AT25SL641-MHE-T
AT25SL641-MHE-T
    ADESTO
    UDFN8_EP
    8-UDFN(5X6),INDTEMP,1.8V,T&R
AT25SL641-MHE-T 数据手册
AT25SL641 64-Mbit, 1.7V Minimum SPI Serial Flash Memory with Dual I/O, Quad I/O and QPI Support Features Single 1.7V - 2.0V Supply Serial Peripheral Interface (SPI) and Quad Peripheral Interface (QPI) Compatible Supports SPI Modes 0 and 3 Supports Dual Output Read and Quad I/O Program and Read Supports QPI Program and Read 133 MHz Maximum Operating Frequency Clock-to-Output (tV1) of 6 ns Up to 66 MB/s Continuous Data Transfer Rate Full Chip Erase Flexible, Optimized Erase Architecture for Code and Data Storage Applications 0.6 ms Typical Page Program (256 Bytes) Time 60 ms Typical 4-Kbyte Block Erase Time 200 ms Typical 32-Kbyte Block Erase Time 350 ms Typical 64-Kbyte Block Erase Time Hardware Controlled Locking of Status Registers via WP Pin 4 Kbit secured One-Time Programmable Security Register Hardware Write Protection Serial Flash Discoverable Parameters (SFDP) Register Flexible Programming Byte/Page Program (1 to 256 Bytes) Dual or Quad Input Byte/Page Program (1 to 256 Bytes) Erase/Program Suspend and Resume JEDEC Standard Manufacturer and Device ID Read Methodology Low Power Dissipation 2 µA Deep Power-Down Current (Typical) 10 µA Standby current (Typical) 5 mA Active Read Current (Typical) Endurance: 100,000 program/erase cycles (4KB, 32KB or 64KB blocks) Data Retention: 20 Years Industrial Temperature Range: -40°C to +85°C Industry Standard Green (Pb/Halide-free/RoHS Compliant) Package Options 8-lead SOIC (208-mil) 8-pad DFN (6 x 5 x 0.6 mm) 8-ball WLCSP (dBGA) Die in Wafer Form DS-25SL641–113F–12/2018 1. Introduction The Adesto® AT25SL641 is a serial interface Flash memory device designed for use in a wide variety of high-volume consumer based applications in which program code is shadowed from Flash memory into embedded or external RAM for execution. The flexible erase architecture of the AT25SL641 is ideal for data storage as well, eliminating the need for additional data storage devices. The erase block sizes of the AT25SL641 have been optimized to meet the needs of today's code and data storage applications. By optimizing the size of the erase blocks, the memory space can be used much more efficiently. Because certain code modules and data storage segments must reside by themselves in their own erase regions, the wasted and unused memory space that occurs with large block erase Flash memory devices can be greatly reduced. This increased memory space efficiency allows additional code routines and data storage segments to be added while still maintaining the same overall device density. SPI clock frequencies of up to 133 MHz are supported allowing equivalent clock rates of 266 MHz for Dual Output and 532 MHz for Quad Output when using the QPI and Fast Read Dual/Quad I/O instructions.The AT25SL641 array is organized into 32,768 programmable pages of 256-bytes each. Up to 256 bytes can be programmed at a time using the Page Program instructions. Pages can be erased 4KB Block, 32KB Block, 64KB Block or the entire chip. The devices operate on a single 1.7V to 1.95V power supply with current consumption as low as 5 mA active and 2 µA for Deep Power Down. All devices offered in space-saving packages. The device supports JEDEC standard manufacturer and device identification with a 4 Kbit Secured OTP. AT25SL641 DS-25SL641–113F–12/2018 2 2. Pinouts and Pin Descriptions The following figures show the available package types. Figure 1-1. 8-SOIC (Top View) Figure 1-2. 8-UDFN (Top View) CS 1 8 VCC HOLD (I/O3) SO (I/O 1) 2 7 HOLD (I/O 3 ) 6 SCK WP (I/O 2) 3 6 SCK 5 SI (I/O0) GND 4 5 SI (I/O 0) CS 1 8 VCC SO (I/O1) 2 7 WP (I/O2) 3 GND 4 Figure 1-3. 8-WLCSP (Bottom View) NC NC CS I/O1(SO) NC Vcc I/O3(HOLD) I/O2(WP) SCK GND I/O0(SI) NC During all operations, VCC must be held stable and within the specified valid range: VCC (min) to VCC (max). All of the input and output signals must be held high or low (according to voltages of VIH, VOH, VIL or VOL. AT25SL641 DS-25SL641–113F–12/2018 3 Table 1-1. Pin Descriptions Symbol CS Name and Function CHIP SELECT Asserted State Type Low Input - Input - Input/Output - Input/Output - Input/Output When this input signal is high, the device is deselected and serial data output pins are at high impedance. Unless an internal program, erase or write status register cycle is in progress, the device will be in the standby power mode (this is not the deep power down mode). Driving Chip Select (CS) low enables the device, placing it in the active power mode. After power-up, a falling edge on Chip Select (CS) is required prior to the start of any instruction. SCK SERIAL CLOCK This input signal provides the timing for the serial interface. Instructions, addresses, or data present at serial data input are latched on the rising edge of Serial Clock (SCK). Data are shifted out on the falling edge of the Serial Clock (SCK). SI (I/O0) SERIAL INPUT The SI pin is used to shift data into the device. The SI pin is used for all data input including command and address sequences. Data on the SI pin is always latched in on the rising edge of SCK. With the Dual-Output and Quad-Output Read commands, the SI Pin becomes an output pin (I/O0) in conjunction with other pins to allow two or four bits of data on (I/O3-0) to be clocked in on every falling edge of SCK To maintain consistency with the SPI nomenclature, the SI (I/O0) pin is referenced as the SI pin unless specifically addressing the Dual-I/O and Quad-I/O modes in which case it is referenced as I/O0. Data present on the SI pin is ignored whenever the device is deselected (CS is deasserted). SO (I/O1) SERIAL OUTPUT The SO pin is used to shift data out from the device. Data on the SO pin is always clocked out on the falling edge of SCK. With the Dual-Output Read commands, the SO Pin remains an output pin (I/O0) in conjunction with other pins to allow two bits of data on (I/O1-0) to be clocked in on every falling edge of SCK To maintain consistency with the SPI nomenclature, the SO (I/O1) pin is referenced as the SO pin unless specifically addressing the Dual-I/O modes in which case it is referenced as I/O1. The SO pin is in a high-impedance state whenever the device is deselected (CS is deasserted). WP (I/O2) WRITE PROTECT The Write Protect (WP) pin can be used to protect the Status Register against data modification. Used in company with the Status Register's Block Protect (SEC, TB, BP2, BP1 and BP0) bits and Status Register Protect SRP) bits, a portion or the entire memory array can be hardware protected. The WP pin is active low. When the QE bit of Status Register-2 is set for Quad I/O, the WP pin (Hardware Write Protect) function is not available since this pin is used for IO2. See figures 1-1, 1-2, and 1-3 for the pin configuration of Quad I/O and QPI operation. AT25SL641 DS-25SL641–113F–12/2018 4 Table 1-1. Pin Descriptions (Continued) Symbol Name and Function HOLD HOLD (I/O3) The HOLD pin is used to temporarily pause serial communication without deselecting or resetting the device. While the HOLD pin is asserted, transitions on the SCK pin and data on the SI pin are ignored and the SO pin is placed in a high-impedance state. Asserted State Type - Input/Output The CS pin must be asserted, and the SCK pin must be in the low state in order for a Hold condition to start. A Hold condition pauses serial communication only and does not have an effect on internally self-timed operations such as a program or erase cycle. With the Quad-Input Byte/Page Program command, the HOLD pin becomes an input pin (I/O3) and with other pins, allows four bits (on I/O3-0) of data to be clocked in on every rising edge of SCK. With the Quad-Output Read commands, the HOLD Pin becomes an output pin (I/O3) in conjunction with other pins to allow four bits of data on (I/O33-0) to be clocked in on every falling edge of SCK. To maintain consistency with SPI nomenclature, the HOLD (I/O3) pin is referenced as the HOLD pin unless specifically addressing the Quad-I/O modes in which case it is referenced as I/O3. The HOLD pin is internally pulledhigh and may be left floating if the Hold function is not used. However, it is recommended that the HOLD pin also be externally connected to VCC whenever possible. See figures 11, 1-2, and 1-3 for the pin configuration of Quad I/O and QPI operation. VCC DEVICE POWER SUPPLY: VCC is the supply voltage. It is the single voltage used for all device functions including read, program, and erase. The VCC pin is used to supply the source voltage to the device. Operations at invalid VCC voltages may produce spurious results and should not be attempted. - Power GND GROUND: VSS is the reference for the VCC supply voltage. The ground reference for the power supply. GND should be connected to the system ground. - Power AT25SL641 DS-25SL641–113F–12/2018 5 Block Diagram Figure 2-1 shows a block diagram of the AT25SL641 serial Flash. Figure 2-1. AT25SL641 Block Diagram Control and Protection Logic CS I/O Buffers and Latches SRAM Data Buffer SCK SI (I/O0) SO (I/O1) WP (I/O2) Interface Control And Logic Address Latch 2. Y-Decoder Y-Gating X-Decoder Flash Memory Array HOLD (I/O3) Note: I/O3-0 pin naming convention is used for Dual-I/O and Quad-I/O commands. AT25SL641 DS-25SL641–113F–12/2018 6 Memory Array To provide the greatest flexibility, the memory array of the AT25SL641 can be erased in four levels of granularity including a full chip erase. The size of the erase blocks is optimized for both code and data storage applications, allowing both code and data segments to reside in their own erase regions. The Memory Architecture Diagram illustrates the breakdown of each erase level. Figure 3-1. Memory Architecture Diagram 32KB 32KB 64KB 32KB 32KB 64KB ••• 32KB 32KB 64KB 32KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB Block Address Range 7F F F F F h 7F E F F F h 7F DF F F h 7F CF F F h 7F BF F F h 7F AF F F h 7F 9F F F h 7F 8F F F h 7F 7F F F h 7F 6F F F h 7F 5F F F h 7F 4F F F h 7F 3F F F h 7F 2F F F h 7F 1F F F h 7F 0F F F h 7E F F F F h 7E E F F F h 7E DF F F h 7E CF F F h 7E BF F F h 7E AF F F h 7E 9F F F h 7E 8F F F h 7E 7F F F h 7E 6F F F h 7E 5F F F h 7E 4F F F h 7E 3F F F h 7E 2F F F h 7E 1F F F h 7E 0F F F h – 7F F 000h – 7F E 000h – 7F D000h – 7F C000h – 7F B000h – 7F A000h – 7F 9000h – 7F 8000h – 7F 7000h – 7F 6000h – 7F 5000h – 7F 4000h – 7F 3000h – 7F 2000h – 7F 1000h – 7F 0000h – 7E F 000h – 7E E 000h – 7E D000h – 7E C000h – 7E B000h – 7E A000h – 7E 9000h – 7E 8000h – 7E 7000h – 7E 6000h – 7E 5000h – 7E 4000h – 7E 3000h – 7E 2000h – 7E 1000h – 7E 0000h 00F F F F h 00E F F F h 00DF F F h 00CF F F h 00BF F F h 00AF F F h 009F F F h 008F F F h 007F F F h 006F F F h 005F F F h 004F F F h 003F F F h 002F F F h 001F F F h 000F F F h – 00F 000h – 00E 000h – 00D000h – 00C000h – 00B000h – 00A000h – 009000h – 008000h – 007000h – 006000h – 005000h – 004000h – 003000h – 002000h – 001000h – 000000h ••• 64KB Page Program Detail 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 4KB 1-256 byte 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes Page Address Range 7F F F F F h 7F F E F F h 7F F DF F h 7F F CF F h 7F F BF F h 7F F AF F h 7F F 9F F h 7F F 8F F h 7F F 7F F h 7F F 6F F h 7F F 5F F h 7F F 4F F h 7F F 3F F h 7F F 2F F h 7F F 1F F h 7F F 0F F h 7F E F F F h 7F E E F F h 7F E DF F h 7F E CF F h 7F E BF F h 7F E AF F h 7F E 9F F h 7F E 8F F h – 7F F F 00h – 7F F E 00h – 7F F D00h – 7F F C00h – 7F F B00h – 7F F A00h – 7F F 900h – 7F F 800h – 7F F 700h – 7F F 600h – 7F F 500h – 7F F 400h – 7F F 300h – 7F F 200h – 7F F 100h – 7F F 000h – 7F E F 00h – 7F E E 00h – 7F E D00h – 7F E C00h – 7F E B00h – 7F E A00h – 7F E 900h – 7F E 800h 0017F F h 0016F F h 0015F F h 0014F F h 0013F F h 0012F F h 0011F F h 0010F F h 000F F F h 000E F F h 000DF F h 000CF F h 000BF F h 000AF F h 0009F F h 0008F F h 0007F F h 0006F F h 0005F F h 0004F F h 0003F F h 0002F F h 0001F F h 0000F F h – 001700h – 001600h – 001500h – 001400h – 001300h – 001200h – 001100h – 001000h – 000F 00h – 000E 00h – 000D00h – 000C00h – 000B00h – 000A00h – 000900h – 000800h – 000700h – 000600h – 000500h – 000400h – 000300h – 000200h – 000100h – 000000h ••• Block Erase Detail ••• 3. 