11925SA-24Q-AL-00
11925SA-24Q-AL-00
    NMBTECHNOLOGIESCORPORATION
    FAN24VDC120X25MMLOCKROTOR
11925SA-24Q-AL-00 数据手册
11925SA (119 X 25L) .14 35 .12 30 In H.10 2O (Pa) 25 .16 .08 40 20 .14 .06 35 15 .12 .04 30 10 .10 .02 25 5 .08 0 20 0 Static Pressure Motor Protection: Auto Restart/Polarity Protection Insulation Resistance: Ps Static Pressure 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Ps -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .04 35.3 2100 900 L 1800 600 K K J 17.65 1500 300 J 1.50 M 1200 0 2.50 900 2.00 L J 52.95 70.6 100 .36 90 .32 80 In H2.28 O 70 (Pa) .24 .40 60 100 .20 .36 50 90 .16 .32 40 80 .12 Ps .28 30 70 .08 .24 20 60 .04 .20 10 50 .160 400 CFM 300 0.00 0.50 1.00 1.50 0.00 17.65 35.3 52.95 0 2.50 2.00 70.6 (m3/min) CFM 88.25 Static Pressure Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black Ps .12 30 .169 (4 – φ4.3) 4000 3600 R P-Q Curve Speed Curve INLET SIDE OUTLET SIDE 2000 3600 Q P Q 1200 2800 P 800 2400 0.00 .08 20 0.00 .04 10 0 0 0.50 1.00 17.65 1.50 35.3 400 2000 2.00 52.95 70.6 N R 2.50 Q 88.25 P 3.00 3.50 105.9 123.55 0 1600 4.00 1200 (m3/min) CFM 800 141.2 Air Flow 400 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 0.00 17.65 35.3 52.95 70.6 88.25 105.9 123.55 11.82 min (300) ROTATION 0 4.00 (m3/min) CFM 141.2 A 0.169 (8−φ4.3± 0.2) B AIR NAME PLATE B A 4.13 (105.0± 0.3) Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 11925SA-12J-EA-00 12 7.0 ~ 13.8 0.05 0.60 1300 46.9 1.33 0.06 14.0 20.5 140 11925SA-12K-EA-00 12 7.0 ~ 13.8 0.09 1.08 1600 57.5 1.63 0.08 21.0 26.5 140 11925SA-12L-EA-00 12 7.0 ~ 13.8 0.13 1.56 1900 67.1 1.90 0.11 28.5 30.0 140 11925SA-12M-EA-00 12 7.0 ~ 13.8 0.16 1.92 2200 79.4 2.25 0.15 38.0 33.5 140 11925SA-12N-EA-00 12 7.0 ~ 13.8 0.24 2.88 2500 91.1 2.58 0.19 48.0 37.0 140 11925SA-12P-EA-00 12 7.0 ~ 13.8 0.33 3.96 2800 102.0 2.89 0.24 60.5 40.5 140 11925SA-12Q-EA-00 12 7.0 ~ 13.8 0.47 5.64 3100 113.0 3.20 0.29 73.0 44.0 140 11925SA-12R-EA-00 12 7.0 ~ 13.2 0.62 7.44 3500 128.1 3.63 0.36 89.0 47.0 140 MODEL Rotation: Clockwise Input Speed 0.15 (4.0± 0.2) 0.98 (25.0± 0.5) 4.68 (119.0 ± 0.5) Current 1600 3200 R NN 4.13 (105.0± 0.3) 4.53 (115.0) 2800 2400 4000 R 4.68 (119.0± 0.5) 4.13 (105.0) 4.53 (115) 4.51 (114.5) P NO SOLDER Air Flow ) 96 .0 4. 26 1 (φ 4.13 (105.0) 3200 Q N-R N .169 (4 – φ4.3) 4.13 (105.0) N-R Speed Curve Outline Panel Cut-Outs ) 96 .0 4. 26 1 (φ P-Q Curve Speed Static Pressure Material (m3/min) 88.25 600 AirKFlow (Pa) .40 40,000 Hours (AA/EA) 4.13 (105.0) M L 10 0.00 0 1500 2400 1200 M 1.00 0 J-M Speed Curve J 0.50 5 1800 K 15 0.00 .02 2100 L P-Q Curve .06 In H2O Failure Rate: 10% 4.51 (114.5) 2400 M Air Flow Expected Life inch Units: (mm) J-M Speed Curve Speed 40 Speed .16 Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure (min-1)*1 CFM*1 (m3/min)*1 in H2O *1: Average Values in Free Air Noise (Pa)*1 (dB)*1 Mass (g) Note: PWM/Locked Rotor/Tach Available DC Axial Fans (Pa) Characteristic Curves General Specifications 60°C P-Q Curve 2 Speed NMBTC.COM / 248.919.2250In H O 11925SA (119 X 25L) NMBTC.COM / 248.919.2250 Specifications Operating Voltage (V) (V) 11925SA-24J-EA-00 24 11925SA-24K-EA-00 24 11925SA-24L-EA-00 Max. Max. Static Power Air Flow Pressure (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O 12.0 ~ 27.6 0.03 0.72 1300 46.9 1.33 0.06 14.0 20.5 140 12.0 ~ 27.6 0.04 0.96 1600 57.5 1.63 0.08 21.0 26.5 140 24 12.0 ~ 27.6 0.06 1.44 1900 67.1 1.90 0.11 28.5 30.0 140 11925SA-24M-EA-00 24 12.0 ~ 27.6 0.08 1.92 2200 79.4 2.25 0.15 38.0 33.5 140 11925SA-24N-EA-00 24 12.0 ~ 27.6 0.11 2.64 2500 91.1 2.58 0.19 48.0 37.0 140 11925SA-24P-EA-00 24 12.0 ~ 27.6 0.17 4.08 2800 102.0 2.89 0.24 60.5 40.5 140 11925SA-24Q-EA-00 24 12.0 ~ 27.6 0.20 4.80 3100 113.0 3.20 0.29 73.0 44.0 140 Rotation: Clockwise Current Airflow Outlet: Air Out Over Struts Input Speed *1: Average Values in Free Air Noise (Pa)*1 (dB)*1 Mass (g) Note: PWM/Locked Rotor/Tach Available DC Axial Fans Rated Voltage MODEL
11925SA-24Q-AL-00 价格&库存
很抱歉,暂时无法提供与“11925SA-24Q-AL-00”相匹配的价格&库存,您可以联系我们找货
