SST/HDMI output use case) 3.5 Control channel interfaces • AUX CH, DDC, I2C host interface, and UART (UART for test/debug purposes only) C4320-DAT-01p MegaChips’ Proprietary Information Page 11 of 39 STDP4320 3.6 HDCP 1.3 support • Key sets for DP/HDMI RX and DP/HDMI TX integrated in one-time programmable ROM (OTP) • Standalone HDCP repeater capability 3.7 Package • 172 LFBGA (12 x 12 mm), 0.8 ball pitch 3.8 Power supply voltages • 3.3 V I/O; 1.2 V core 3.9 ESD • 2 KV HBM, 450 V CDM C4320-DAT-01p MegaChips’ Proprietary Information Page 12 of 39 STDP4320 4. BGA footprint and pin lists 4.1 Ball grid array diagram The ball grid array (BGA) diagrams give the allocation of pins to the package, shown from the top looking down using the PCB footprint. The STDP4320 is available in a 172-pin LFBGA package. White = no ball at this location n/c = no connect: ball present, but must not be connected Figure 3. STDP4320 BGA diagram C4320-DAT-01p MegaChips’ Proprietary Information Page 13 of 39 STDP4320 4.2 Full pin list sorted by pin number Table 1. Pin list Pin number A1 VSS A2 RX0_LN2_N A5 RX0_LN0_P A6 RX0_AUX_P A7 RX0_AUX_N A8, A9, A10, A13 n/c A14 VSS B1 RX0_LN3_P B2 RX0_LN2_P B5 RX0_LN0_N B6, B7, B8, B9 VSS B10, B13, B14 n/c C1 RX0_LN3_N C2 AVDD33_RX C3 RX0_LN1_N C4 RX0_LN1_P C5, C6 AVDD12_RX C7, C8 AVDD33_RX C9, C10 AVDD12_RX C11, C12 n/c C13 AVDD33_RX C14 n/c D1 TX1_HPD D2 TEST D3, D4, D5 VSS D6 D7, D8 D9 D10, D11, D12 C4320-DAT-01p Net name RX0_REXT VSS n/c VSS D13 HDMI_TX0_DDC_SCL D14 HDMI_TX0_DDC_SDA E1 n/c E2 SPDIF_OUT0 MegaChips’ Proprietary Information Page 14 of 39 STDP4320 Table 1. Pin list (continued) Pin number E3 HDMI_CEC E4 TX0_HPD E5 DVDD12 E10 DVDD12 E11 HDMI_TX1_DDC_SDA E12 GPIO8 E13 GPIO6 E14 HDMI_TX1_DDC_SCL F1 MASTER1_IRQ_IN F2 GPO F3 SPDIF_OUT1 F4 RX0_HPD F5 DVDD12 F6, F7, F8, F9 VSS F10 DVDD12 F11 GPIO9 F12 GPIO10 F13 GPIO11 F14 GPIO7 G1 MASTER2_IRQ_IN G2 MASTER3_IRQ_IN G3 GPIO13/TX1_CONFIG2 G4 MASTER0_IRQ_IN G5 DVDD12 G6, G7, G8, G9 C4320-DAT-01p Net name VSS G10 DVDD12 G11 MASTER2_I2C_SDA G12 MASTER2_I2C_SCL G13 MASTER0_I2C_SDA G14 MASTER0_I2C_SCL H1 GPIO12/TX1_CONFIG1 H2 HOST_IRQ_OUT H3 SPI_CLK H4 UART_TX H5 DVDD12 MegaChips’ Proprietary Information Page 15 of 39 STDP4320 Table 1. Pin list (continued) Pin number H6, H7, H8, H9 VSS H10 DVDD12 H11 HDMI_RX0_DDC_SCL H12 RESETn H13 MASTER1_I2C_SDA H14 MASTER1_I2C_SCL J1 SPI_DI J2 UART_RX J3 SPI_CSN J4 GPIO2 J5 DVDD33 J6, J7, J8, J9 VSS J10 DVDD33 J11 n/c J12 HOST_I2C_SCL J13 MASTER3_I2C_SCL J14 MASTER3_I2C_SDA K1 TCLK_3V3_OUT K2 SPI_DO K3 GPIO0/TX0_CONFIG1 K4 GPIO1/TX0_CONFIG2 K5 DVDD25_SM K10 GPIO5 K11 n/c K12 HDMI_RX0_DDC_SDA K13 AVDD12_PLL K14 HOST_I2C_SDA L1 TCLK_1V2_OUT L2 TX0_REXT L3, L4 L5 L6, L7, L8, L9 L10 L11, L12 L13 C4320-DAT-01p Net name VSS GPIO3/RX0_CABLE_DET0 VSS GPIO4/RX0_CABLE_DET1 VSS AVDD12_OSC1 MegaChips’ Proprietary Information Page 16 of 39 STDP4320 Table 1. Pin list (continued) Pin number L14 AVDD33_RCOSC M1 TX0_AUX_N M2 AVDD12_TX0 M3 TX0_LN2_N M4 TX0_LN2_P M5 AVDD12_TX0 M6 AVDD12_OSC0 M7, M8 C4320-DAT-01p Net name VSS M9 TX1_REXT M10 AVDD12_TX1 M11 TX1_LN2_N M12 TX1_LN2_P M13 AVDD33_TX1 M14 TX1_LN0_P N1 