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes 256 bytes AT25SL641 DS-25SL641–113F–12/2018 7 4. Device Operation 4.1 Standard SPI Operation The AT25SL641 features a serial peripheral interface on four signals: Serial Clock (SCK). Chip Select (CS), Serial Data Input (SI) and Serial Data Output (SO). Standard SPI instructions use the SI input pin to serially write instructions, addresses or data to the device on the rising edge of SCK. The SO output pin is used to read data or status from the device on the falling edge of SCK. SPI bus operation Modes 0 (0, 0) and 3 (1, 1) are supported. The primary difference between Mode 0 and Mode 3 concerns the normal state of the SCK signal when the SPI bus master is in standby and data is not being transferred to the Serial Flash. For Mode 0 the SCK signal is normally low on the falling and rising edges of CS. For Mode 3 the SCK signal is normally high on the falling and rising edges of CS. 4.2 Dual SPI Operation The AT25SL641 supports Dual SPI operation. This instruction allows data to be transferred to or from the device at two times the rate of the standard SPI. The Dual Read instruction is ideal for quickly downloading code to RAM upon powerup (code-shadowing) or for executing non-speed- critical code directly from the SPI bus (XIP). When using Dual SPI instructions the SI and SO pins become bidirectional I/0 pins; IO0 and IO1. 4.3 Quad SPI Operation The AT25SL641 supports Quad SPI operation. This instruction allows data to be transferred to or from the device at four times the rate of the standard SPI. The Quad Read instruction offers a significant improvement in continuous and random access transfer rates allowing fast code- shadowing to RAM or execution directly from the SPI bus (XIP). When using Quad SPI instruction the SI and SO pins become bidirectional IO0 and IO1, and the WP and HOLD pins become IO2 and IO3 respectively. Quad SPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set. 4.4 QPI Operation The AT25SL641 supports Quad Peripheral Interface (QPI) operation when the device is switched from Standard/Dual/ Quad SPI mode to QPI mode using the Enable QPI (38h) instruction. To enable QPI mode, the non-volatile Quad Enable bit (QE) in Status Register-2 is required to be set. When using QPI instructions, the SI and SO pins become bidirectional IO0 and IO1, and the WP and HOLD pins become IO2 and IO3 respectively. The typical SPI protocol requires that the byte-long instruction code being shifted into the device only via SI pin in eight serial clocks. The QPI mode utilizes all four I/O pins to input the instruction code, thus only two serial clocks are required. This can significantly reduce the SPI instruction overhead and improve system performance in an XIP environment. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given time. The enable QPI (38h) and Disable QPI/ Disable QPI 2 (FFh) instructions are used to switch between these two modes. Upon power-up or after software reset using the Reset (99h) instruction, the default state of the device is Standard/Dual/Quad SPI mode. AT25SL641 DS-25SL641–113F–12/2018 8 5. Write Protection To protect inadvertent writes by the possible noise, several means of protection are applied to the Flash memory. 5.1 Write Protect Features While Power-on reset, all operations are disabled and no instruction is recognized. An internal time delay of tPUW can protect the data against inadvertent changes while the power supply is outside the operating specification. This includes the Write Enable, Page program, Block Erase, Chip Erase, Write Security Register and the Write Status Register instructions. For data changes, Write Enable instruction must be issued to set the Write Enable Latch (WEL) bit to “0”. Powerup, Completion of Write Disable, Write Status Register, Page program, Block Erase and Chip Erase are subjected to this condition. Using setting the Status Register protect (SRP) and Block protect (SEC, TB, BP2, BP1, and BP0) bits a portion of memory can be configured as reading only called software protection. Write Protect (WP) pin can control to change the Status Register under hardware control. The Deep Power Down mode provides extra protection from unexpected data changes as all instructions are ignored under this status except for Release Deep Power Down instruction. AT25SL641 DS-25SL641–113F–12/2018 9 6. Status Register The Read Status Register instruction can be used to provide status on the availability of the Flash memory array, if the device is write enabled or disabled the state of write protection and the Quad SPI setting. The Write Status Register instruction can be used to configure the devices writes protection features and Quad SPI setting. Write access to the Status Register is controlled by in some cases of the WP pin. Table 6-1. Status Register-1 S7 S6 S5 S4 S3 S2 S1 S0 SRP0 SEC TB BP2 BP1 BP0 WEL BUSY Write Enable Latch Erase or Write in Progress Status Sector Protect Top/Bottom Block Protect Block Protect Block Protect Register (Non- Volatile) Write Protect (Non- Volatile) (Non- Volatile) (Non- Volatile) Protect 0 (Non- Volatile) (Non- Volatile) Table 6-2. 6.1 Status Register-2 S15 S14 S13 S12 S11 S10 S9 S8 SUS CMP (R) (R) (R) (R) QE SRP1 Suspend Status Complement Protect (NonVolatile) Reserved Reserved Reserved Reserved Quad Enable (Non- Volatile) Register Protect 1 (Non-Volatile) Busy BUSY is a read only bit in the status register (S0) that is set to a 1 state when the device is executing a Page Program, Erase, Write Status Register or Write Security Register instruction. During this time the device will ignore further instruction except for the Read Status Register and Erase / Program Suspend instruction (see tW, tPP, tSE, tBE1, tBE2 and tCE in AC Characteristics). When the Program, Erase, Write Status Register or Write Security Register instruction has completed, the BUSY bit is cleared to a 0 state indicating the device is ready for further instructions. 6.2 Write Enable Latch (WEL) Write Enable Latch (WEL) is a read only bit in the status register (S1) that is set to a 1 after executing a Write Enable instruction. The WEL status bit is cleared to a 0 when device is write disabled. A write disable state occurs upon power-up or after any of the following instructions: Write Disable, Page Program, Erase and Write Status Register. 6.3 Block Protect Bits (BP2, BP1, BP0) The Block Protect Bits (BP2, BP1, BP0) are non-volatile read/write bits in the status register (S4, S3, and S2) that provide write protection control and status. Block protect bits can be set using the Write Status Register Instruction (see tW in AC characteristics). All, none or a portion of the memory array can be protected from Program and Erase instructions (see Status Register Memory Protection table). The factory default setting for the Block Protection Bits is 0, none of the array protected. 6.4 Top/Bottom Block protect (TB) The Top/Bottom bit (TB) is non-volatile bits in the status register (S5) that controls if the Block Protect Bits (BP2, BP1, BP0) protect from the Top (TB = 0) or the Bottom (TB = 1) of the array as shown in the Status Register Memory Protection table. The factory default setting is TB = 0. The TB bit can be set with the Write Status Register Instruction depending on the state of the SRP0, SRP1 and WEL bits. AT25SL641 DS-25SL641–113F–12/2018 10 6.5 Sector/Block Protect (SEC) The Sector protect bit (SEC) is non-volatile bits in the status register (S6) that controls if the Block Protect bits (BP2, BP1, BP0) protect 4KB Sectors (SEC = 1) or 64KB blocks (SEC = 0) in the Top (TB = 0) or the Bottom (TB = 1) of the array as shown in the Status Register Memory protection table. The default setting is SEC = 0. 6.6 Status Register Protect (SRP1, SRP0) The Status Register Protect bits (SRP1 and SRP0) are non-volatile read/write bits in the status register (S8 and S7). The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable (OTP) protection. Table 6-3. Status Register Protection Status Register SRP1 SRP0 WP Description 0 0 X Software Protected WP pin no control. The register can be written to after a Write Enable instruction, WEL = 1. [Factory Default] 0 1 0 Hardware Protected When WP pin is low the Status Register locked and can not be written to. 0 1 1 Hardware Unprotected 1 0 X Power Supply Lock-Down 1 1 X When WP pin is high the Status register is unlocked and can be written to after a Write Enable instruction, WEL = 1. Status Register is protected and cannot be written to again until the next power down, power-up cycle (Note 1). One Time Program Status Register is permanently protected and cannot be written to. Note: 1. When SRP1, SRP0 = (1,0), a power down, power-up cycle changes SRP1, SRP0 to the (0,0) state. 6.7 Quad Enable (QE) The Quad Enable (QE) bit is a non-volatile read/write bit in the status register (S9) that allows Quad operation. When the QE bit is set to a 0 state (factory default) the WP pin and HOLD are enabled. When the QE pin is set to a 1 the Quad IO2 and IO3 pins are enabled. WARNING: The QE bit should never be set to a 1 during standard SPI or Dual SPI operation if the WP or HOLD pins are tied directly to the power supply or ground. 6.8 Complement Protect (CMP) The Complement Protect bit (CMP) is a non-volatile read/write bit in the status register (S14). It is used in conjunction with SEC, TB, BP2, BP1 and BP0 bits to provide more flexibility for the array protection. Once CMP is set to 1, previous array protection set by SEC, TB, BP2, BP1 and BP0 are reversed. For instance, when CMP = 0, a top 4KB sector can be protected while the rest of the array is not; when CMP = 1, the top 4KB sector will become unprotected while the rest of the array become read-only. Please refer to the Status Register Memory Protection table for details. The default setting is CMP = 0. 6.9 Erase/Program Suspend Status (SUS) The Suspend Status bit (SUS) is a read only bit in the status register (S15) that is set to 1 after executing an Erase/Program Suspend (75h) instruction. The SUS status bit is cleared to 0 by Erase/Program Resume (7Ah) instruction as well as a power down, power-up cycle. AT25SL641 DS-25SL641–113F–12/2018 11 Table 6-4. Status Register Memory Protection (CMP = 0) Status Register Bits Memory Protection SEC TB BP2 BP1 BP0 Sector(s) Addresses Density Portion X X 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 126 and 127 7E0000h - 7FFFFFh 128KB Upper 1/64 0 0 0 1 0 124 - 127 7C0000h - 7FFFFFh 256KB Upper 1/32 0 0 0 1 1 120 - 127 780000h - 7FFFFFh 512KB Upper 1/16 0 0 1 0 0 112 - 127 700000h - 7FFFFFh 1MB Upper 1/8 0 0 1 0 1 96 - 127 600000h - 7FFFFFh 2MB Upper 1/4 0 0 1 1 0 64 - 127 400000h - 7FFFFFh 4MB Upper 1/2 0 1 0 0 1 0 and1 000000h - 01FFFFh 128KB Lower 1/64 0 1 0 1 0 0-3 000000h - 03FFFFh 256KB Lower 1/32 0 1 0 1 1 0-7 000000h - 07FFFFh 512KB Lower 1/16 0 1 1 0 0 0 - 15 000000h - 0FFFFFh 1MB Lower 1/8 0 1 1 0 1 0 - 31 000000h - 1FFFFFh 2MB Lower 1/4 0 1 1 1 0 0 - 63 000000h - 3FFFFFh 4MB Lower 1/2 X X 1 1 1 0 - 127 000000h - 7FFFFFh 8MB ALL 1 0 0 0 1 127 7FF000h - 7FFFFFh 4KB U – 1/2048 1 0 0 1 0 127 7FE000h - 7FFFFFh 8KB U – 1/1024 1 0 0 1 1 127 7FC000h - 7FFFFFh 16KB U – 1/512 1 0 1 0 X 127 7F8000h - 7FFFFFh 32KB U – 1/256 1 1 0 0 1 0 000000h - 000FFFh 4KB L – 1/2048 1 1 0 1 0 0 000000h - 001FFFh 8KB L – 1/1024 1 1 0 1 1 0 000000h - 003FFFh 16KB L – 1/512 1 1 1 0 X 0 000000h - 007FFFh 32KB L – 1/256 Note: 1. X = Don’t care 2. L = Lower; U = Upper 3. If any Erase or Program instruction specifies a memory region that contains protected data portion, this instruction will be ignored. 