1421-60014-TD
1421-60014-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMMAJACKSTR50OHMEDGEMNT
1421-60014-TD 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - .400 10.16 DCN 42247 .100 2.54 DATE APPROVED 05/16 DAL .240 6.10 .238 6.03 FOR .068" THICK BOARD MATERIAL: BODY & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND A CENTER CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 SPRING CONTACT: BERYLLIUM COPPER ALLOY 25, 1/4 HARD SHIM SPRING: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17200, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B 2X.160 4.06 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: INSERT: PASSIVATED PER AMS-2700 BODY & CONTACTS: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: PERFORMANCE: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 18.0 GHz. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 05/13/16 CHECKED: APPROVED: DAL 05/13/16 DAL 05/13/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMMA JACK EDGE LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 1421-60014 SHEET 1 OF 1
1421-60014-TD 价格&库存
很抱歉,暂时无法提供与“1421-60014-TD”相匹配的价格&库存,您可以联系我们找货
