HGP.3E.250.CLLPE
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
3E
Termination type
Female solder Coaxial
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
HGP*: Fixed receptacle, nut fixing, watertight or vacuum-tight
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
P : Watertight unmated
Weight
74.39 g
Performance
Configuration
3E.250 : 1 Coax (50 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
26 Amps
Specifications
Contact Type: Solder
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.06 + 0.5 * f/GHz
Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -20°C / +80°C
Humidity (max): 1000 hr
Pressure: 30 bars
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
31
34
15.5
39.5
6
22.5
30
M24x1.0
in.
1,22
1,34
0,61
1,56
0,24
0,89
1,18
RECOMMENDED BY LEMO
Tools
2/3
3/3
很抱歉,暂时无法提供与“HGP.3E.250.CLLPE”相匹配的价格&库存,您可以联系我们找货