4. Note 3 does not apply to this Status Register Bit setting. See Errata 1 in Appendix A for details. AT25SL641 DS-25SL641–113F–12/2018 12 Table 6-5. Status Register Memory Protection (CMP = 1) Status Register Bits Memory Protection SEC TB BP2 BP1 BP0 Sector(s) Addresses Density Portion X X 0 0 0 0 - 127 000000h - 7FFFFFh 8MB ALL 0 0 0 0 1 0 - 125 000000h – 7DFFFFh 8,064KB Lower 63/64 0 0 0 1 0 0 and 121 000000h – 7BFFFFh 7,936KB Lower 31/32 0 0 0 1 1 0 - 119 000000h – 77FFFFh 7,680KB Lower 15/16 0 0 1 0 0 0 - 111 000000h – 6FFFFFh 7,168KB Lower 7/8 0 0 1 0 1 0 - 95 000000h – 5FFFFFh 6MB Lower 3/4 0 0 1 1 0 0 - 63 000000h – 3FFFFFh 4MB Lower 1/2 0 1 0 0 1 2 - 127 020000h - 7FFFFFh 8,064KB Upper 63/64 0 1 0 1 0 4 and 127 040000h - 7FFFFFh 7,936KB Upper 31/32 0 1 0 1 1 8 - 127 080000h - 7FFFFFh 7,680KB Upper 15/16 0 1 1 0 0 16 - 127 100000h - 7FFFFFh 7,168KB Upper 7/8 0 1 1 0 1 32 - 127 200000h - 7FFFFFh 6MB Upper 3/4 0 1 1 1 0 64 - 127 400000h - 7FFFFFh 4MB Upper 1/2 X X 1 1 1 NONE NONE NONE NONE 1 0 0 0 1 0 - 127 000000h - 7FEFFFh 8,188KB L – 2047/2048 1 0 0 1 0 0 - 127 000000h - 7FDFFFh 8,184KB L – 1023/1024 1 0 0 1 1 0 - 127 000000h - 7FBFFFh 8,176KB L – 511/512 1 0 1 0 X 0 - 127 000000h - 7F7FFFh 8,160KB L – 255/256 1 1 0 0 1 0 - 127 001000h - 7FFFFFh 8,188KB U – 2047/2048 (4) 1 1 0 1 0 0 - 127 002000h - 7FFFFFh 8,184KB U – 1023/1024 1 1 0 1 1 0 - 127 004000h - 7FFFFFh 8,176KB U – 511/512 1 1 1 0 X 0 - 127 008000h - 7FFFFFh 8,160KB U – 255/256 Note: 1. X = don’t care 2. L = Lower; U = Upper 3. If any Erase or Program instruction specifies a memory region that contains protected data portion, this instruction will be ignored. 4. Note 3 does not apply to this Status Register Bit setting. See Errata 2 in Appendix A for details. AT25SL641 DS-25SL641–113F–12/2018 13 7. Instructions The SPI instruction set of the AT25SL641 consists of thirty eight basic instructions and the QPI instruction set of the AT25SL641 consists of thirty one basic instructions that are fully controlled through the SPI bus (see Instruction Set table). Instructions are initiated with the falling edge of Chip Select (CS) and are completed with the rising edge of edge CS. The first byte of data clocked into the input pins (SI or IO3:0) provides the instruction code. Data on the SI input is sampled on the rising edge of clock with most significant bit (MSB) first. Clock relative timing diagrams are included for each instruction below. All read instructions can be completed after any clocked bit. However, all instructions that Write, Program or Erase must complete on a byte boundary (CS driven high after a full 8-bit have been clocked), otherwise the instruction will be terminated. This feature further protects the device from inadvertent writes. Additionally, while the memory is being programmed or erased, or when the Status Register is being written, all instructions except for Read Register will be ignored until the program or erase cycle has completed. Table 7-1. Manufacturer and Device Identification ID code 7.1 Instruction Manufacturer ID Adesto 1Fh 90h, 92h, 94h, 9Fh Device ID AT25SL641 16h 90h, 92h, 94h, ABh Memory Type ID SPI / QPI 43h 9Fh Capacity Type ID 64M 17h 9Fh Instruction Set Tables Table 7-2. Instruction Set Table 1 (SPI Instructions) Instruction Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 (Clock Number) (0 - 7) (8 - 15) (16 - 23) (24 - 31) (32 - 39) (40 - 47) Write Enable 06h Write Enable For Volatile Status Register 50h Write Disable 04h Read Status Register-1 05h (SR7-SR0)(2) Read Status Register-2 35h (SR15-SR8)(2) Write Status Register-1 01h (SR7-SR0) Write Status Register-2 31h (SR15-SR8) Read Data 03h A23-A16 A15-A8 A7-A0 (D7-D0) Fast Read Data 0Bh A23-A16 A15-A8 A7-A0 dummy Page Program 02h Enable QPI 38h Block Erase (4KB) (SR15-SR8) A23-A16 A15-A8 A7-A0 20h A23-A16 A15-A8 A7-A0 Block Erase (32KB) 52h A23-A16 A15-A8 A7-A0 Block Erase (64KB) D8h A23-A16 A15-A8 A7-A0 Chip Erase 60h/C7h (D7-D0) (3) (D7-D0) AT25SL641 DS-25SL641–113F–12/2018 14 Table 7-2. Instruction Set Table 1 (SPI Instructions) (Continued) Instruction Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 (Clock Number) (0 - 7) (8 - 15) (16 - 23) (24 - 31) (32 - 39) (40 - 47) Erase/Program Suspend 75h Erase/Program Resume 7Ah Deep Power Down B9h Release Deep Power Down/Device ID(4) ABh dummy dummy dummy (ID7-ID0)(2) Read Manufacturer/ Device ID(4) 90h 00h 00h 00h or 01h (MID7MID0) (DID7-DID0) Read JEDEC ID 9Fh (MID7-MID0) (Manufacturer) (D7-D0) (Memory Type) (D7-D0) (Capacity Type) Reset Enable 66h Reset 99h Enter Secured OTP B1h Exit Secured OTP C1h Read Security Register 2Bh Write Security Register 2Fh Read Serial Flash Discovery Parameters 5Ah A15-A8 A7-A0 dummy (D7-D0) Table 7-3. (SC7-SC0) (10) A23-A16 Instruction Set Table 2 (Dual SPI Instructions) Instruction Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 (Clock Number) (0 - 7) (8 - 15) (16 - 23) (24 - 31) (32 - 39) (40 - 47) Fast Read Dual Output 3Bh A23-A16 A15-A8 A7-A0 dummy (D7-D0)(6) Fast Read Dual I/O BBh A23-A8(5) A7-A0, M7-M0 (D7-D0, S)(6) Read Dual Manufacturer/ Device ID(4) 92h 0000h (00h, xxxx) or (01h, xxxx) (MID7-MID0) (DID7-DID0)(6) Table 7-4. Instruction Set Table 3 (Quad SPI Instructions) Instruction Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 (Clock Number) (0 - 7) (8 - 15) (16 - 23) (24 - 31) (32 - 39) (40 - 47) Fast Read Quad Output 6Bh A23-A16 A15-A8 A7-A0 dummy (D7-D0) (8) Fast Read Quad I/O EBh A23-A0, M7-M0(7) (xxx, D7-D0,S)(9) (D7-D0, S)(8) Quad Page Program 33h A23-A0 (D7-D0, S)(8) AT25SL641 DS-25SL641–113F–12/2018 15 Table 7-4. Instruction Set Table 3 (Quad SPI Instructions) (Continued) Instruction Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 (Clock Number) (0 - 7) (8 - 15) (16 - 23) (24 - 31) (32 - 39) (40 - 47) Read Quad Manufacturer /Device ID(4) 94h (00_0000h, xx) or (00_0001h, xx) (xxxx,MID7-MID0) (xxxx,DID7-DID0)(9) Word Read Quad I/O E7h A23-A0, M7-M0(7) (xx, D7-D0..) Set Burst with Wrap 77h xxxxxx, W6-W4(7) Table 7-5. (D7-D0)(8) Instruction Set Table 4 (QPI Instructions) Instruction Name Byte 1 Byte 3 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7 Byte 8 Byte 9 (Clock Number) (0, 1) (2, 3) (4, 5) (6, 7) (8, 9) (10, 11) (12, 13) (14, 15) (16, 17) Write Enable 06h Write Enable for Volatile Status Register 50h Write Disable 04h Read Status Register-1 05h (SR7-SR0) (2) Read Status Register-2 35h (SR15SR8)(2) Write Status Register-1(5) 01h (SR7-SR0) Write Status Register-2 31h (SR15-SR8) Set Read Parameter C0h P7-P0 0Bh A23-A16 A15-A8 A7-A0 Dummy Dummy (D7-D0) >104 MHz A23-A16 A15-A8 A7-A0 Dummy Dummy Dummy (D7-D0) up to 133 MHz A23:A16 A15:A8 A7:A0 Dummy Dummy Dummy Dummy (D7-D0)(3) Fast Read Data >80 MHz (SR15SR8) Page Program 02h A23-A16 A15-A8 A7-A0 Block Erase (4KB) 20h A23-A16 A15-A8 A7-A0 Block Erase (32KB) 52h A23-A16 A15-A8 A7-A0 Block Erase (64KB) D8h A23-A16 A15-A8 A7-A0 Chip Erase 60h/C7h Erase/Program Suspend 75h Erase/Program Resume 7Ah Deep Power Down B9h Release Deep Power Down ABh (D7-D0) AT25SL641 DS-25SL641–113F–12/2018 16 Table 7-5. Instruction Set Table 4 (QPI Instructions) (Continued) Instruction Name Byte 1 Byte 3 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7 Byte 8 Byte 9 (Clock Number) (0, 1) (2, 3) (4, 5) (6, 7) (8, 9) (10, 11) (12, 13) (14, 15) (16, 17) Read Manufacturer/Device ID(4) 90h 00h 00h 00h or 01h (MID7MID0) (DID7DID0) Read JEDEC ID(4) 9Fh (MID7-MID0) Manufacturer (D7-D0) Memory Type (D7-D0) Capacity Type Enter Security B1h Exit Security C1h Read Security Register 2Bh A23-A16 A15-A8 A7-A0 (M7-M0) Dummy (D7-D0) >104 MHz A23-A16 A15-A8 A7-A0 (M7-M0) Dummy Dummy (D7-D0) up to 133 MHz A23-A16 A15-A8 A7-A0 (M7-M0) Dummy Dummy Dummy A23-A16 A15-A8 A7-A0 Dummy Dummy (D7-D0) >104 MHz A23-A16 A15-A8 A7-A0 Dummy Dummy Dummy (D7-D0) up to 133 MHz A23-A16 A15-A8 A7-A0 Dummy Dummy Dummy Dummy A23-A16 A15-A8 A7-A0 (D7-D0) (SC7-SC0) (10) Write Security Register Fast Read Quad I/O(11) >80 MHz 2Fh EBh Reset Enable 66h Reset 99h Disable QPI FFh Burst Read with Wrap >80 MHz Quad Page Program Notes: 1. on the 2. 3. 4. 5. 6. 7. 0Ch 33h (D7-D0) (D7-D0) Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “()” indicate data being read from the device IO pin. SR = status register, The Status Register contents and Device ID repeats continuously until CS terminates the instruction. At least one byte of data input is required for Page Program, Quad Page Program and Program Security Register, up to 256 bytes of data input. If more than 256 bytes of data are sent to the device, the addressing wraps to the beginning of the page and overwrites previously sent data. See Manufacturer and Device Identification table for Device ID information. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8, A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9, A7, A5, A3, A1, M7, M5, M3, M1 Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 Set Burst with Wrap Input IO0 = x, x, x, x, x, x, W4, IO1 = x, x, x, x, x, x, W5, IO2 = x, x, x, x, x, x, W6, IO3 = x, x, x, x, x, x, x x x x x AT25SL641 DS-25SL641–113F–12/2018 17 7.2 8. Quad Input/ Output Data IO0 = (D4, D0S) IO1 = (D5, D1S) IO2 = (D6, D2S) IO3 = (D7, D3S) 9. Fast Read Quad I/O Data Output IO0 = (x, x, x, x, D4, D0S) IO1 = (x, x, x, x, D5, D1S) IO2 = (x, x, x, x, D6, D2S) IO3 = (x, x, x, x, D7, D3S) 10. 