DC
DC Fan
San Ace 80 9R type
DC Fan 80 mm sq.
80×80×25 mm
Model 109R0812E401 is not certified.
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Yellow
Sensor
· Mass………………………………………… 110 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
SPL
Operating temperature
[V]
[V]
[A]
[W]
[min-1]
[m3/min]
[CFM]
[Pa]
[inchH2O]
[dB (A)]
[˚C]
[h]
1.25
0.85
4.44
2.88
2.16
1.56
1.32
1.08
0.72
2600
2350
4500
3700
3400
2900
2600
2350
1850
0.92
0.83
1.5
1.31
1.2
1.03
0.92
0.83
0.65
32.5
29.3
53.0
46.3
42.4
36.4
32.5
29.3
23.0
28.4
22.5
80.4
57.8
48.0
35.3
28.4
22.5
14.7
0.114
0.09
0.323
0.232
0.193
0.142
0.114
0.09
0.059
26
23
40
35
34
29
26
23
-20 to +70
60000/60˚C
(90000/40˚C)
-20 to +60
40000/60˚C
(70000/40˚C)
-20 to +70
60000/60˚C
(90000/40˚C)
7 to 13.8
0.25
0.17
0.37
0.24
0.18
0.13
0.11
0.09
0.06
20.4 to 26.4
0.2
4.8
4500
1.5
53.0
80.4
0.323
40
-20 to +60
40000/60˚C
(70000/40˚C)
0.1
0.07
0.06
0.05
0.04
2.4
1.68
1.44
1.2
0.96
3400
2900
2600
2350
1850
1.2
1.03
0.92
0.83
0.65
42.4
36.4
32.5
29.3
23.0
48.0
35.3
28.4
22.5
14.7
0.193
0.142
0.114
0.09
0.059
34
29
26
23
-20 to +70
60000/60˚C
(90000/40˚C)
0.1
4.8
4600
1.56
55.1
88.4
0.355
41
-20 to +60
0.06
2.88
3400
1.2
42.4
48.0
0.193
34
-20 to +70
109R0805F401
109R0805M401
109R0812G401
109R0812E401
109R0812S401
109R0812H401
109R0812F401
109R0812M401
109R0812L401
5
4.5 to 5.5
10.8 to 13.2
6 to 13.8
12
109R0824G401
109R0824S401
109R0824H401
109R0824F401
109R0824M401
109R0824L401
24
12 to 27.6
14 to 27.6
109R0848K401
48
109R0848S401
40.8 to 55.2
Max. airflow
Max. static pressure
Expected life
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
Note 1: Sensor and control options are available for selection. Refer to the table on p. 623.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
109R0805F401
109R0805M401
With pulse sensor
(inch H O) (Pa)
0.125
0.050
0.025
0.14
40
5.5 V
5V
30
4.5 V
0.100
0.075
40
0.12
0.35
30
5.5 V
5V
4.5 V
0.10
0.08
Static pressure
0.150
0.16
Static pressure
Static pressure
0.175
(inch H2O) (Pa)
2
50
0.06
0.04
10
0.5
30
Airflow
40
1.5 (m3/min)
50
(CFM)
0.25
0.20
0.15
0.10
0.05
0.02
With pulse sensor
(inch H O) (Pa)
2
0.200
109R0812G401
With pulse sensor
0.8
Airflow
1.2 (m3/min)
40
(CFM)
90
80
70
60
50
40
30
13.2 V
12 V
10.8 V
0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8
(m3/min)
10 20 30 40 50 60 70 (CFM)
Airflow
CATALOG No. C1111B002 '21.9.IT
109
109R0812E401
109R0812S401
With pulse sensor
109R0812H401
With pulse sensor
With pulse sensor
