AS03208MS-3-R
AS03208MS-3-R
    PUIAUDIO
    SPEAKER3W8OHM85DB200HZ
AS03208MS-3-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Data Sheet AS03208MS-3-R PUI Audio’s AS03208MS-3-R packs a punch despite its 32 x 32 x 16.5mm size. A 3W nominal, 4W max power handling and great sensitivity combine to make for a small speaker that can output as much as 85 dB of sound at one meter! The flat 200 Hz to 20,000 Hz frequency response covers over 90% of the audio band, and high–end design—rubber surround and non-resonant frame—makes for a speaker that truly delivers high fidelity performance. Great for critical listening applications! Features: • IP65 rated speaker face • High 83 dB output at 1W/50cm • Neodymium motor • Only 16.5 mm thick • 1.5mm of excursion Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity (SPL @ 1W/50cm) (600, 800, 1000, and 1200 Hz) Distortion (Max @ 1W, 1 kHz) Resonant Frequency Frequency Range Housing Material Magnet Material Weight Environmental Protection Rating Values 3 4 8 ± 15% Units Watts Watts Ohms 83 ± 3
AS03208MS-3-R 价格&库存
很抱歉,暂时无法提供与“AS03208MS-3-R”相匹配的价格&库存,您可以联系我们找货