11. SC = security register The M7-M0 bits are counted as dummy clocks. Write Enable (06h) Write Enable instruction is for setting the Write Enable Latch (WEL) bit in the Status Register. The WEL bit must be set prior to every Program, Erase and Write Status Register instruction. To enter the Write Enable instruction, CS goes low prior to the instruction (06h) being driven onto the SI pin on the rising edge of SCK, and then driving CS high. Figure 7-1. Write Enable Instruction for SPI Mode (left) and QPI Mode (right) 7.3 Write Enable for Volatile Status Register (50h) This i n s t r u c t i o n gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile values into the Status Register bits, the Write Enable for Volatile Status Register (50h) instruction must be issued prior to a Write Status Register (01h) instruction. The Write Enable for Volatile Status Register instruction (Figure 7-2) does not set the Write Enable Latch (WEL) bit. Once Write Enable for Volatile Status Register is set, a Write Enable instruction should not have been issued prior to setting Write Status Register instruction (01h or 31h). When the Write Enable for Volatile Status Register (50h) is executed in QPI Mode, the SUS bit (S15) and Reserved bits (S13, S12, S11 and S10) of the Status Register-2 must be driven to high after Write Status Register instruction (01h). Once the Read Status Register (05h or 31h) instruction is issued, the read values of the SUS bit (S15) and Reserved bits (S13, S12, S11 and S10) of the Status Register-2 are ignored. AT25SL641 DS-25SL641–113F–12/2018 18 Figure 7-2. Write Enable for Volatile Status Register Instruction for SPI Mode (left) and QPI Mode (right) 7.4 Write Disable (04h) The Write Disable instruction is to reset the Write Enable Latch (WEL) bit in the Status Register. To enter the Write Disable instruction, CS goes low prior to the instruction 04h being driven onto the SI pin on the rising edge of SCK, and then driving CS high. T h e WEL bit is automatically reset write-disable status of “0” after power-up and upon completion of the every Program, Erase and Write Status Register instruction. Figure 7-3. Write Disable Instruction for SPI Mode (left) and QPI Mode (right) 7.5 Read Status Register-1 (05h) and Read Status Register-2 (35h) The Read Status Register instructions 05h and 35h are used to read Status Registers 1 and 2 respectively. The Read Status Register can be read at any time (even in program/erase/write Status Register and Write Security Register condition). It is recommended to check the BUSY bit before sending a new instruction when a Program, Erase, Write Status Register or Write Status Register operation is in progress. The instruction is entered by driving CS low and sending the instruction code (05h) for Status Register-1 or (35h) for Status Register-2 onto the SI pin on the rising edge of SCK. The Status Register bits are then shifted out on the SO pin at the falling AT25SL641 DS-25SL641–113F–12/2018 19 edge of SCK with most significant bit (MSB) first as shown in (Figure 7-4 and Figure 7-5). The Status Register can be read continuously. The instruction is completed by driving CS high. Figure 7-4. Read Status Register Instruction (SPI Mode) Figure 7-5. Read Status Register Instruction (QPI Mode) 7.6 Write Status Register (01h) The Write Status Register instruction is u s e d to write the non-volatile Status Register-1 bit (SRP0) and Status Register-2 bits (QE and SRP1). All other Status Register bit locations are read-only and are not affected by the Write Status Register instruction. A Write Enable instruction must previously have been issued prior to setting Write Status Register Instruction (Status Register bit WEL must equal 1). Once the write is enabled, the instruction is entered by driving CS low, sending the instruction code, and then writing the status register data byte as illustrated in Figure 7-6 and Figure 7-7. The CS pin must be driven high after either the eighth or sixteenth bit of data is clocked in. If this is not done, the Write Status Register instruction will not be executed. If CS is driven high after the eighth clock, the CMP, QE, and SRP1 bits are cleared to 0. After CS is driven high, the self-timed Write Status Register cycle commences for a time duration of tw (See AC Characteristics). While the Write Status Register cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the BUSY bit. The BUSY bit is d r i v e n h i g h during the Write Status Register cycle and d r i v e n l o w when the cycle has finished and is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (WEL) bit in Status Register is cleared to 0. AT25SL641 DS-25SL641–113F–12/2018 20 Figure 7-6. Write Status Register Instruction (SPI Mode) Figure 7-7. Write Status Register Instruction (QPI Mode) 7.7 Write Status Register-2 (31h) The Write Status Register-2 instruction is used to write only non-volatile Status Register-2 bits (CMP, QE and SRP1). A Write Enable instruction must previously have been issued prior to setting Write Status Register Instruction (Status Register bit WEL must equal 1). Once write is enabled, the instruction is entered by driving CS low, sending the instruction code, and then writing the Status Register data byte as illustrated in Figure 7-8 and Figure 7-9. Using Write Status Register-2 (31h) instruction, software can individually access each one-byte Status Register via different instructions. AT25SL641 DS-25SL641–113F–12/2018 21 Figure 7-8. Write Status Register-2 Instruction (SPI Mode) Figure 7-9. Write Status Register-2 Instruction (QPI Mode) 7.8 Set Read Parameters (C0h) In QPI mode, to accommodate a wide range of applications with different needs for either maximum read frequency or minimum data access latency, t h e Set Read Parameters (C0h) instruction can be used to configure the number of dummy clocks for the Fast Read (0Bh), Fast Read Quad I/O (EBh), and Burst Read with Wrap (0Ch) instructions, and to configure the number of bytes of wrap length for the Burst Read with Wrap (0Ch) instruction. In Standard SPI mode, the Set Read Parameters (C0h) instruction is not accepted. The dummy clocks for various Fast Read instructions in Standard/Dual/Quad SPI mode are fixed. The wrap length is set by the W6-W5 bits in the Set Burst with Wrap (77h) instruction. This setting remains unchanged when the device is switched from Standard SPI mode to QPI mode. The default wrap length after a power up or a Reset instruction is 8 bytes, and the default number of dummy clocks is 4. AT25SL641 DS-25SL641–113F–12/2018 22 Table 7-6. Encoding of the P[5:4] Bits P5, P4 Dummy Clocks Maximum Read Frequency 00 4 80 MHz 01 4 80 MHz 10 6 104 MHz 11 8 133 MHz Table 7-7. Encoding of the P[1:0] Bits P1, P0 Wrap Length 00 8-byte 01 16-byte 10 32-byte 11 64-byte Figure 7-10. Set Read Parameters Instruction (QPI Mode) 7.9 Read Data (03h) The Read Data instruction is used to read data out from the device. The instruction is initiated by driving the CS pin low and then sending the instruction code 03h, followed by a 24-bit address (A23- A0), onto the SI pin. After the address is received, the data byte of the addressed memory location is shifted out on the SO pin at the falling edge of SCK with the most significant bit (MSB) first. The address is automatically incremented to the next higher address and the next byte of data is shifted out, allowing for a continuous stream of data. This means that the entire memory can be accessed with a single instruction as long as the clock continues. The instruction is completed by driving CS high. The Read Data instruction sequence is shown in Figure 7-11. If a Read Data instruction is issued while an Erase, Program or Write Status Register cycle is in process (BUSY = 1) the instruction is ignored AT25SL641 DS-25SL641–113F–12/2018 23 and does not effect the current cycle. The Read Data instruction allows clock rates from D.C to a maximum of fR (see AC Electrical Characteristics). Figure 7-11. Read Data Instruction 7.10 Fast Read (0Bh) The Fast Read instruction is a high speed reading mode that can operate at the highest possible frequency of FR. The address is latched on the rising edge of the SCK. After the 24-bit address, eight dummy clocks are shifted in as shown in Figure 7-12. The dummy clocks allow the internal circuits the time required to set up the initial address. During the dummy clocks, the data value on the SO pin is a “don’t care”. Data of each bit shifts out on the falling edge of SCK. Figure 7-12. Fast Read Instruction (SPI Mode) Fast Read in QPI Mode When QPI mode is enabled, the number of dummy clock is configured by the Set Read Parameters (C0h) instruction to accommodate a wide range applications with different needs for either maximum Fast Read frequency or minimum data access latency. The number of dummy clock cycles can be configured as either 4, 6 or 8 by setting bits P[5:4] in the 8bit parameter of the Set Read Parameters (C0h) command as shown in Table 7-6, Encoding of the P[5:4] Bits. The AT25SL641 DS-25SL641–113F–12/2018 24 default number of dummy clocks upon power up or after a Reset instruction is 4. Please refer to Figure 7-13. Figure 7-13. Fast Read Instruction (QPI Mode) n+1 n+2 n+3 n+4 7.11 Fast Read Dual Output (3Bh) By using two pins (IO0 and IO1, instead of just IO0), the Fast Read Dual Output instruction allows data to be transferred from the AT25SL641 at twice the rate of standard SPI devices. The Fast Read Dual Output instruction is ideal for quickly downloading code from Flash to RAM upon power-up or for application that cache code-segments to RAM for execution. The Fast Read Dual Output instruction can operate at the highest possible frequency of F R (see AC Electrical Characteristics). After the 24-bit address, eight dummy clocks are driven on the SI pin as shown in Figure 7-14. The dummy clocks allow the internal circuits the time required for setting up the initial address. During the dummy clocks, the data value on the SO pin is a “don’t care”. However, the IO0 pin should be high-impedance prior to the falling edge of the first data out clock. Figure 7-14. Fast Read Dual Output instruction (SPI Mode) AT25SL641 DS-25SL641–113F–12/2018 25 7.12 Fast Read Quad Output (6Bh) By using four pins (IO0, IO1, IO2, and IO3), the Fast Read Quad Output instruction allows data to be transferred from the AT25SL641 at four times the rate of standard SPI devices. Prior to executing the 6Bh instruction, the Quad Enable (QE) bit of Status Register 2 must be set. The Fast Read Quad Output instruction can operate at the highest possible frequency of F R (see AC Electrical Characteristics). This is accomplished by adding eight dummy clocks after the 24- bit address as shown in Figure 7-15. The dummy clocks allow the internal circuits the time required to set up the initial address. During the dummy clocks, the data value on the SO pin is a “don’t care”. However, the IO0 pin should be high-impedance prior to the falling edge of the first data out clock. Figure 7-15. Fast Read Quad Output Instruction (SPI Mode) 7.13 Fast Read Dual I/O (BBh) The Fast Read Dual I/O instruction reduces cycle overhead by using two IO pins: IO0 and IO1 to transfer data. Continuous Read Mode The Fast Read Dual I/O instruction s u p p o r t s a c o n t i n u o u s r e a d m o d e u s i n g the Mode bits (M7-0), which are shifted into the device after address bits (A23-0). The upper nibble of the Mode (M7-4) controls whether the instruction code must be driven to the device on subsequent access. If the Mode bits (M7-0) equal “Ax” hex, then the next Fast Dual I/O instruction (after CS is raised and then lowered) does not require the instruction (BBh) code, as shown in Figure 7-16 and Figure 7-17. This reduces the instruction sequence by eight clocks and allows the address to be immediately entered after CS is asserted low. AT25SL641 DS-25SL641–113F–12/2018 26 If Mode bits (M7-0) are any value other “Ax” hex, the next instruction (after CS is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. A mode bit reset can be used to reset Mode bits (M70) before issuing normal instructions. The bits of the lower nibble (M3-0) are don’t care (“X”). However, the I/O pins should be high-impedance prior to the falling edge of the first data out clock. Figure 7-16. Fast Read Dual I/O Instruction (initial instruction or previous M7-0 ≠ Axh) AT25SL641 DS-25SL641–113F–12/2018 27 Figure 7-17. Fast Read Dual I/O Instruction (previous M7-0 = Axh) 7.14 Fast Read Quad I/O (EBh) The Fast Read Quad I/O instruction reduces cycle overhead through quad access using four IO pins: IO0, IO1, IO2, and IO3. The Quad Enable bit (QE) of Status Register-2 must be set to enable the Fast read Quad I/O Instruction. Continuous Read Mode The Fast Read Quad I/O instruction can further reduce instruction overhead through setting the Mode bits (M7-0) with following the input Address bits (A23-0), as shown in Figure 7-18. The upper nibble of the Mode (M7-4) controls the length of the next Fast Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the