Turbo Metal Gear Worm Motor (6V 40RPM 10kg/cm)
SKU:FIT0489-B
INTRODUCTION
The turbo metal gear worm motor uses a metal gear box for durability and a high torque output. Due to the special mechanical
structure of the worm drive the motor output shaft is self locking and can not be rotated.
(From wikipedia)
This part uses a two wire connection and supports direction control as well as PWM speed control. Rated voltage is 6v and will
achieve 40RPM, with a torque of 10kg/cm.
Warning: Do not stall motor for extended periods of time to avoid damage to the gearbox.
SPECIFICATION
Operating Voltage: 3 - 9 V
Rated Voltage: 6V
No-load Speed: 40 RPM
No-load Current: 40 mA
Rated Torque: 32 RPM
Rated Current: 250 mA
Rated Torque: 2.5 kg.cm
Rated Power: 1.3 W
Stall Torque: 10 kg/cm
Stall Current: 1.7 A
Reduction Ratio: 1:150
Weight: 160 g
SHIPPING LIST
Metal Turbo Worm Gear Motor (6V 40RPM 10kg.cm) x1
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1481.html 4-27-17
很抱歉,暂时无法提供与“FIT0489-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+244.19975
- 2+231.90192
- 3+231.02351
- 国内价格 香港价格
- 5+214.166765+25.87373
