Mono Enclosed Speaker - 3W 4 Ohm
PRODUCT ID: 3351
Description
Listen up! This 2.8" x 1.2" speaker is a great addition to any audio project where you need 4 ohm
impedance and 3W or less of power. We particularly like this speaker as it is small and enclosed
for good audio volume and quality. It has a handy JST 2PH input cable to add audio to your
displays and other projects (this connector is part of the JST‐PH series which is ~2.0mm spacing).
This speaker will work peachy‐keen with any of our mono audio amps, such as the PAM8302 or
MAX98357A mono class D amplifiers.
We also sell this as a 'stereo set' over here if you want 2 at a time.
Technical Details
o
o
o
o
o
Speaker weight: 26.4g
Dimensions: 30mm x 70mm x 17mm / 1.2" x 2.8" x .7"
Cable is 22.5" long
3.4mm diameter mounting holes
63mm x 24mm mounting rectangle
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3351”相匹配的价格&库存,您可以联系我们找货