Mode (M3-0) are don’t care (“X”). However, the I/O pins should be high-impedance prior to the falling edge of the first data out clock. Note that the mode bits are counted as dummy clocks. If the Mode bits (M7-0) equal Ax hex, then the next Fast Read Quad I/O instruction (after CS is raised and then lowered) does not require the EBh instruction code, as shown in Figure 7-19. This reduces the instruction sequence by eight clocks and allows the address to be immediately entered after CS is asserted low. If the Mode bits (M7-0) are any value other than “Ax” hex, the next instruction (after CS is raised and then lowered) requires the first byte instruction code, thus retuning normal operation. A mode bit reset can be used to reset Mode bits (M7-0) before issuing normal instructions. AT25SL641 DS-25SL641–113F–12/2018 28 Figure 7-18. Fast Read Quad I/O Instruction (Initial instruction or previous M7-0 ≠ Axh, SPI mode) Figure 7-19. Fast Read Quad I/O Instruction (previous M7-0 = Axh, SPI mode) Wrap Around in SPI mode The Fast Read Quad I/O instruction can also be used to access a specific portion within a page by issuing a Set Burst with Wrap (77h) instruction prior to issuing the Fast Read Quad I/O (EBh) instruction. The Set Burst with Wrap (77h) instruction can either enable or disable the Wrap Around feature for the following Fast Read Quad I/O instruction. When Wrap Around is enabled, the data being accessed can be limited to an 8/16/32/64-byte section of a 256-byte page. The output data starts at the initial address specified in the instruction. Once it reaches the ending boundary of the 8/16/32/64-byte section, the output wraps around to the beginning boundary automatically until CS is pulled high to terminate the instruction. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read instructions. (Please refer to Section 7.32 Set Burst with Wrap). AT25SL641 DS-25SL641–113F–12/2018 29 Fast Read Quad I/O in QPI Mode When QPI mode in enabled, the number of dummy clocks is configured by the Set Read Parameters (C0h) instruction to accommodate a wide range applications with different needs for either maximum fast read frequency or minimum data access latency. The number of dummy clock cycles can be configured as either 4, 6 or 8 by setting bits P[5:4] in the 8bit parameter of the Set Read Parameters (C0h) command as shown in Table 7-6, Encoding of P[5:4] Bits. The default number of dummy clocks upon power up or after a Reset (99h) instruction is four. The Continuous Read Mode feature is also available in QPI mode for Fast Read Quad I/O instruction. In QPI mode, the Continuous Read Mode bits M7-M0 are also considered as dummy clocks. The Wrap Around feature is not available in QPI mode for Fast Read Quad I/O instruction. To perform a read operation with fixed data length wrap around in QPI mode, a Burst Read with Wrap (0Ch) instruction must be used. Please refer to Section 7.33, Burst Read with Wrap. Figure 7-20. Fast Read Quad I/O Instruction (Initial instruction or previous M7-0 ≠ Axh, QPI mode) n+1 n+2 n+3 n+4 7.15 Page Program (02h) The Page Program instruction is used for programming the memory to “0”. A Write Enable instruction (06h) must be issued before the device accept the Page Program Instruction (Status Register bit WEL = 1). After the Write Enable (WREN) instruction has been decoded, the device sets the Write Enable Latch (WEL) bit in the Status Register. The instruction is entered by driving the CS pin low and then sending the instruction code 02h followed by a 24-bits address (A23-A0) and at least one data byte on the SI pin. The CS pin must be driven low for the entire time of the instruction while data is being sent to the device. The CS pin must be driven low for the entire time of the instruction while data is being sent to the device. Please refer to Figure 7-21 and Figure 7-22. If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant address bits) should be set to 0. If the last address byte is not zero, and the number of clocks exceeds the remaining page length, the addressing wraps to the beginning of the page. In some cases, less than 256 bytes (a partial page) can be programmed without having any effect on other bytes within the same page. One condition to perform a partial page program is that the number of clocks cannot exceed the remaining page length. If more than 256 bytes are sent to the device the addressing wraps to the beginning of the page and overwrite previously sent data. The CS pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Page Program instruction is not executed. After CS is driven high, the self-timed Page Program instruction commences for a time duration of tPP (See AC Characteristics). While the Page Program cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the BUSY bit. The BUSY bit is a 1 during the Page Program AT25SL641 DS-25SL641–113F–12/2018 30 cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. Figure 7-21. Page Program Instruction (SPI Mode) Figure 7-22. Page Program Instruction (QPI Mode) 7.16 Quad Page Program (33h) The Quad Page Program instruction is used to program the memory to “0” at previously erased memory areas. The Quad Page Program uses four pins to transfer address and data: IO0, IO1, IO2 and IO3. This improves performance and data throughput of lower clock frequencies of less than 5MHz. Systems using faster clock speed will not get more benefit for the Quad Page Program as the required internal page program time is far more than the time required to clock data in. To use Quad Page Program, the Quad Enable bit must be set, A Write Enable (06h) instruction must be executed before the device can accept the Quad Page Program instruction (Status Register-1, WEL = 1). The instruction is initiated by driving the CS pin low, then sending the instruction code 33h followed by a 24-bit address (A23 - A0) and at least one data, into the I/O pins. The CS pin must be held low for the entire length of the instruction while data is being sent to the device. All other functions of Quad Page Program are the same as the standard Page Program. Please AT25SL641 DS-25SL641–113F–12/2018 31 refer to Figure 7-23 and Figure 7-24. Figure 7-23. Quad Page Program Instruction (SPI mode) Figure 7-24. Quad Page Program Instruction (QPI mode) AT25SL641 DS-25SL641–113F–12/2018 32 7.17 4 KByte Block Erase (20h) The Block Erase instruction is used to erase the data of the selected block by setting the memory locations to “1”. The instruction is used to erase a 4 KB block. Prior to the Block Erase Instruction, the Write Enable instruction must be issued. The instruction is initiated by driving the CS pin low and shifting the instruction code 20h followed by a 24-bit block address (A23 - A0). (Please refer to Figure 7-25 and Figure 7-26). The CS pin must go high after the eighth bit of the last byte has been latched in, otherwise, the Block Erase instruction will not be executed. After CS goes high, the self-timed Block Erase instruction commences for a time duration of tSE (See AC Characteristics). While the Block Erase cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the BUSY bit. The BUSY bit is a 1 during the Block Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. Figure 7-25. 4 KByte Block Erase Instruction (SPI Mode) Figure 7-26. 4 KByte Block Erase Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 33 7.18 32 KByte Block Erase (52h) The Block Erase instruction is used to erase the data of the selected block by setting the memory locations to “1”. The instruction is used for a 32 KB Block erase operation. Prior to the Block Erase Instruction, a Write Enable instruction must be issued. The instruction is initiated by driving the CS pin low and shifting the instruction code 52h followed b y a 24-bit block address (A23 - A0). Please refer to Figure 7-27 and Figure 7-28. The CS pin must go high after the eighth bit of the last byte has been latched in, otherwise, the Block Erase instruction will not be executed. After CS is driven high, the self-timed Block Erase instruction commences for a time duration of tBE1. See AC Characteristics. While the Block Erase cycle is in progress, the Read Status Register instruction may still be read the status of the BUSY bit. The BUSY bit is a 1 during the Block Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. Figure 7-27. 32 KByte Block Erase Instruction (SPI Mode) Figure 7-28. 32 KByte Block Erase Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 34 7.19 64 KByte Block Erase (D8h) The Block Erase instruction is used to erase the data of a selected block by setting the memory locations of that block to “1”. The instruction is used for 64 KB block erase operation. Prior to the Block Erase Instruction, a Write Enable instruction must be issued. The instruction is initiated by driving the CS pin low and shifting the instruction code D8h followed b y a 24-bit block address (A23 - A0). Please refer to Figure 7-29 and Figure 7-30. The CS pin must go high after the eighth bit of the last byte has been latched in, otherwise, the Block Erase instruction will not be executed. After CS is driven high, the self-timed Block Erase instruction commences for a time duration of tBE2 (See AC Characteristics). While the Block Erase cycle is in progress, the Read Status Register instruction may still be read the status of the BUSY bit. The BUSY bit is a 1 during the Block Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. Figure 7-29. 64 KByte Block Erase Instruction (SPI Mode) Figure 7-30. 64 KByte Block Erase Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 35 7.20 Chip Erase (C7h / 60h) The Chip Erase instruction clears all bits in the device to FFh (all 1s). Prior to the Chip Erase Instruction, a Write Enable instruction must be issued. The instruction is initiated by driving the CS pin low and shifting the instruction code C7h or 60h. Please refer to Figure 7-31. The CS pin must go high after the eighth bit of the last byte has been latched in, otherwise, the Chip Erase instruction will not be executed. After CS is driven high, the self-timed Chip Erase instruction commences for a duration of tCE (See AC Characteristics). While the Chip Erase cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the BUSY bit. The BUSY bit is a 1 during the Chip Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions. When the BUSY bit is asserted, the Write Enable Latch (W EL) bit in the Status Register is cleared to 0. Figure 7-31. Chip Erase Instruction for SPI Mode (left) and QPI Mode (right) 7.21 Erase / Program Suspend (75h) The Erase/Program Suspend instruction allows the system to interrupt a Block Erase, Block Erase operation or a Page Program, Quad Data Input Page Program, Quad Page Program operation. Erase Suspend is valid only during a Block Erase operation. The Write Status Register-1 (01h), Write Status Register-2 (31h) instruction and Erase instructions (20h, 52h, D8h, C7h, 60h) are not allowed during an Erase Suspend. During the Chip Erase operation, the Erase Suspend instruction is ignored. Program Suspend is valid only during the Page Program, Quad Data Input Page Program or Quad Page Program operation. The Write Status Register-1 (01h), Write Status Register-2 (31h) instruction, Program instructions (02h and 33h) and Erase Instructions (20h, 52h, D8h, C7h, 60h) are not allowed during Program Suspend. The Erase/Program Suspend instruction 75h is accepted by the device only if the SUS bit in the Status Register equals to 0 and the BUSY bit equals to 1 while