TX0_AUX_P N2 TX0_LN3_P N5 TX0_LN1_N N6 AVDD33_TX0 N7 TCLK N8 XTAL N9 AVDD12_TX1 N10 TX1_LN3_P N13 TX1_LN1_N N14 TX1_LN0_N P1 VSS P2 TX0_LN3_N P5 TX0_LN1_P P6 TX0_LN0_N P7 TX0_LN0_P P8 TX1_AUX_N P9 TX1_AUX_P P10 TX1_LN3_N P13 TX1_LN1_P P14 VSS MegaChips’ Proprietary Information Page 17 of 39 STDP4320 5. Connections 5.1 Pin list I/O Legend: I = Input; O = Output; P = Power; G = Ground; IO = Bi-direction; AI = Analog input; AO = Analog output; AIO = Analog I/O; TRI = Tristate; TOL = Tolerance; PD = Internal 50K pulldown; PU = Internal 50K pull-up; OPENDR = Open drain output Note: Some pins can have multiple functionalities, which are configured under register control. The alternate functionality for each pin is listed in the Description column. Table 2. DisplayPort receiver pins Pin Assignment I/O Description Reset state D6 RX0_REXT AIO, 3V3 TOL Connect to External 249 Ohm Resistor to VDD33 NA A5 RX0_LN0_P AIO, 3V3 TOL DUAL MODE RX HDMI CLOCKP OR DP RX_LN0P. TRISTATE B5 RX0_LN0_N AIO, 3V3 TOL DUAL MODE RX HDMI CLOCKN OR DP RX_LN0N. TRISTATE C4 RX0_LN1_P AIO, 3V3 TOL DUAL MODE RX HDMI RX0P OR DP RX_LN1P. TRISTATE C3 RX0_LN1_N AIO, 3V3 TOL DUAL MODE RX HDMI RX0N OR DP RX_LN1N. TRISTATE B2 RX0_LN2_P AIO, 3V3 TOL DUAL MODE RX HDMI RX1P OR DP RX_LN2P. TRISTATE A2 RX0_LN2_N AIO, 3V3 TOL DUAL MODE RX HDMI RX1N OR DP RX_LN2N. TRISTATE B1 RX0_LN3_P AIO, 3V3 TOL DUAL MODE RX HDMI RX2P OR DP RX_LN3P. TRISTATE C1 RX0_LN3_N AIO, 3V3 TOL DUAL MODE RX HDMI RX2N OR DP RX_LN3N. TRISTATE A6 RX0_AUX_P AIO, 1V2 TOL DUAL MODE RX DP RX_AUXP. AC Couple 0.1uF. Use 20 Ohm damping resistor in series and 1M Ohm pull up to 3.3 V before cap. TRISTATE A7 RX0_AUX_N AIO, 1V2 TOL DUAL MODE RX DP RX_AUXN. AC Couple 0.1uF. Use 20 Ohm damping resistor in series and 1M Ohm pull down to GND before cap. TRISTATE Note: The default DP and HDMI input signals mapping match the standard DP and HDMI connector pin mapping. However, lane swapping and polarity swapping are possible through software configuration. C4320-DAT-01p MegaChips’ Proprietary Information Page 18 of 39 STDP4320 Table 3. System function pins Pin Assignment I/O Description Reset state D2 TEST I, 3V3 TOL, INT PD Connect to GND INPUT, Internal PD N7 TCLK XTAL Connect to 27 MHz crystal oscillator with 22 pF to 1.2 V. NA N8 AIO, 1V2 TOL K1 TCLK_3V3_OUT IO, 3V3 TOL TCLK output, Tristate 3.3 V pad TRISTATE L1 TCLK_1V2_OUT IO, 1V2 TOL TCLK output, Tristate 1.2 V pad TRISTATE H12 RESETn AIO, 3V3 TOL TRISTATE, INPUT J3 SPI_CSN IO, 3V3 TOL, To SPI chip select. Also see Table 8: Bootstrap TRI, INT PU configuration. TRISTATE, Internal PU K2 SPI_DO IO, 3V3 TOL, To SPI data out. Also see Table 8: Bootstrap TRI, INT PD configuration. TRISTATE, Internal PD J1 SPI_DI I, 3V3 TOL, INT PD INPUT with Internal PD H3 SPI_CLK IO, 3V3 TOL, To SPI clock. Also see Table 8: Bootstrap TRI, INT PD configuration. Use external 3K ohm resistor to 3.3 V From SPI data in. TRISTATE, Internal PD Table 4. Multi-function pins Pin Assignment E3 I/O Description Reset state HDMI_CEC HDMI CEC not supported in the current silicon rev. Connect this pin to external pull-up DVDD3V3. TRISTATE F4 RX0_HPD To the upstream HPD signal pin on the DP connector. 