Turbo Metal Gear Worm Motor (12V 160RPM 2.2kg.cm)
SKU:FIT0489-C
INTRODUCTION
The turbo metal gear worm motor uses a metal gear box for durability and a high torque output. Due to the special mechanical
structure of the worm drive the motor output shaft is self locking and can not be rotated.
(From wikipedia)
This part uses a two wire connection and supports direction control as well as PWM speed control. Rated voltage is 12v and will
achieve 160RPM, with a torque of 2.2kg/cm.
Warning: Do not stall motor for extended periods of time to avoid damage to the gearbox.
SPECIFICATION
Operating Voltage: 6 - 15 V
Rated Voltage: 12V
No-load Speed: 160 RPM
No-load Current: 35 mA
Rated Torque: 128 RPM
Rated Current: 180 mA
Rated Torque: 0.55 kg.cm
Rated Power: 1.1 W
Stall Torque: 2.2 kg/cm
Stall Current: 1 A
Reduction Ratio: 1:37.3
Weight: 165 g
SHIPPING LIST
Metal Turbo Worm Gear Motor (12V 160RPM 2.2kg.cm) x1
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1482.html 4-26-17
很抱歉,暂时无法提供与“FIT0489-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6+214.166766+25.87373
- 国内价格
- 1+226.63142
- 2+214.33360
