Description
This efficient desiccant begins working by absorbing airborne moisture left inside the bag when
you’ve finished vacuum packaging, capturing moisture that manages to pass through the bag
material. Secured in a strong pouch of either clean room grade, sulphur-free, non-woven Tyvek®
or economical kraft paper, desiccant helps keep your devices dry, even through unexpected
shipping delays or longer than anticipated storage time.
Specifications
Desiccant in Tyvek® Pouch
Properties
Pouch
Unit Sizes
Media
Packaging
Desiccant in Kraft Pouch
Pouch Size
Tyvek®
Pouch
Item Number
Pouches per
Container
Width (in)
Length (in)
Width (mm)
Length (mm)
1/6 Unit
1/6PLDES1200
1200
2.125
2.125
54
54
1/3 Unit
1/3PLDES700
700
2.125
2.5
54
64
1/2 Unit
1/2PLDES550
550
2.125
2.875
54
73
1 Unit
1PLDES300
300
3.00
4.50
76
114
1 Unit
1PLDES1800
1800
3.00
4.50
76
114
2 Unit
2PLDES150
150
5.00
4.50
127
114
4 Unit
4PLDES500
500
5.00
6.250
127
159
8 Unit
8PLDES300
300
4.50
8.50
114
216
16 Unit
16PLDES150
150
4.50
11.00
114
279
Kraft
Pouch
Item Number
Pouches per
Container
Width (in)
Length (in)
Width (mm)
Length (mm)
1/2 Unit
1/2KDES550
550
2.375
3.50
60
89
Pouch Size
RoHS 2, REACH, and Conflict Minerals Statement
None of the RoHS 2 restricted materials or REACH ( Registration, Evaluation and Authorization
of Chemicals) substances of very high concern as of 2020/06/25, or Conflict Minerals are
intentionally added in manufacturing this product. Ref: European Union Directive 2015/863/EU
and Regulation (EC) No. 1907/2006/CE.
Typical Values
Non-Woven Tyvek® or Kraft Paper
1/6, 1/3, 1/2, 1, 2, 4, 8, 16
Montmorillonite Clay
Air-tight pails or drums
The recommended amount of desiccant is dependent on the interior surface area of the bag to
be used. Below is a reference table indicating recommended minimum amounts of desiccant that
should be used with Moisture Barrier Bags. Note: number units rounded up.
As packaged SCS Desiccant in Tyvek® and Kraft pouches meets MIL-D-3464, Type I and II and is
on the QPL (Qualified Product List).
INTERIOR BAG
SURFACE AREA*
100 sq. in.
130 sq. in.
160 sq. in.
200 sq. in.
240 sq. in.
290 sq. in.
340 sq. in.
390 sq. in.
450 sq. in.
510 sq. in.
580 sq. in.
650 sq. in.
720 sq. in.
NUMBER OF DESICCANT UNITS
**MIH
很抱歉,暂时无法提供与“1/3KDES700”相匹配的价格&库存,您可以联系我们找货
