3287-4101-TD
3287-4101-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMPCB
3287-4101-TD 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 43145 DATE APPROVED 02/17 GPF 5X .290 7.37 4X .096 2.44 SOLDER .145 3.68 4X .042 1.07 .024 0.61 4X RP .020 0.51 4X .111±.002 2.82±0.05 MATERIAL: BODY & CONTACT: INSULATOR: 2X .100 2.54 BERYLLIUM COPPER PER ASTM-B-196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B NOTES: 1. CROSS HATCHED SURFACES TO BE PRE-TINNED USING SN96 SOLDER 2. ALL DIMENSIONS APPLY PRIOR TO PRE-TINNING. 3. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: MATERIAL: 50 OHMS DC TO 26.5 GHz 1.35:1 DC TO 26.5 GHz 325 VRMS -55 C TO +125 C FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VB CHECKED: APPROVED: GPF 02/24/17 GPF 02/24/17 02/24/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM ST. MALE SMOOTH BORE TO PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3287-4101-TD SHEET 1 OF 1
3287-4101-TD 价格&库存
很抱歉,暂时无法提供与“3287-4101-TD”相匹配的价格&库存,您可以联系我们找货