100K res to GND. TRISTATE L5 GPIO3/ RX0_CABLE_DET0 Cable detect1 for DisplayPort connector TRISTATE L10 GPIO4/ RX0_CABLE_DET1 Cable detect2 for DisplayPort connector TRISTATE K12 HDMI_RX0_DDC_SDA DDC SDA for upstream HDMI port0. Use external pull up 4.7 K to 3.3 V when used. Else leave as TRISTATE NC. H11 HDMI_RX0_DDC_SCL DDC SCL for upstream HDMI port0. Use external pull up 4.7 K to 3.3 V when used. Else leave as TRISTATE NC. E2 SPDIF_OUT0 To external buffer for SPDIF output [Audio corresponding to video on Port0] TRISTATE, Internal PU To external buffer for SPDIF output [Audio corresponding to video on Port1] TRISTATE, Internal PU IO, 3.3 TOL, TRI IO, 3.3 TOL, TRI, INT PU F3 SPDIF_OUT1 C4320-DAT-01p MegaChips’ Proprietary Information Page 19 of 39 STDP4320 Table 4. Multi-function pins Pin Assignment E4 I/O Description Reset state TX0_HPD HPD in for Downstream DP/HDMI port0 TRISTATE J4 GPIO2 General Purpose input/output, Tristate 3.3 V pad TRISTATE D14 HDMI_TX0_DDC_SDA DDC SDA for downstream HDMI port0. Use external pull up 4.7 K to 3.3 V when used. Else leave as NC. TRISTATE D13 IO, 3.3 TOL, HDMI_TX0_DDC_SCL TRI DDC SCL for downstream HDMI port0. Use external pull up 4.7 K to 3.3 V when used. Else leave as NC. TRISTATE K3 GPIO0/TX0_CONFIG1 Config1 input for Downstream DP port0 or GPIO TRISTATE K4 GPIO1/TX0_CONFIG2 Config2 input for Downstream DP port0 or GPIO TRISTATE D1 TX1_HPD HPD in for Downstream DP/HDMI port1 TRISTATE K10 GPIO5 General Purpose input/output, Tristate 3.3 V pad TRISTATE E11 HDMI_TX1_DDC_SDA DDC SDA for downstream HDMI port1. Use external pull up 4.7 K to 3.3 V when used. Else leave as NC. TRISTATE E14 HDMI_TX1_DDC_SCL IO, 3.3 TOL, TRI DDC SCL for downstream HDMI port1 . Use external pull up 4.7 K to 3.3 V when used. Else leave as NC. TRISTATE H1 GPIO12/ TX1_CONFIG1 Config1 input for Downstream DP port1 or GPIO TRISTATE G3 GPIO13/ TX1_CONFIG2 Config2 input for Downstream DP port1 or GPIO TRISTATE H4 UART_TX To debug port UART_TX. Also see Table 8: Bootstrap configuration. TRI, Internal PU J2 UART_RX To debug port UART_RX TRISTATE G14 MASTER0_I2C_SCL G13 MASTER0_I2C_SDA G4 MASTER0_IRQ_IN H14 MASTER1_I2C_SCL IO, 3.3 TOL, TRI, INT PU IO, 3.3 TOL, TRI Master I2C SDA Port0. Connect to I2C Slave with TRISTATE external Pull Up IO, 3.3 TOL, TRI, INT PD IO, 3.3 TOL, TRI H13 MASTER1_I2C_SDA F1 MASTER1_IRQ_IN G12 MASTER2_I2C_SCL IO, 3.3 TOL, TRI, INT PD IO, 3.3 TOL, TRI G11 MASTER2_I2C_SDA C4320-DAT-01p Master I2C SCL Port0. Connect to I2C Slave with TRISTATE external Pull Up Master I2C Port0 interrupt input. Connect to I2C Slave interrupt out TRISTATE, Internal PD Master I2C SCL Port1. Connect to I2C Slave with TRISTATE external Pull Up Master I2C SDA Port1. Connect to I2C Slave with TRISTATE external Pull Up Master I2C Port01interrupt input. Connect to I2C Slave interrupt out TRISTATE, Internal PD Master I2C SCL Port2. Connect to I2C Slave with TRISTATE external Pull Up Master I2C SDA Port2. Connect to I2C Slave with TRISTATE external Pull Up MegaChips’ Proprietary Information Page 20 of 39 STDP4320 Table 4. Multi-function pins Pin