RAPC10PS
RAPC10PS
    SWITCHCRAFT
    CONN POWER JACK SOLDER
RAPC10PS 数据手册
8 7 6 5 4 3 2 1 PART NUMBER SEAL O-RING RAPC10 RAPC10S RAPC10P RAPC10PS RASPC10 RASPC10S RASPC10P RASPC10PS 0.95 24.2 F 0.47 11.9 0.125 3.18 MAXIMUM PANEL THICKNESS 0.08 [2.0mm] CENTER PIN 0.35 9.0 0.055 1.40 MOUNTING BUSHING 5/16-32 UNEF 2A THREAD SLEEVE TERMINAL 0.23 5.8 BUSHING I.D. E PCB LOCATING POST NO YES NO YES NO YES NO YES NO SILVER YES TIN YES CENTER PIN SHUNT 0.26 6.5 CENTER PIN TERMINAL SHUNT TERMINAL F NO 0.43 11.0 0.06 1.6 TERMINAL PLATING E SLEEVE SCHEMATIC 0.14 3.4 0.054 1.36 0.19 4.9 0.062 1.57 0.020 0.51 0.020 0.51 0.316±0.002 8.03±0.05 0.12 3.0 0.008 0.20 0.10 2.5 0.10 2.5 0.325 8.26 0.248 6.29 RAPC10PS SHOWN HERE D 0.19 4.8 0.290±0.002 7.37±0.05 0.349 8.87 D A 0.177 4.50 A A 0.248 6.29 0.248 6.29 JACK MOUNTING SURFACE 0.120 3.05 JACK MOUNTING SURFACE C 0.140 3.56 SLEEVE PIN 0.189 4.80 SHUNT 0.120 3.05 0.349 8.87 0.478 12.14 B RECOMMENDED PANEL CUT-OUT 0.177 4.50 0.040 1.02 SLEEVE 0.140 3.56 PIN SEAL O-RING NOT ALWAYS SUPPLIED SEE TABLE & NOTE 1 HEX NUT SEE NOTE 1 SHUNT 0.120 3.05 0.030 0.76 0.070 [1.78] MIN FOR CLEARANCE FIT 0.067 [1.70] MAX FOR INTERFERENCE FIT REQUIRED ONLY FOR JACKS WITH POST 0.349 8.87 0.120 3.05 PCB LOCATING POST NOT ALWAYS PRESENT SEE TABLE 0.478 12.14 ALTERNATE PCB LAYOUT RECOMMENDED PCB LAYOUT COMPONENT SIDE C 0.189 4.80 0.030 0.76 0.070 [1.78] MIN FOR CLEARANCE FIT 0.067 [1.70] MAX FOR INTERFERENCE FIT REQUIRED ONLY FOR JACKS WITH POST FLAT WASHER SEE NOTE 1 COMPONENT SIDE B SHUNT TERMINAL CENTER PIN TERMINAL SLEEVE SPRING TERMINAL NOTES: CUSTOMER DRAWING 1. HEX NUT, WASHER, AND O-RING (IF REQUIRED) SUPPLIED UNASSEMBLED. A THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. 2. MATERIAL: HOUSING, COVER: THERMOPLASTIC, BLACK MOUNTING BUSHING, HEX NUT: COPPER ALLOY, NICKEL PLATED CENTER PIN: COPPER ALLOY, NICKEL PLATED PIN AND SHUNT TERMINALS: COPPER ALLOY, SILVER OR TIN PLATED SLEEVE SPRING TERMINAL: SPRING COPPER ALLOY, SILVER OR TIN PLATED FLAT WASHER: STEEL, NICKEL PLATED O-RING: ELASTOMER, BLACK UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] 3. THESE PRODUCTS ARE RoHS COMPLIANT. 6 5 - THREE PLACE DECIMALS 0.005 [0.13] 10/05/16 PC TJK DATE DRAWN A 27139 04/29/13 PC TJK 02/16/12 ECO NUMBER DATE 4 BY APVD DO NOT SCALE DRAWING SolidWorks CAD File MULT NAME TEMPER BY A SPEC No. SCALE CHKD PNK PNK 02/16/12 4:1 APVD SRC 02/16/12 RA POWER JACKS, PC HIGH AMP, 0.08 [2.0mm] PIN, RoHS C LBS/M MATERIAL SPEC No. FIRST USED ON 27785 REVISIONS 7 0.02 [0.5] WIDTH FINISH B REV 8 - TWO PLACE DECIMALS SIZE SHEET PART No. 1 OF RA_PC10 SERIES 1 REV B
RAPC10PS 价格&库存
很抱歉,暂时无法提供与“RAPC10PS”相匹配的价格&库存,您可以联系我们找货