a Block Erase or a Page Program operation is on-going. If the SUS bit equals to 1 or the BUSY bit equals to 0, the Suspend instruction is ignored by the device. A maximum of time of tSUS (See AC Characteristics) is required to suspend the erase or program operation. After executing the Erase/Program Suspend, the SUS bit in the Status Register is toggled from 0 to 1 immediately. The BUSY bit in the Status Register is cleared from 1 to 0 within tSUS. For a previously resumed Erase/Program operation, it is also required that the Suspend instruction 75h is not issued earlier than a minimum of time of tSUS following the preceding Resume instruction 7Ah. AT25SL641 DS-25SL641–113F–12/2018 36 Unexpected power- off during the Erase/Program suspend state resets the device and releases the suspend state. The SUS bit in the Status Register is also reset to 0. The data within the page or block that was being suspended may become corrupted. It is recommended for the user implement system design techniques t o g u a r d against the accidental power interruption and preserve data integrity during the erase/program suspend state. (Please refer to Figure 7-32 and Figure 7-33). Figure 7-32. Erase Suspend Instruction (SPI Mode) Figure 7-33. Erase Suspend Instruction (QPI Mode) 7.22 Erase / Program Resume (7Ah) The Erase/Program Resume instruction 7Ah is used to restart the Block Erase operation or the Page Program operation after an Erase/Program Suspend (75h). The Resume instruction 7Ah is accepted by the device only if the SUS bit in the Status Register is set and the BUSY bit is cleared. After the 7Ah instruction is issued, hardware clears the SUS bit immediately and sets the BUSY bit within 200ns. The block completes the erase operation or the page completes the program operation. If e i t h e r the SUS bit is cleared or the BUSY bit is set, the Resume instruction 7Ah is ignored by the device. AT25SL641 DS-25SL641–113F–12/2018 37 The Resume instruction cannot be accepted if the previous Erase/Program Suspend operation was interrupted by unexpected power-off. It is also required that a subsequent Erase/Program Suspend instruction not to be issued within a minimum of time of tSUS following a previous Resume instruction. (Please refer to Figure 7-34 and Figure 7-35). Figure 7-34. Erase / Program Resume Instruction (SPI Mode) Figure 7-35. Erase / Program Resume Instruction (QPI Mode) 7.23 Deep Power Down (B9h) Executing the Deep Power Down instruction is the best way to put the device in the lowest power consumption. The Deep Power Down instruction reduces the standby current (from ICC1 to ICC2 as specified in AC characteristics). The instruction is entered by driving the CS pin low following execution of the B9h instruction. (Please refer to Figure 7-36 and Figure 7-37). The CS pin must go high exactly at the byte boundary (the latest eighth bit of instruction code been latched-in); otherwise, the Deep Power Down instruction is not executed. After CS goes high, it requires a delay of tDP and the Deep Power Down mode is entered. While in the Deep Power Down mode, the Release Deep Power Down / Device ID instruction is used to restore the device to normal operation. All other instructions are ignored, including the Read Status Register instruction, which is always available during normal operation. AT25SL641 DS-25SL641–113F–12/2018 38 Figure 7-36. Deep Power Down Instruction (SPI Mode) Figure 7-37. Deep Power Down Instruction (QPI Mode) 7.24 Release Deep Power Down / Device ID (ABh) The Release Deep Power Down / Device ID instruction is a multi-purpose instruction. It can be used to release the device from the Deep Power Down state or obtain the device identification (ID). The instruction is issued by driving the CS pin low and driving a value of ABh onto the bus, then driving CS high as shown in Figure 7-38 and Figure 7-39. The Release from Deep Power Down instruction requires the time duration of tRES1 (See AC Characteristics) before accepting other instructions. The CS pin must keep high during the tRES1 time duration. The Device ID can be read during SPI mode only. In other words, the Device ID feature is not available in QPI mode for the Release Deep Power Down/Device ID instruction. To obtain the Device ID in SPI mode, the instruction is initiated by driving the CS pin low and sending the instruction code ABh followed by 3-dummy bytes. The Device ID bits are then shifted on the falling edge of SCK with most significant bit (MSB) first as shown in Figure 7-40. After CS is driven high it must keep high for a time duration of tRES2 (See AC Characteristics). The Device ID can be read continuously. The instruction is completed by driving CS high. If the Release from Deep Power Down /Device ID instruction is issued while an Erase, Program or Write cycle is in process (when BUSY equals 1) the instruction is ignored and does not have any effect on the current cycle. AT25SL641 DS-25SL641–113F–12/2018 39 Figure 7-38. Release Power Down Instruction (SPI Mode) Figure 7-39. Release Power Down Instruction (QPI Mode) Figure 7-40. Release Power Down / Device ID Instruction (SPI Mode) AT25SL641 DS-25SL641–113F–12/2018 40 7.25 Read Manufacturer / Device ID (90h) The Read Manufacturer/ Device ID instruction provides both the JEDEC assigned manufacturer ID and the specific device ID. This instruction can be issued in both SPI mode and QPI mode. In SPI mode, the 90h instruction is called a 1-1-1 transfer, where the instruction, address, and data are all driven on a single pin (SI for instruction and address, and SO for data). In QPI mode, the 90h instruction is called a 4-4-4 transfer, where the instruction, address, and data are driven on the bidirectional IO0 - IO3 pins. Note that in QPI mode, the following events must occur in the order shown. 1. Set the QE bit in Status Register-2 2. Execute the QPI Enable (38h) instruction 3. Execute the 90h instruction In SPI mode, the operation is initiated by driving the CS pin low and then driving the instruction code 90h onto the SI pin, followed by a 24-bit address (A23-A0) of 000000h. The 90h instruction requires 8 clocks to transfer, and the 24-bit address requires 24 clocks to transfer. The Manufacturer ID for Adesto (1Fh) and the Device ID (17h) are shifted out on the SO pin on the falling edge of SCK with most significant bit (MSB) first. A minimum or 16 clocks are required to transfer the manufacturer and device ID information. If the 24-bit address is initially set to 000001h the Device ID is read first and then followed by the Manufacturer ID. The Manufacturer and Device ID can be read continuously, alternating from one to the other. The instruction is completed by driving CS high. In QPI mode, the SI, SO, WP, and HOLD pins are configured as bidirectional pins IO0, IO1, IO2, and IO3 respectively. The 90h operation the operation is initiated by driving the CS pin low and then driving the instruction code 90h onto the IO0 IO3 pins, followed by a 24-bit address (A23-A0) of 000000h. The 90h instruction requires 2 clocks to transfer, and the 24-bit address requires 6 clocks to transfer. The Manufacturer ID for Adesto (1Fh) and the Device ID (17h) are shifted out on the bidirectional IO0 - IO3 pins on the falling edge of SCK, with most significant bit (MSB) first. A minimum or 4 clocks are required to transfer the manufacturer and device ID information. If the 24-bit address is initially set to 000001h the Device ID is read first and then followed by the Manufacturer ID. The Manufacturer and Device ID can be read continuously, alternating from one to the other. The instruction is completed by driving CS high. Figure 7-41 shows the 90h command as executed in SPI mode. In this mode the instruction and address are driven on the SI pin. Figure 7-42 shows the 90h command as executed in QPI mode. In this mode the instruction and address are driven on all four I/O pins. AT25SL641 DS-25SL641–113F–12/2018 41 Figure 7-41. Read Manufacturer/ Device ID Instruction (SPI Mode) Figure 7-42. Read Manufacturer/ Device ID Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 42 7.26 Read Manufacturer / Device ID Dual I/O (92h) The Read Manufacturer/ Device ID Dual I/O instruction provides both the JEDEC assigned manufacturer ID and the specific device ID. The Read Manufacturer/ Device ID instruction is very similar to the Fast Read Dual I/O instruction. The instruction is initiated by driving the CS pin low and shifting the instruction code 92h followed by a 24-bit address (A23-A0) of 000000h. The Manufacturer ID for Adesto (1Fh) and the Device ID(17h) are shifted out on the falling edge of SCK with most significant bit (MSB) first as shown in Figure 7-43. If the 24-bit address is initially set to 000001h the Device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device ID can be read continuously, alternating from one to the other. The instruction is completed by driving CS high. Figure 7-43. Read Dual Manufacturer/ Device ID Dual I/O Instruction (SPI Mode) 7.27 Read Manufacturer / Device ID Quad I/O (94h) The Read Manufacturer/ Device ID Quad I/O instruction provides both the JEDEC assigned manufacturer ID and the specific device ID. The Read Manufacturer/ Device ID Quad I/O instruction is very similar to the Fast Read Quad I/O instruction. The instruction is initiated by driving the CS pin low and shifting the instruction code 94h followed by a 24-bit address (A23A0) of 000000h. The Manufacturer ID for Adesto (1Fh) and the Device ID (17h) are shifted out on the falling edge of SCK with most significant bit (MSB) first as shown in Figure 7-44. If the 24-bit address is initially set to 000001h the Device ID is read first, followed by the Manufacturer ID. The Manufacturer and Device ID can be read continuously, alternating from one to the other. The instruction is completed by driving CS high. AT25SL641 DS-25SL641–113F–12/2018 43 Figure 7-44. Read Quad Manufacturer/ Device ID Quad I/O Instruction (SPI Mode) 7.28 JEDEC ID (9Fh) For compatibility reasons, the AT25SL641 provides several instructions to electronically determine the identity of the device. The Read JEDEC ID instruction is congruous with the JEDEC standard for SPI compatible serial flash memories that was adopted in 2003. The instruction is entered by driving the CS pin low with following the instruction code “9Fh”. JEDEC assigned Manufacturer ID byte for Adesto (1Fh) and two Device ID bytes, Memory Type (ID15-ID8) and Capacity (ID7-ID0) are then shifted out on the falling edge of SCK with most significant bit (MSB) first shown in Figure 7-45 and Figure 7-46. For memory type and capacity values refer to Manufacturer and Device Identification table. The JEDEC ID can be read continuously. The instruction is terminated by driving CS high. AT25SL641 DS-25SL641–113F–12/2018 44 Figure 7-45. Read JEDEC ID Instruction (SPI Mode) Figure 7-46. Read JEDEC ID Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 45 7.29 Enable QPI (38h) The AT25SL641 supports both the Standard/Dual/Quad Serial Peripheral interface (SPI) and Quad Peripheral Interface (QPI). However, SPI mode and QPI mode cannot be used at the same time. The Enable QPI instruction is used to switch the device from SPI mode to QPI mode. To switch the device to QPI mode, the Quad Enable (QE) bit in Status Register 2 must be set, followed by an Enable QPI instruction. If the Quad Enable (QE) bit is 0, the Enable QPI instruction is ignored and the device remains in SPI mode. After power-up, the default state of the device is SPI mode. See the instruction Set Table 7-2 for all the commands supported in SPI mode and the instruction Set Table 7-5 for all the instructions supported in QPI mode. When the device is switched from SPI mode to QPI mode, the existing Write Enable and Program/Erase Suspend status, and the Wrap Length setting remains unchanged. Figure 7-47. Enable QPI Instruction (SPI Mode only) 7.30 Disable QPI (FFh) By issuing a Disable QPI (FFh) instruction, the device is reset back to SPI mode. