11925SA (119 X 25L)
.14
35
.12
30
In H.10
2O
(Pa)
25
.16
.08
40
.06
35
15
.12
.04
30
10
.10
.02
25
5
.08
Static Pressure
Motor Protection:
Auto Restart/Polarity Protection
Insulation Resistance:
Ps
Static Pressure
10M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Ps
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
.04
35.3
2100
900
L
1800
600
K
K
J
17.65
1500
300
J
1.50
M
1200
900
2.00
L
J
52.95
70.6
100
.36
90
.32
80
In H2.28
O
70
(Pa)
.24
.40
60
100
.20
.36
50
90
.16
.32
40
80
.12
Ps .28
30
70
.08
.24
.04
.20
10
50
.160
400
CFM
300
0.00
0.50
1.00
1.50
0.00
17.65
35.3
52.95
2.00
70.6
(m3/min)
CFM
88.25
Static Pressure
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
Ps .12
30
.169
(4 – φ4.3)
4000
3600
R
P-Q Curve
Speed Curve
INLET SIDE
OUTLET SIDE
2000
3600
Q
P
Q
1200
2800
P
800
2400
0.00
.08
20 0.00
.04
10
1.00
17.65
1.50
35.3
400
2000
2.00
52.95
70.6
N
R
2.50
Q
88.25
P
3.00
3.50
105.9
123.55
4.00
1200
(m3/min)
CFM
800
141.2
Air Flow
400
0.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
0.00
17.65
35.3
52.95
70.6
88.25
105.9
123.55
11.82
min (300)
ROTATION
(m3/min)
CFM
141.2
A
0.169
(8−φ4.3± 0.2)
B
AIR
NAME
PLATE
B
A
4.13
(105.0± 0.3)
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
11925SA-12J-EA-00
12
7.0 ~ 13.8
0.05
0.60
1300
46.9
1.33
0.06
14.0
20.5
140
11925SA-12K-EA-00
12
7.0 ~ 13.8
0.09
1.08
1600
57.5
1.63
0.08
21.0
26.5
140
11925SA-12L-EA-00
12
7.0 ~ 13.8
0.13
1.56
1900
67.1
1.90
0.11
28.5
30.0
140
11925SA-12M-EA-00
12
7.0 ~ 13.8
0.16
1.92
2200
79.4
2.25
0.15
38.0
33.5
140
11925SA-12N-EA-00
12
7.0 ~ 13.8
0.24
2.88
2500
91.1
2.58
0.19
48.0
37.0
140
11925SA-12P-EA-00
12
7.0 ~ 13.8
0.33
3.96
2800
102.0
2.89
0.24
60.5
40.5
140
11925SA-12Q-EA-00
12
7.0 ~ 13.8
0.47
5.64
3100
113.0
3.20
0.29
73.0
44.0
140
11925SA-12R-EA-00
12
7.0 ~ 13.2
0.62
7.44
3500
128.1
3.63
0.36
89.0
47.0
140
MODEL
Rotation: Clockwise
Input
Speed
0.15
(4.0± 0.2)
0.98
(25.0± 0.5)
4.68
(119.0 ± 0.5)
Current
1600
3200
R
NN
4.13
(105.0± 0.3)
4.53
(115.0)
2800
2400
4000
R
4.68
(119.0± 0.5)
4.13
(105.0)
4.53
(115)
4.51
(114.5)
P
NO SOLDER Air Flow
96 .0
4. 26
1
(φ
4.13
(105.0)
3200
Q
N-R
N
.169
(4 – φ4.3)
4.13
(105.0)
N-R
Speed Curve
Outline
Panel Cut-Outs
96 .0
4. 26
1
(φ
P-Q Curve
Speed
Static Pressure
Material
(m3/min)
88.25
600
AirKFlow
(Pa)
.40
40,000 Hours (AA/EA)
4.13
(105.0)
M
L
10 0.00
2400
1200
M
1.00
J-M
Speed Curve
J
0.50
5
1800
K
15 0.00
.02
2100
L
P-Q Curve
.06
In H2O
Failure Rate: 10%
4.51
(114.5)
2400
M
Air Flow
Expected Life
inch
Units: (mm)
J-M
Speed Curve
Speed
40
Speed
.16
Power
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
(min-1)*1 CFM*1 (m3/min)*1 in H2O
*1: Average Values in Free Air
Noise
(Pa)*1 (dB)*1
Mass
(g)
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
(Pa)
Characteristic Curves
General Specifications
60°C
P-Q Curve
2
Speed
NMBTC.COM / 248.919.2250In H O
11925SA (119 X 25L)
Specifications
Operating
Voltage
(V)
(V)
11925SA-24J-EA-00
24
11925SA-24K-EA-00
24
11925SA-24L-EA-00
Max.
Max. Static
Power
Air Flow
Pressure
(A)*1
(W)*1
12.0 ~ 27.6
0.03
0.72
1300
46.9
1.33
0.06
14.0
20.5
140
12.0 ~ 27.6
0.04
0.96
1600
57.5
1.63
0.08
21.0
26.5
140
24
12.0 ~ 27.6
0.06
1.44
1900
67.1
1.90
0.11
28.5
30.0
140
11925SA-24M-EA-00
24
12.0 ~ 27.6
0.08
1.92
2200
79.4
2.25
0.15
38.0
33.5
140
11925SA-24N-EA-00
24
12.0 ~ 27.6
0.11
2.64
2500
91.1
2.58
0.19
48.0
37.0
140
11925SA-24P-EA-00
24
12.0 ~ 27.6
0.17
4.08
2800
102.0
2.89
0.24
60.5
40.5
140
11925SA-24Q-EA-00
24
12.0 ~ 27.6
0.20
4.80
3100
113.0
3.20
0.29
73.0
44.0
140
Rotation: Clockwise
Current
Input
Speed
Noise
(Pa)*1 (dB)*1
Mass
(g)
DC Axial Fans
Rated
Voltage
MODEL
很抱歉,暂时无法提供与“11925SA-24J-EA-00”相匹配的价格&库存,您可以联系我们找货
