AST-03208MR-R
32mm Speaker
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• 32mm diameter speaker with Neodymium magnet for 82 dB sensi vity
• 0.1W con nuous, 0.2W maximum power handling and 8Ω impedance
• Mylar cone for wide frequency response
• Thru hole design and wave solderable for PCB mount
Frequency Response (0.1W @ 0.1 meter)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.
AST-03208MR-R
32mm Speaker
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
55°C with random humidity for 96 hours
Low Temperature
-20°C with random humidity for 96 hours
Humidity
40°C with 90% to 95% relative humidity for 96 hours
Vibration
1.5 mm movement modulated at 10 to 55 Hz for 2 hours
Drop Test
75 cm free fall onto 40 mm thick board, 10 cycles
Temperature Cycle Test
-20°C to 55°C, 5 cycles (refer to Temperature Cycle Test Graph)
After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement.
Wave Solder Profile
SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 0.1W/0.5M
(AT 1.2, 1.4, 1.6, 1.8 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.1
0.2
8 ± 20%
W
W
OHM
82 ± 3
dBA
5%
1,500 ± 20%
500 ~ 20,000
NORYL
MYLAR
NdFeB
-20 ~ +60
10
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
ADDED NOTE 4
REVISED MAGNET MATERIAL
7/8/2006
10/27/2008
1/5/2011
6/28/2011
B.R.
B.R.
C.W.
©2003, Projects Unlimited Inc.
Hz
Hz
+0.2
6 -0
°C
grams
15.1
1
P31.9
REMOVABLE
WASH TAB
17.53
P1 (2)
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
4. HAND SOLDER ONLY.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
AST-03208MR-R.idw
Designed by
Date
Checked by
Date
Approved by
B.R.
4/7/2006
B.R.
4/7/2006
E.P.
Date
Drawn Date
4/7/2006 10/27/2008
AST-03208MR-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AST-03208MR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+13.50511500+1.62610