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch (WEL) and Program/Erase Suspend status, and the Wrap Length settings remains unchanged. Figure 7-48. Disable QPI Instruction for QPI Mode AT25SL641 DS-25SL641–113F–12/2018 46 7.31 Word Read Quad I/O (E7h) The Quad I/O dramatically reduces instruction overhead, allowing faster random access for code execution (XIP) directly from the Quad SPI. The Quad Enable bit (QE) of Status Register-2 must be set to enable the Word Read Quad I/O instruction. The lowest Address bit (A0) must equal 0 and only two dummy clocks are required prior to the data output. Continuous Read Mode The Word Read Quad I/O instruction can further reduce instruction overhead through setting the Continuous Read Mode bits (M7-0) after the input Address bits (A23-0), as shown in Figure 7-49. The upper nibble of the (M7-4) controls the length of the next Word Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M[3:0]) are don’t care (“X”). However, the I/O pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M[7-4] = Ah, then the next Fast Read Quad I/O instruction (after CS is raised and then lowered) does not require the E7h instruction code, as shown in Figure 7-50. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS is asserted low. If the Continuous Read Mode bits M[7:4] do not equal to Ah (1,0,1,0) the next instruction (after CS is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. Figure 7-49. Word Read Quad I/O Instruction (Initial instruction or previous set M7-0 ≠ Axh, SPI Mode) AT25SL641 DS-25SL641–113F–12/2018 47 Figure 7-50. Word Read Quad I/O Instruction (Previous instruction set M7-0 = Axh, SPI Mode) Wrap Around in SPI mode The Word Read Quad I/O instruction can also be used to access a specific portion within a page by issuing a Set Burst with Wrap (77h) instruction prior to E7h. The Set Burst with Wrap instruction can either enable or disable the Wrap Around feature for the following E7h commands. When Wrap Around is enabled, the output data starts at the initial address specified in the instruction, once it reaches the ending boundary of the 8/16/32/64-byte section, the output wraps around to the beginning boundary automatically until CS is pulled high to terminate the instruction. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing read instructions. The Set Burst with Wrap instruction allows three wrap bits, W6-4, to be set. The W4 bit is used to enable or disable the Wrap Around operation, while W6-5 is used to specify the length of the wrap around section within a page. 7.32 Set Burst with Wrap (77h) The Set Burst with Wrap (77h) instruction is used in conjunction with Fast Read Quad I/O and Word Read Quad I/O instructions to access a fixed length of 8/16/32/64-byte section within a 256-byte page. Certain applications can benefit from this feature and improve the overall system code execution performance. Before the device accepts the Set Burst with Wrap instruction, a Quad enable of Status Register-2 must be executed (Status Register bit QE must equal 1). The Set Burst with Wrap instruction is initiated by driving the CS pin low and then shifting the instruction code 77h followed by 24 dummy bits and 8 wrap bits, W7 - W0. The instruction sequence is shown in Set Burst with Wrap Instruction Sequence. Wrap bit W7 and W3-0 are not used. Table 7-8. Encoding of W6 - W4 Wrap Bits W4 = 0 W6, W5 Wrap Around W4 = 1(Default) Wrap Length Wrap Around Wrap Length 00 Yes 8-byte No N/A 01 Yes 16-byte No N/A 10 Yes 32-byte No N/A 11 Yes 64-byte No N/A Once W6-4 is set by a Set Burst with Wrap instruction, all the following Fast Read Quad I/O”and Word Read Quad I/O instructions use the W6-4 setting to access the 8/16/32/64-byte section within any page. To exit the Wrap Around function and return to normal read operation, another Set Burst with Wrap instruction should be issued to set W4 = 1. AT25SL641 DS-25SL641–113F–12/2018 48 The default value of W4 upon power on is 1. In the case of a system Reset while W4 = 0, it is recommended that the controller issues a Set Burst with Wrap instruction or Reset (99h) instruction to reset W4 = 1 prior to any normal Read instructions since the AT25SL641 does not have a hardware reset pin. Figure 7-51. Set Burst with Wrap Instruction Sequence 7.33 Burst Read with Wrap (0Ch) The Burst Read with Wrap (0Ch) instruction provides an alternative way to perform the read operation with Wrap Around in QPI mode. The instruction is similar to the Fast Read (0Bh) instruction in QPI mode, except the addressing of the read operation wraps around to the beginning boundary of the wrap length once the ending boundary is reached. The number of dummy clock cycles can be configured as either 4, 6 or 8 by setting bits P[5:4] in the 8-bit parameter of the Set Read Parameters (C0h) command as shown in Table 7-6, Encoding of P[5:4] Bits. Figure 7-52. Burst Read with Wrap Instruction (QPI Mode) n+1 n+2 n+3 n+4 AT25SL641 DS-25SL641–113F–12/2018 49 7.34 Enable Reset (66h) and Reset (99h) For eight-pin packages, the AT25SL641 provide a software Reset instruction (99h) instead of a dedicated RESET pin. Once the Reset instruction is accepted, any on-going internal operations are terminated and the device returns to its default power-on state and loses all current volatile settings, such as Volatile Status Register bits, Write Enable Latch (WEL) status, Program/Erase Suspend status, Continuous Read Mode bit setting, Read parameter setting and Wrap bit setting. The Enable Reset (66h) and Reset (99h) instructions can be issued in either SPI mode or QPI mode. To avoid accidental reset, both instructions must be issued in sequence. The execution of any instruction other than Reset (99h) after the Reset Enable (66h) instruction is executed disables the reset enable state. A new sequence of Enable Reset (66h) and Reset (99h) would then be required to reset the device. Once the Reset instruction is accepted by the device, it takes approximately tRST = 30µs to reset. During this period, no instruction is accepted. Data corruption may happen if there is an on-going or suspended internal Erase or Program operation when Reset instruction sequence is accepted by device. It is recommended to check the BUSY bit and the SUS bit in Status Register before issuing the Reset instruction sequence. Figure 7-53. Enable Reset and Reset Instruction (SPI Mode) Figure 7-54. Enable Reset and Reset Instruction (QPI Mode) AT25SL641 DS-25SL641–113F–12/2018 50 7.35 Read Serial Flash Discovery Parameter (5Ah) The Read Serial Flash Discovery Parameter (SFDP) instruction allows reading the Serial Flash Discovery Parameter area (SFDP). This SFDP area is composed of 2048 read-only bytes containing operating characteristics and vendor specific information. The SFDP area is factory programmed. If the SFDP area is blank, the device is shipped with all the SFDP bytes at FFh. If only a portion of the SFDP area is written to, the portion not used is shipped with bytes in erased state (FFh). The instruction sequence for the read SFDP has the same structure as that of a Fast Read instruction. First, the device is selected by driving Chip Select (CS) low. Next, the 8-bit instruction code (5Ah) and the 24-bit address are shifted in, followed by 8 dummy clock cycles. The bytes of SFDP content are shifted out on the Serial Data Output (SO) starting from the specified address. Each bit is shifted out during the falling edge of Serial Clock (SCK). The instruction sequence is shown here. The Read SFDP instruction is terminated by driving Chip Select (CS) High at any time during data output. Figure 7-55. Read SFDP Register Instruction Table 7-9. SFDP Signature and Headers Description Comment SFDP Signature Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 00h 07:00 0101 0011 53h 01h 15:08 0100 0110 46h 02h 23:16 0100 0100 44h 03h 31:24 0101 0110 50h SFDP Minor Revision Start from 00h 04h 07:00 0000 0110 06h SFDP Major Revision Start from 01h 05h 15:08 0000 0001 01h Number of Parameters Headers Start from 00h 06h 23:16 0000 0001 01h AT25SL641 DS-25SL641–113F–12/2018 51 Table 7-9. SFDP Signature and Headers Description Comment Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) Reserved FFh 07h 31:24 1111 1111 FFh JEDEC Parameter ID (LSB) JEDEC Parameter ID (LSB) = 00h 08h 07:00 0000 0000 00h Parameter Table Minor Revision Start from 00h 09h 15:08 0000 0110 06h Parameter Table Major Revision Start from 01h 0Ah 23:16 0000 0001 01h 0Bh 31:24 0001 0000 10h 0Ch 07:00 0011 0000 30h 0Dh 15:08 0000 0000 00h 0Eh 23:16 0000 0000 00h Parameter Table Length (double words) Parameter Table Pointer How many DWORDs in the parameter table Address of Adesto Parameter Table JEDEC Parameter ID (MSB) JEDEC Parameter ID (MSB):FFh 0Fh 31:24 1111 1111 FFh JEDEC Parameter ID (LSB) Adesto Manufacturer ID 10h 07:00 0001 1111 1Fh Parameter Table Minor Revision Start from 00h 11h 15:08 0000 0000 00h Parameter Table Major Revision Start from 01h 12h 23:16 0000 0001 01h Parameter Table Length (double words) How many DWORDs in the parameter table 13h 31:24 0000 0010 02h Parameter Table Pointer (PTP) Address of Adesto Parameter Table 14h 07:00 1000 0000 80h 15h 15:08 0000 0000 00h 16h 23:16 0000 0000 00h 17h 31:24 0000 0001 01h Reserved FFh AT25SL641 DS-25SL641–113F–12/2018 52 Table 7-10. SFDP Parameters Table 1 Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 30h 01:00 01 E5h 0: 1 Byte 1: 64 bytes or larger 02 1 Volatile Status Register Block Protect Bits 0: Nonvolatile status bit 1: Volatile status bit 03 0 Volatile Status Register Write Enable Opcode 0: 50h Opcode to enable, if bit 3 = 1 04 0 07:05 111 Description Comment Erase Granularity 01: 4KB available 11: 4KB not available Write Granularity Reserved 4KB Erase Opccde Opcode or FFh 31h 15:08 0010 0000 20h Fast Dual Read Output (1 -1 -2) 0: Not supported, 1: Supported 32h 16 1 F1h Number of Address Bytes 00: 3 Byte only 01: 3 or 4 Byte 10: 4 Byte only 11: Reserved 18:17 00 Double Transfer Rate (DTR) Clocking 0: Not supported, 1: Supported 19 0 Fast Dual I/O Read (1-2- 2) 0: Not supported, 1: Supported 20 1 Fast Quad I/O Read (1-4-4) 0: Not supported, 1: Supported 21 1 Fast Quad Output Read (1-1-4) 0: Not supported, 1: Supported 22 1 Reserved FFh 23 1 Reserved FFh 33h 31:24 1111 1111 FFh 34h 07:00 1111 1111 FFh 35h 15:08 1111 1111 FFh 36h 23:16 1111 1111 FFh 37h 31:24 0000 0011 03h 38h 04:00 00100 44h 07:05 010 15:08 1110 1011 Flash Memory Density Fast Quad I/O (1-4-4) Number of dummy clocks Number of dummy clocks Fast Quad I/O (1-4-4) Number of mode bits Number of mode bits Fast Quad I/O (1-4-4) Read Opcode Opcode or FFh 39h EBh AT25SL641 DS-25SL641–113F–12/2018 53 Table 7-10. SFDP Parameters Table 1 Description Comment Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) Fast Quad Output (1-1-4) Number of dummy clocks Number of dummy clocks 3Ah 20:16 01000 08h Fast Quad Output (1-1-4) Number of mode bits Number of mode bits 23:21 000 Fast Quad Output (1-1-4) Read Opcode Opcode or FFh 3Bh 31:24 0110 1011 6Bh Fast Dual Output (1-1-2) Number of dummy clocks Number of dummy clocks 