Assignment I/O Description Reset state G1 MASTER2_IRQ_IN IO, 3.3 TOL, TRI, INT PD Master I2C Port2 interrupt input. Connect to I2C Slave interrupt out TRISTATE, Internal PD J13 MASTER3_I2C_SCL IO, 3.3 TOL, TRI J14 MASTER3_I2C_SDA G2 MASTER3_IRQ_IN J12 HOST_I2C_SCL IO, 3.3 TOL, TRI, INT PD IO, 3.3 TOL, TRI K14 HOST_I2C_SDA H2 HOST_IRQ_OUT IO, 3.3 TOL, TRI, INT PD E13 GPIO6 IO, 3.3 TOL, TRI F14 GPIO7 IO, 3.3 TOL, TRI E12 GPIO8 IO, 3.3 TOL, TRI F11 GPIO9 IO, 3.3 TOL, TRI F12 GPIO10 IO, 3.3 TOL, TRI F13 GPIO11 IO, 3.3 TOL, TRI F2 GPO IO, 3.3 TOL, TRI, INT PD Master I2C SCL Port3. Connect to I2C Slave with TRISTATE, external Pull Up Master I2C SDA Port3. Connect to I2C Slave with TRISTATE, external Pull Up Master I2C Port3 interrupt input. Connect to I2C Slave interrupt out TRISTATE, Internal PD Slave I2C SCL. Connect to I2C Master with external Pull Up TRISTATE Slave I2C SDA. Connect to I2C Master with external Pull Up TRISTATE Interrupt out. Connect to interrupt in of Master TRISTATE, Internal PD General purpose input/output TRISTATE General purpose input/output. See Table 8: Bootstrap configuration. TRISTATE, Internal PD Table 5. Transmitter pins Pin Assignment I/O Description Reset state L2 TX0_REXT AI, 1V2 TOL TX, EXTERNAL 249 Ohm RESISTOR TO VDD12 NA N1 TX0_AUX_P AIO, 1V2 TOL DUAL MODE TX Port0 DP TX_AUXP. AC Couple to TRISTATE TX Connector. External 100K Resistor to GND. M1 TX0_AUX_N AIO, 1V2 TOL DUAL MODE TX Port0 DP TX_AUXN. AC Couple to TRISTATE TX Connector. External 100K Resistor to VDD33. N2 TX0_LN3_P AO, 1V2 TOL DUAL MODE TX Port0 HDMI TXCKP OR DP TX_LN3P. AC Couple to TX Connector. TRISTATE P2 TX0_LN3_N AO, 1V2 TOL DUAL MODE TX Port0 HDMI TXCKN OR DP TX_LN3N. AC Couple to TX Connector TRISTATE M4 TX0_LN2_P AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX2P OR DP TX_LN2P. AC Couple to TX Connector TRISTATE C4320-DAT-01p MegaChips’ Proprietary Information Page 21 of 39 STDP4320 Table 5. Transmitter pins Pin Assignment I/O Description Reset state M3 TX0_LN2_N AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX2N OR DP TX_LN2N. AC Couple to TX Connector TRISTATE P5 TX0_LN1_P AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX1P OR DP TX_LN1P. AC Couple to TX Connector TRISTATE N5 TX0_LN1_N AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX1N OR DP TX_LN1N. AC Couple to TX Connector TRISTATE P7 TX0_LN0_P AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX0P OR DP TX_LN1P. AC Couple to TX Connector TRISTATE P6 TX0_LN0_N AO, 1V2 TOL DUAL MODE TX Port0 HDMI TX0N OR DP TX_LN1N. AC Couple to TX Connector TRISTATE M9 TX1_REXT AI, 1V2 TOL TX, EXTERNAL 249 Ohm RESISTOR TO VDD12 NA P9 TX1_AUX_P AO, 1V2 TOL DUAL MODE TX Port1 DP TX_AUXP. AC Couple to TRISTATE TX Connector. External 100K Resistor to GND. P8 TX1_AUX_N AO, 1V2 TOL DUAL MODE TX Port1 DP TX_AUXN. AC Couple TRISTATE to TX Connector. External 100K Resistor to VDD33. N10 TX1_LN3_P AO, 1V2 TOL DUAL MODE TX Port1 HDMI TXCKP OR DP TX_LN3P. AC Couple to TX Connector. TRISTATE P10 TX1_LN3_N AO, 1V2 TOL DUAL MODE TX Port1 HDMI TXCKN OR DP TX_LN3N. AC Couple to TX Connector TRISTATE M12 TX1_LN2_P AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX2P OR DP TX_LN2P. AC Couple to TX Connector TRISTATE M11 TX1_LN2_N AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX2N OR DP TX_LN2N. AC Couple to TX Connector TRISTATE P13 TX1_LN1_P AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX1P OR DP TX_LN1N. AC Couple to TX Connector TRISTATE N13 TX1_LN1_N AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX1N OR DP TX_LN1N. AC Couple to TX Connector TRISTATE M14 TX1_LN0_P AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX0P OR DP TX_LN1P. AC Couple to TX Connector TRISTATE N14 TX1_LN0_N AO, 1V2 TOL DUAL MODE TX Port1 HDMI TX0N OR DP TX_LN1N. AC Couple to TX Connector TRISTATE Table 6. System power and ground Pin Assignment Description J5, J10 DVDD33 I/O VDD, 3.3V digital supply. De-couple using 100 nF. E5, E10, F5, F10, G5, G10, H5, H10 DVDD12 Core VDD, 1.2V digital supply. De-couple using 100 nF. L14 AVDD33_RCOSC 3.3V RC-oscillator analog supply. De-couple using 100 nF. K13 AVDD12_PLL 1.2V analog PLL supply. De-couple using 10 uF and 100 nF. C5, C6, C9, C10 AVDD12_RX 1.2V analog receiver supply. EMI filter rail and de-couple using 10 uF and 100 nF. C4320-DAT-01p MegaChips’ Proprietary Information Page 22 of 39 STDP4320 Table 6. System power and ground Pin Assignment Description C2, C7, C8, C13 AVDD33_RX 3.3V analog receiver supply. EMI filter rail and de-couple using 10 uF and 100 nF. N6 AVDD33_TX0 3.3V analog transmitter supply. EMI filter rail and de-couple using 10 uF and 100 nF. M13 AVDD33_TX1 3.3V analog transmitter supply. EMI filter rail and de-couple using 10 uF and 100 nF. M2, M5 AVDD12_TX0 1.2V analog transmitter supply. EMI filter rail and de-couple using 10 uF and 100 nF. M10, N9 AVDD12_TX1 1.2V analog transmitter supply. EMI filter rail and de-couple using 10 uF and 100 nF. M6 AVDD12_OSC0 1.2V analog crystal oscillator supply. De-couple using 100 nF. L13 AVDD12_OSC1 1.2V analog crystal oscillator supply. De-couple using 100 nF. K5 DVDD25_SM 2.5V LDO supply. De-couple using 10 uF and 100 nF. A1, A14, B6, B7, B8, B9, D3, D4, D5, D7, D8, D10, D11, D12, F6, F7, F8, F9, G6, G7, G8, G9, VSS H6, H7, H8, H9, J6, J7, J8, J9, L3, L4, L6, L7, L8, L9, L11, L12, M7, M8, P1, P14 Common GND. Connect to GND plane Table 7. Reserved pins Pin Assignment Description A8, A9, A10, A13, B10, B13, B14, C11, C12, n/c C14, D9, E1, J11, K11 5.2 Reserved. Do not connect Bootstrap configuration DC levels on some of the pins are specified during de-asserting edge of power-on reset (RESETn goes high). The levels specified below must be adhered for normal function of the device. Table 8. Bootstrap configuration Bootstrap signal name Internal PU/PD Pin assignment Bootstrap_0 PULLUP UART_TX (H4) Function 0: Reserved for ATE Test 1: Normal Operation (Recommended) Bootstrap_1 PULLDN GPO (F2) 0: Crystal_OSC is enabled (Recommended) 1: RC_OSC is enabled, C4320-DAT-01p MegaChips’ Proprietary Information Page 23 of 39 STDP4320 Bootstrap signal name Bootstrap_2 Internal PU/PD PULLDN Pin assignment Function SPI_CLK (H3) 0: OCM boot up from internal ROM (Recommended) 1: OCM boot up from external ROM 0: Reserved for Testing (Recommended) Bootstrap_3 PULLDN SPI_DO (K2) 1: Reserved for Testing 0: Select External OSC Operation Bootstrap_4 PULLUP SPDIF_OUT0 (E2) Bootstrap_5 PULLUP SPI_CSN (J3) 1: Select Internal OSC Operation (Recommended) 0: Debug Mode 1: Normal Operation (Recommended) 0: Software Bootstrap for I2C address selection Bootstrap_6 PULLUP SPDIF_OUT1 (F3) 1: Software Bootstrap for I2C address selection 0: Software Bootstrap for I2C address selection Bootstrap_7 PULLDN HOST_IRQ_OUT (H2) 1: Software Bootstrap for I2C address selection Note: When the pin corresponding to a specific bootstrap is left NC, it takes the value of the assigned by the internal PULLUP (Level 1) or PULLDN (Level0). The internal resistor used is around 50 k ohm. To select a non-default value on a bootstrap, an external PULLUP or PULLDN resistor is tied to the opposite direction that overcomes the internal PULLUP or PULLDN needs to be used. C4320-DAT-01p MegaChips’ Proprietary Information Page 24 of 39 STDP4320 6. Package specifications Package type: 172 LFBGA (12 x 12 mm / ball pitch 0.8 mm) 6.1 Package drawing Figure 4. Package drawing C4320-DAT-01p MegaChips’ Proprietary Information Page 25 of 39 STDP4320 6.2 Package dimensions Figure 5. Package dimensions C4320-DAT-01p MegaChips’ Proprietary Information Page 26 of 39 STDP4320 6.3 Marking field template and descriptors The STDP4320 marking template is shown below. Figure 6. Marking template Field descriptors are shown below. Table 9.Field descriptors Field Description Marking A Standard MegaChips logo M B 2-character version code BA C Product code STDP4320 D Optional marking E 2-character assembly plant code 22 F 3-character BE sequence code “XYZ” G 2-character diffusion plant code VQ H 3-character country of origin code MLT I 2-character test plant code 22 J 1-digit assembly year “Y” K 2-digit assembly week “WW” L Ball A1 identifier a DOT 6.4 Classification reflow profile Please refer to the DisplayPort Application Note: Classification reflow profile for SMD devices (C0353-APN-06) for reflow diagram and details. C4320-DAT-01p MegaChips’ Proprietary Information Page 27 of 39 STDP4320 7. Electrical specifications 7.1 Preliminary DC characteristics: absolute maximum ratings Applied conditions greater than those listed under “Absolute maximum ratings” may cause permanent damage to the device. The device should never exceed absolute maximum conditions since it may affect device reliability. Table 10. Absolute maximum ratings Parameter Symbol Min Typ Max Units VVDD_3.3 -0.3 3.3 3.63 V VVDD_1.2 -0.3 1.2 1.26 V Input voltage for tolerance for 5 V I/O pin VIN5Vtol -0.3 - 5.5 V Input voltage tolerance for 3.3 V I/O pin(1,2) VIN3V3tol -0.3 - 3.63 V ESD - Human Body Model (HBM) VESD - - ±2 kV ESD - Charged Device Model (CDM) VESD - - ±450 V Latch-up ILA - - ±200 mA Ambient operating temperature TA 0 - 70 °C Storage temperature TSTG -40 - 125 °C Operating junction temperature TJ 0 - 125 °C Thermal resistance (Junction to Ambient) θJA - 36.5 - °C/W PSI (J-C) (Junction to Case) ψJC - 1.6 - °C/W Peak IR reflow soldering temperature (
STDP4320BA 价格&库存
很抱歉,暂时无法提供与“STDP4320BA”相匹配的价格&库存,您可以联系我们找货
