XL-5530L-LW300-S-R
XL-5530L-LW300-S-R
    PUIAUDIO
    AUDIO PIEZO INDICATOR 6-16V CHAS
XL-5530L-LW300-S-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 6 ~ 16 260 123 2,000/4,000 500 SIREN -40 ~ +70 -40 ~ +70 UL94 ABS LEAD WIRES 89.4 Vdc Vdc mA dBA Hz 3.0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED LENGTH DIMENSION REVISED OPERATING TEMPERATURE REVISED OPERATING TEMPERATURE REVISED WEIGHT 5/15/2006 3/26/2008 9/1/2011 4/9/2018 11/21/2019 2/27/2020 B.R. B.R. M.V. M.L. M.V. C C grams 56 54.5 41 AWG #28 RED (+) +1 3 -0 BLACK (-) 50 14.5 8 3 1 18 6 300 10 9 NOTES: 5 (2) MOUNTING BRACKET 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 XL-5530L-LW300-S-R.idw Designed by Date Checked by Date Approved by J.D. 5/15/2006 E.P. 5/15/2006 B.R. Date Drawn Date 5/15/2006 3/26/2008 XL-5530L-LW300-S-R Indicator Edition Sheet - 1/1
XL-5530L-LW300-S-R 价格&库存
很抱歉,暂时无法提供与“XL-5530L-LW300-S-R”相匹配的价格&库存,您可以联系我们找货
