HGP.0E.650.CTLZ
HGP.0E.650.CTLZ
    LEMO(雷莫)
    CONN PNL RCPT TRIAX SKT SLDER
HGP.0E.650.CTLZ 数据手册
HGP.0E.650.CTLZ www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 0E Termination type Female solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.0E.650.CLAC10 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model *: Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 14.46 g Performance Configuration 0E.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Solder Vtest: 1200 V (AC), 1690 V (DC) Impedance: 50 Ohm VSWR: 1.03 + 0.34 * f/GHz Cable type: RGT 178, RGT 174 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr DRAWINGS RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
HGP.0E.650.CTLZ 价格&库存
很抱歉,暂时无法提供与“HGP.0E.650.CTLZ”相匹配的价格&库存,您可以联系我们找货
