Mini Aluminum Heat Sink for Raspberry Pi - 13 x 13 x 3mm
PRODUCT ID: 3084
Description
Looking for an ultra-thin heat sink for your Raspberry Pi 3? Check out this nice and slim 13x13x3mm Heat Sink!
This heat sink is made from high quality aluminum and will work perfectly with any Raspberry Pi but is
best paired with a Raspberry Pi 3 since it can run a little hot. It comes with thermal adhesive already
applied to the back making installation super easy. Clean the surface of the chip of any dust or grease
then peel off the protective film and press the heat sink firmly onto the chip. You can use this heatsink
with any of our injection molded Adafruit Pi Enclosures, but it may not work with other enclosures and
some HATs may not fit on top with the heat sink installed.
We don't have formal specs for this heat sink, but when we ran 'stress -c 4' on the Pi 3 to run all 4 CPUs,
a heat-sink-less Pi quickly dropped down to 0.96 GHz to maintain thermal equilibrium. With this heat
sink installed, it could run at 1.02 GHz (so, 6% higher performance). It's a very minimal heatsink!
Note that you do not need a heatsink for the Pi 3, it will automatically adjust its speed to avoid
overheating! It can also, of course, be used for other processors and chips.
Technical Details
Product Dimensions: 13.0mm x 13.0mm x 3.3mm / 0.5" x 0.5" x 0.1"
Product Weight: 0.7g/0.0oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3084”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 90+12.4955290+1.51314
