AI-2604-TF-LW115-24V-R
    PUIAUDIO
    BUZZER MAGNETIC 24V 26MM CHASSIS
AI-2604-TF-LW115-24V-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 30 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 24 20 ~ 28 25 82 400 100 CONTINUOUS -20 ~ +60 -30 ~ +70 UL-94 ABS LEAD WIRES 10 Vdc Vdc mA dBA Hz 0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED RESONANT FREQUENCY REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPL, LEAD WIRE TOLERNCE 8/9/2006 1/29/2007 2/4/2008 2/25/2020 R.W. B.R. M.L. 2010, PUI AUDIO Inc. C C grams 2 3.1 (2) 115 5 5 2 UL1007 AWG #26 26 32.2 39 RED (+)/BLACK (-) 16.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-2604-TF-LW115-24V-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 7/31/2006 E.P. 8/9/2006 B.R. 8/9/2006 2/4/2008 AI-2604-TF-LW115-24V-R Indicator Edition Sheet - 1/1
AI-2604-TF-LW115-24V-R 价格&库存
很抱歉,暂时无法提供与“AI-2604-TF-LW115-24V-R”相匹配的价格&库存,您可以联系我们找货
