1785-0003-TD
1785-0003-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMAJACKSTR50OHMEDGEMNT
1785-0003-TD 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 43089 DATE APPROVED 02/17 MAL MOUNTING SURFACE .312 7.92 .382 9.70 .184±.010 4.67±0.25 .180±.010 4.57±0.25 4X .020 X 45 .304 7.72 2X .070±.002 1.78±0.05 .185 4.70 .180 4.57 SOLDER .038±.001 0.97±0.03 2X .071±.002 1.80±0.05 MATERIAL: BODY: CONTACT & CONTACT SLEEVE: INSULATOR: BRASS PER ASTM B16, ALLOY UNS No. C36000 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 NOTES: 1. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) 2. TO BE TIN DIPPED USING Sn96 SOLDER 3. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY, CONTACT & CONTACT SLEEVE: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: MATERIAL: 50 OHMS DC TO 22.0 GHz 1000 VRMS FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VB 02/03/17 CHECKED: APPROVED: MAL 02/04/17 MAL 02/04/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA JACK END LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 1785-0003-TD SHEET 1 OF 1
1785-0003-TD 价格&库存
很抱歉,暂时无法提供与“1785-0003-TD”相匹配的价格&库存,您可以联系我们找货
