1KDES1300
1KDES1300
    SCS
    1 UNIT KRAFT DESI 1300/DRUM
1KDES1300 数据手册
Description This efficient desiccant begins working by absorbing airborne moisture left inside the bag when you’ve finished vacuum packaging, capturing moisture that manages to pass through the bag material. Secured in a strong pouch of either clean room grade, sulphur-free, non-woven Tyvek® or economical kraft paper, desiccant helps keep your devices dry, even through unexpected shipping delays or longer than anticipated storage time. Specifications Desiccant in Tyvek® Pouch Properties Pouch Unit Sizes Media Packaging Desiccant in Kraft Pouch Pouch Size Tyvek® Pouch Item Number Pouches per Container Width (in) Length (in) Width (mm) Length (mm) 1/6 Unit 1/6PLDES1200 1200 2.125 2.125 54 54 1/3 Unit 1/3PLDES700 700 2.125 2.5 54 64 1/2 Unit 1/2PLDES550 550 2.125 2.875 54 73 1 Unit 1PLDES300 300 3.00 4.50 76 114 1 Unit 1PLDES1800 1800 3.00 4.50 76 114 2 Unit 2PLDES150 150 5.00 4.50 127 114 4 Unit 4PLDES500 500 5.00 6.250 127 159 8 Unit 8PLDES300 300 4.50 8.50 114 216 16 Unit 16PLDES150 150 4.50 11.00 114 279 Kraft Pouch Item Number Pouches per Container Width (in) Length (in) Width (mm) Length (mm) 1/2 Unit 1/2KDES550 550 2.375 3.50 60 89 Pouch Size RoHS 2, REACH, and Conflict Minerals Statement None of the RoHS 2 restricted materials or REACH ( Registration, Evaluation and Authorization of Chemicals) substances of very high concern as of 2020/06/25, or Conflict Minerals are intentionally added in manufacturing this product. Ref: European Union Directive 2015/863/EU and Regulation (EC) No. 1907/2006/CE. Typical Values Non-Woven Tyvek® or Kraft Paper 1/6, 1/3, 1/2, 1, 2, 4, 8, 16 Montmorillonite Clay Air-tight pails or drums The recommended amount of desiccant is dependent on the interior surface area of the bag to be used. Below is a reference table indicating recommended minimum amounts of desiccant that should be used with Moisture Barrier Bags. Note: number units rounded up. As packaged SCS Desiccant in Tyvek® and Kraft pouches meets MIL-D-3464, Type I and II and is on the QPL (Qualified Product List). INTERIOR BAG SURFACE AREA* 100 sq. in. 130 sq. in. 160 sq. in. 200 sq. in. 240 sq. in. 290 sq. in. 340 sq. in. 390 sq. in. 450 sq. in. 510 sq. in. 580 sq. in. 650 sq. in. 720 sq. in. NUMBER OF DESICCANT UNITS **MIH
1KDES1300 价格&库存
很抱歉,暂时无法提供与“1KDES1300”相匹配的价格&库存,您可以联系我们找货