3Ch 04:00 01000 08h Fast Dual Output (1-1-2) Number of mode bits Number of mode bits 07:05 000 Fast Dual Output (1-1-2) Read Opcode Opcode or FFh 3Dh 15:08 0011 1011 3Bh Fast Dual I/O (1-2-2) Number of dummy clocks Number of dummy clocks 3Eh 20:16 00000 80h Fast Dual I/O (1-2-2) Number of mode bits Number of mode bits 23:21 100 Fast Dual I/O (1-2-2) Read Opcode Opcode or FFh 3Fh 31:24 1011 1011 BBh Fast Dual DPI (2-2-2) 0: Not supported, 1: Supported 40h 0 0 FEh Reserved FFh 03:01 111 Fast Quad QPI (4-4-4) 0: Not supported, 1: Supported 04 1 Reserved FFh 07:05 111 Reserved FFh 41h 15:08 1111 1111 FFh Reserved FFh 42h 23:16 1111 1111 FFh Reserved FFh 43h 31:24 1111 1111 FFh Reserved FFh 44h 07:00 1111 1111 FFh Reserved FFh 45h 15:08 1111 1111 FFh Fast Dual DPI (2-2-2) Number of dummy clocks Number of dummy clocks 46h 20:16 0 0000 00h Fast Dual DPI (2-2-2) Number of mode bits Number of mode bits 23:21 000 Fast Dual DPI(2-2-2) Opcode or FFh 47h 31:24 1111 1111 FFh Reserved FFh 48h 07:00 1111 1111 FFh Reserved FFh 49h 15:08 1111 1111 FFh Read Opcode AT25SL641 DS-25SL641–113F–12/2018 54 Table 7-10. SFDP Parameters Table 1 Description Comment Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) Fast Quad QPI (4-4-4) Number of dummy clocks Number of dummy clocks 4Ah 20:16 00010 42h Fast Quadl QPI (4-4-4) Number of mode bits Number of mode bits 23:21 010 Fast Quad QPI(4-4-4) Opcode or FFh 4Bh 31:24 1110 1011 EBh Erase type-1 Size 4KB = 2^0Ch, 32KB = 2^0Fh, 64KB = 2^10h; (2^Nbyte) 4Ch 07:00 0000 1100 0Ch Erase type-1 Opcode Opcode or FFh 4Dh 15:08 0010 0000 20h Erase type-2 Size 4KB = 2^0Ch, 32KB = 2^0Fh, 64KB = 2^10h; (2^Nbyte) 4Eh 23:16 0000 1111 0Fh Erase type-2 Opcode Opcode or FFh 4Fh 31:24 0101 0010 52h Erase Type-3 Size 4KB = 2^0Ch, 32KB = 2^0Fh, 64KB = 2^10h; (2^Nbyte) 50h 07:00 0001 0000 10h Erase Type-3 Opcode Opcode or FFh 51h 15:08 1101 1000 D8h Erase Type-4 Size 4KB = 2^0Ch, 32KB = 2^0Fh, 64KB = 2^10h; (2^Nbyte) 52h 23:16 0000 0000 00h Erase Type-4 Opcode Opcode or FFh 53h 31:24 1111 1111 FFh Erase Maximum/Typical Ratio Maximum = 2 * (COUNT + 1) * Typical 03:00 0011 Erase type-1 Typical time Count or 00h 54h 55h 56h 57h 08:04 0 0011 33h 62h D5h 00h Erase type-1 Typical units 00b: 1ms 01b: 16ms 10b: 128ms 11b: 1s 10:09 01 Erase type-2 Typical time Count or 00h 15:11 0110 0 Erase type-2 Typical units 00b: 1ms 01b: 16ms 10b: 128ms 11b: 1s 17:16 01 Erase type-3 Typical time Count or 00h 22:18 101 01 Erase type-3 Typical units 00b: 1ms 01b: 16ms 10b: 128ms 11b: 1s 24:23 01 Erase type-4 Typical time Count or 00h 29:25 00 000 Erase type-4 Typical units 00b: 1ms 01b: 16ms 10b: 128ms 11b: 1s 31:30 00 Read Opcode AT25SL641 DS-25SL641–113F–12/2018 55 Table 7-10. SFDP Parameters Table 1 Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 58h 03:00 0100 84h 07:04 1000 12:08 0 1001 13 1 Count or 00h 17:14 01 00 Program Byte Typical units, 1st byte 0: 1µs, 1: 8µs 18 0 Program Additional Byte Typical time Count or 00h 22:19 000 0 Program Additional Byte Typical units 0: 1µs, 1: 8µs 23 0 Erase Chip Typical time Count or 00h 28:24 0 0111 Erase Chip Typical units 00b: 16ms 01b: 256ms 10b: 4s 11b: 64s 30:29 10 Reserved 1h 31 1 Prohibited Op during Program Suspend see datasheet 03:00 11010 Prohibited Op during Erase Suspend see datasheet 07:04 1110 Description Comment Program Maximum/Typical Ratio Maximum = 2 * (COUNT + 1) * Typical Page Size 2^N bytes Program Page Typical time Count or 00h Program Page Typical units 0: 8µs, 1: 64µs Program Byte Typical time, 1st byte 59h 5Ah 5Bh 5Ch 29h 01h C7h ECh AT25SL641 DS-25SL641–113F–12/2018 56 Table 7-10. SFDP Parameters Table 1 Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 5Dh 5Eh 5Fh 08 1 12:09 0 000 A1h 07h 3Dh Count or 00h 17:13 11 101 Program Suspend Maximum units 00b: 128ns, 01b: 1µs, 10b: 8µs, 11b: 64µs 19:18 01 Erase Resume to Suspend time Count of 64µs 23:20 0000 Erase Suspend Maximum time Count or 00h 28:24 1 1101 Erase Suspend Maximum units 00b: 128ns, 01b: 1µs, 10b: 8µs, 11b: 64µs 30:29 01 Suspend / Resume supported 0: Program and Erase suspend supported 1: not supported 31 0 Program Resume Opcode Opcode or FFh 60h 7:0 0111 1010 7Ah Program Suspend Opcode Opcode or FFh 61h 15:8 0111 0101 75h Resume Opcode Opcode or FFh 62h 23:16 0111 1010 7Ah Suspend Opcode Opcode or FFh 63h 31:24 0111 0101 75h Reserved 11b 64h 01:00 11 F7h Status Register Busy Polling xxxxx1b: Opcode = 05h, bit 0 = 1 Busy, xxxx1xb: Opcode = 70h, bit 7 = 0 Busy, Others: reserved 07:02 1111 01 Exit Deep Power-down time Count or 00h 12:08 0 0010 Exit Deep Power-down units 00b: 128ns, 01b: 1µs, 10b: 8µs, 11b: 64µs 14:13 01 Exit Deep Power-down Opcode Opcode or FFh 22:15 101 0101 1 Enter Deep Power-down Opcode Opcode or FFh 30:23 101 1100 1 Deep Power-down Supported 0: Deep Power-down supported, 1: not supported 31 0 Description Comment Reserved 1h Program Resume to Suspend time Count of 64µs Program Suspend Maximum time 65h 66h 67h A2h D5h 5Ch AT25SL641 DS-25SL641–113F–12/2018 57 Table 7-10. SFDP Parameters Table 1 Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 68h 69h 6Ah 03:00 1001 08:04 0 0001 19h F6h 1Ch 09 1 Fast Quad I/O Continuous (0-4-4) Exit 15:10 1111 01 Fast Quad I/O Continuous (0-4-4) Enter 19:16 1100 Quad Enable Requirements (QER) 22:20 001 23 0 6Bh 31;24 1111 1111 FFh 6Ch 06:00 110 1000 E8h 07 1 Description Comment Disable 4-4-4 Read Mode Enable 4-4-4 Read Mode Fast Quad I/O Continuous (0-4-4) supported 0: not supported, 1: Quad I/O 0-4-4 supported HOLD or RESET Disable 0: not supported, 1: use Configuration register bit 4 Reserved FFh Status Register Opcode Reserved 1h Soft Reset Opcodes 6Dh 13:08 01 0000 4-Byte Address Exit 6Eh 23:14 1100 0000 00 4-Byte Address Enter 6Fh 31:24 1000 0000 10h C0h 80h Table 7-11. SFDP Parameters Table 2 Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) 1650h: 1.65V, 1700h: 1.70V, 2300h: 2.30V, 2500h: 2.50V, 2700h: 2.70V 80h 81h 15:0 0000 0000 0001 0111 00h 17h 1950h: 1.95V, 3600h: 3.60V, 4000h: 4.00V, 4400h: 4.40V 82h/83h 31:16 0000 0000 0010 0000 00h 20h Description Comment VCC Minimum Voltage VCC Maximum Voltage AT25SL641 DS-25SL641–113F–12/2018 58 Table 7-11. SFDP Parameters Table 2 Description Comment Address (h) Byte Address (Bit) Data (b) (Bit) Data (h) (Byte) Array Protection Method 10b: Use non-volatile Status register 84h 85h 01:00 00 00h 00h Power up Protection default 0: power up unprotected 1: power up protected 02 0 Protection Disable Opcodes 011b: Use status register 05:03 000 Protection Enable Opcodes 011b: Use status register 08:06 0 00 Protection Read Opcodes 011b: Use status register 11:09 000 Protection Register Erase Opcode 00b: Not supported, 01b: Opcodes 3Dh, 2Ah, 7Fh, CFh, 13:12 00 Protection Register Program Opcode 00b: Not supported 01b: Opcodes 3Dh, 2Ah, 7Fh, FCh 15:14 00 Reserved FFh 86h 23:16 1111 1111 FFh Reserved FFh 87h 31:24 1111 1111 FFh Reserved FFh 88h - FFh 7.36 Reserved Enter Secured OTP (B1h) The Enter Secured OTP instruction is used for entering the additional 4 Kbit secured OTP mode. The OTP array is independent from main array, which may be used to store unique serial number for system identifier. After entering the Secured OTP mode, and then follow standard read or program, procedure to read out the data or update data. The Secured OTP data cannot be updated again once it is locked down. Note that the Write Status Register-1, Write Status Register-2 and Write Security Register instructions are not acceptable during the access to the secure OTP region. Once security OTP is locked down, only commands related with read are valid. The Enter Secured OTP instruction sequence is shown in Figure 7-56. Figure 7-56. Enter Secured OTP Instruction for SPI Mode (left) and QPI Mode (right) AT25SL641 DS-25SL641–113F–12/2018 59 7.37 Exit Secured OTP (C1h) The Exit Secured OTP instruction is for exiting the additional 4 Kbit secured OTP mode. (Please refer to Figure 7-57). Figure 7-57. Exit Secured OTP instruction for SPI Mode (left) and QPI Mode (right) 7.38 Read Security Register (2Bh) The Read Security Register read the value of Security Register bits at any time (even in program/erase/write status register-1 and write status register-2 condition) and continuously. Secured OTP Indicator bit. The Secured OTP indicator bit shows whether the chip is factory-locked or non-factorylocked. When the bit is “0”, it indicates a non-factory lock, a “1” indicates a factory-lock. Lock-down Secured OTP (LDSO) bit. By writing Write Security Register instruction, the LDSO bit may be set to “1” for customer lock-down purpose. However, once the bit it set to “1” (Lock-down), the LDSO bit and the 4 Kbit Secured OTP area cannot be updated any more. While it is in 4 Kbit Secured OTP mode, array access is not allowed to write. Table 7-12. Security Register Definition Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 x x x x x x LDSO (indicate if lock- down) Secured OTP indicator bit Reserved Reserved Reserved Reserved Reserved Reserved 0: no lock down 0: non factory lock 1: factory lock 1: lock- down (cannot program/ erase OTP) Volatile bit Volatile bit Volatile bit Volatile bit Volatile bit Volatile bit Non Volatile bit Non-Volatile bit AT25SL641 DS-25SL641–113F–12/2018 60 Figure 7-58. Read Security Register Instruction (SPI Mode) Figure 7-59. Read Security Register Instruction (QPI Mode) 7.39 Write Security Register (2Fh) The Write Security Register instruction is for changing the values of Security Register bits. Unlike the Write Status Register, the Write Enable instruction is not required before executing the Write Security Register instruction. The Write Security Register instruction may change the value of bit 1 (LDSO) for customer to lock-down the 4 Kbit Secured OTP area. Once the LDSO bit is set, the Secured OTP area can no longer be updated. The CS must go high exactly at the boundary; otherwise, the instruction is rejected and not executed. AT25SL641 DS-25SL641–113F–12/2018 61 Figure 7-60. Write Security Register Instruction for SPI Mode (left) and QPI Mode (right) 7.40 4 Kbit Secured OTP This value provides a 4 Kbit one-time-program area for setting t h e device unique serial number which may be set by the factory or the customer. • Security register bit 0 indicates whether the chip is locked by factory or not. • To program the 4K-bit secured OTP by entering 4K-bit secured OTP mode (with ENSO command) and going through normal program procedure, and then exiting 4K-bit secured OTP mode by writing EXSO command • The customer may lock-down bit 1 as “1”. Note. Once the value is locked down by either the factory the or customer, it can no longer be changed. While in 4 Kbit secured OTP mode, array access is not allowed to write. Table 7-13. Encoding of 4K bit Secured OTP Address Address Range Size Standard Customer Lock 000000 ~ 00000F 128 bits ESN (Electrical Serial Number) Determined by customer 000010 ~ 0001FF 3,968 bits N/A AT25SL641 DS-25SL641–113F–12/2018 62 8. Electrical Characteristics Table 8-1. Absolute Maximum Ratings(1) Parameter Symbol Conditions Range Unit -0.6 to VCC+0.4 V Supply Voltage VCC Voltage Applied to Any Pin VIO Relative to Ground -0.6 to VCC +0.4 V Transient Voltage on any Pin VIOT
AT25SL641-MHE-T 价格&库存
很抱歉,暂时无法提供与“AT25SL641-MHE-T”相匹配的价格&库存,您可以联系我们找货
AT25SL641-MHE-T
  • 6000+11.925686000+1.44076
库存:18780
AT25SL641-MHE-T
  • 1+17.297431+2.08972
  • 10+15.7430510+1.90194
  • 25+15.3167925+1.85044
  • 50+15.2385550+1.84099
  • 100+13.62170100+1.64566
  • 250+13.58215250+1.64088
  • 500+13.37702500+1.61610
  • 1000+12.809071000+1.54748
库存:18780
