8
7
6
5
4
3
2
1
PART NUMBER SEAL O-RING
RAPC10
RAPC10S
RAPC10P
RAPC10PS
RASPC10
RASPC10S
RASPC10P
RASPC10PS
0.95 24.2
F
0.47 11.9
0.125 3.18 MAXIMUM
PANEL THICKNESS
0.08 [2.0mm]
CENTER PIN
0.35 9.0
0.055 1.40
MOUNTING BUSHING
5/16-32 UNEF 2A THREAD
SLEEVE
TERMINAL
0.23 5.8
BUSHING I.D.
E
PCB LOCATING
POST
NO
YES
NO
YES
NO
YES
NO
YES
NO
SILVER
YES
TIN
YES
CENTER PIN
SHUNT
0.26 6.5
CENTER PIN
TERMINAL
SHUNT TERMINAL
F
NO
0.43 11.0
0.06 1.6
TERMINAL
PLATING
E
SLEEVE
SCHEMATIC
0.14 3.4
0.054 1.36
0.19 4.9
0.062 1.57
0.020 0.51
0.020 0.51
0.316±0.002 8.03±0.05
0.12 3.0
0.008 0.20
0.10 2.5
0.10 2.5
0.325 8.26
0.248 6.29
RAPC10PS SHOWN HERE
D
0.19 4.8
0.290±0.002 7.37±0.05
0.349 8.87
D
A
0.177 4.50
A
A
0.248 6.29
0.248 6.29
JACK MOUNTING SURFACE
0.120 3.05
C
0.140 3.56
SLEEVE
PIN
0.189 4.80
SHUNT
0.120 3.05
0.349 8.87
0.478 12.14
B
RECOMMENDED PANEL CUT-OUT
0.177 4.50
0.040 1.02
SLEEVE
0.140 3.56
PIN
SEAL O-RING
NOT ALWAYS SUPPLIED
SEE TABLE & NOTE 1
HEX NUT
SEE NOTE 1
SHUNT
0.120 3.05
0.030 0.76
0.070 [1.78] MIN FOR CLEARANCE FIT
0.067 [1.70] MAX FOR INTERFERENCE FIT
REQUIRED ONLY FOR JACKS WITH POST
0.349 8.87
0.120 3.05
PCB LOCATING POST
NOT ALWAYS PRESENT
SEE TABLE
0.478 12.14
ALTERNATE PCB LAYOUT
RECOMMENDED PCB LAYOUT
COMPONENT SIDE
C
0.189 4.80
0.030 0.76
FLAT WASHER
SEE NOTE 1
COMPONENT SIDE
B
SHUNT
TERMINAL
CENTER PIN
TERMINAL
SLEEVE SPRING
TERMINAL
NOTES:
CUSTOMER DRAWING
1. HEX NUT, WASHER, AND O-RING (IF REQUIRED) SUPPLIED UNASSEMBLED.
A
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
2. MATERIAL:
HOUSING, COVER: THERMOPLASTIC, BLACK
MOUNTING BUSHING, HEX NUT: COPPER ALLOY, NICKEL PLATED
CENTER PIN: COPPER ALLOY, NICKEL PLATED
PIN AND SHUNT TERMINALS: COPPER ALLOY, SILVER OR TIN PLATED
SLEEVE SPRING TERMINAL: SPRING COPPER ALLOY, SILVER OR TIN PLATED
FLAT WASHER: STEEL, NICKEL PLATED
O-RING: ELASTOMER, BLACK
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES [mm]
3. THESE PRODUCTS ARE RoHS COMPLIANT.
6
5
- THREE PLACE DECIMALS
0.005 [0.13]
10/05/16
PC
TJK
DATE DRAWN
A
27139
04/29/13
PC
TJK
02/16/12
ECO NUMBER
DATE
4
BY
APVD
DO NOT SCALE DRAWING
SolidWorks CAD File
MULT
NAME
TEMPER
BY
A
SPEC No.
SCALE
CHKD
PNK
PNK
02/16/12
4:1
APVD
SRC
02/16/12
RA POWER JACKS, PC
HIGH AMP, 0.08 [2.0mm] PIN, RoHS
C
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
27785
REVISIONS
7
0.02 [0.5]
WIDTH
FINISH
B
REV
8
- TWO PLACE DECIMALS
SIZE
SHEET
PART No.
1
OF
RA_PC10 SERIES
1
REV
B
很抱歉,暂时无法提供与“RAPC10P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+92.05621
- 2+76.09980
- 5+67.24487
- 20+66.80651
