3287-6100-TD
3287-6100-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSMD
3287-6100-TD 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 42490 DATE APPROVED 07/16 DAL RP .150 3.81 .067±.001 1.70±0.03 .009 0.23 B .085 2.16 .125 3.18 NOTE 2 3 NOTE 2 CONTACT & INSULATOR FLUSH TO .005 BELOW -B- A .030 0.76 SOLDER .012±.001 0.30±0.03 A .028±.001 0.71±0.03 NOTE 2 NOTES: 1. MATERIAL: BODY: STAINLESS STEEL CONTACT: BERYLLIUM COPPER INSULATOR: TORLON 2. 3. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) TO BE TIN DIPPED USING Sn96 SOLDER ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING FINISH: BODY & CONTACT: GOLD OVER NICKEL PERFORMANCE: .152 3.86 MATERIAL: FINISH: IMPEDANCE: FREQ. RANGE: VSWR: 50 OHMS DC TO 20.0 GHz. 1.20:1 DC TO 20.0 GHz. SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. PART NUMBER 3287-6100 3287-6101 DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 02/16/06 CHECKED: APPROVED: STW 02/16/06 STW 02/16/06 INTERFACE FULL DETENT SMOOTH BORE 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM MALE PC MOUNT WITH R/A CONTACT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 3287-610X-TD SHEET 1 OF 1
3287-6100-TD 价格&库存
很抱歉,暂时无法提供与“3287-6100-TD”相匹配的价格&库存,您可以联系我们找货