(inch H2O) (Pa)
0.30
0.25
80
13.8 V
60
0.20
0.15
0.10
0.05
12 V
40
6V
1.5
1.0
2.0 (m3/min)
0 10 20 30 40 50 60 70
(inch H2O) (Pa)
70
0.25
60
0.20
50
0.15
0.10
40
6V
30
10
10
109R0812M401
With pulse sensor
0.125
0.025
40
50
50
0.16
40
13.8 V
12 V
30
6V
10
0.5
6V
10
0.12
109R0812L401
1.0
30
40
1.5 (m3/min)
50
30
13.8 V
12 V
6V
10
(CFM)
0.8
109R0824S401
40
50
(CFM)
0.8
(m3/min)
With pulse sensor
30
1.2 (m3/min)
40
0.10
0.09
0.08
0.07
0.06
0.05
0.04
0.03
0.02
0.01
13.8 V
12 V
15
7V
10
5
(CFM)
0.4
10
5
Airflow
With pulse sensor
30
(inch H2O) (Pa)
40
0.06
0.04
1.5 (m3/min)
0.10
0.08
1.0
Airflow
With pulse sensor
Airflow
109R0824G401
0.075
13.8 V
12 V
30
(CFM)
0.14
0.100
1.5 (m3/min)
(inch H2O) (Pa)
0.100
0.075
1.0
Static pressure
Static pressure
0.150
0.125
50
Airflow
(inch H2O) (Pa)
0.175
0.150
0.025
(CFM)
0.200
0.175
12 V
Airflow
109R0812F401
0.200
13.8 V
Static pressure
Static pressure
0.35
100
Static pressure
0.40
Static pressure
0.30
(inch H2O) (Pa)
0.6
15
30 (CFM)
Airflow
109R0824H401
With pulse sensor
With pulse sensor
(inch H2O) (Pa)
0.30
0.25
0.20
0.15
0.10
0.05
26.4 V
24 V
20.4 V
(m3/min)
(inch H2O) (Pa)
70
0.25
60
0.20
50
0.15
0.10
24 V
12 V
30
10
109R0824M401
With pulse sensor
0.050
0.025
27.6 V
24 V
30
12 V
50
10
27.6 V
24 V
30
0.075
0.050
12 V
(CFM)
10
0.12
109R0824L401
With pulse sensor
1.0
30
40
1.5 (m3/min)
50
Airflow
(CFM)
40
50
(CFM)
0.8
(m3/min)
With pulse sensor
(inch H2O) (Pa)
30
27.6 V
24 V
12 V
0.06
0.04
1.5 (m3/min)
40
0.10
0.08
1.0
Airflow
10
0.02
40
0.14
0.100
0.075
30
40
0.100
1.5 (m3/min)
(inch H2O) (Pa)
50
Static pressure
0.125
1.0
(inch H2O) (Pa)
0.150
0.125
50
Airflow
0.175
0.150
0.025
Airflow
0.200
0.175
40
109R0824F401
0.200
27.6 V
Static pressure
Static pressure
0.35
0.30
100
90
80
70
60
50
40
30
Static pressure
0.40
Static pressure
(inch H2O) (Pa)
Static pressure
DC
DC Fan 80 mm sq.
0.8
Airflow
1.2 (m3/min)
40
(CFM)
0.10
0.09
0.08
0.07
0.06
0.05
0.04
0.03
0.02
0.01
27.6 V
24 V
15
14 V
10
5
0.4
10
15
0.6
Airflow
25
30 (CFM)
109R0848S401
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
Static pressure
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
110
100
90
80
70
60
50
40
30
55.2 V
48 V
40.8 V
0.5
1.0
1.5
Static pressure
0.45
With pulse sensor
DC Fan 80 mm sq.
109R0848K401
DC
60
0.20
50
0.15
0.10
55.2 V
48 V
40
40.8 V
30
10
2.0 (m3/min)
70
0.25
0.5
(CFM)
10
Airflow
■ Dimensions (unit: mm)
30
1.5 (m3/min)
40
50
(CFM)
Airflow
(With ribs)
80±0.5
4-ø4.3±0.3
Mounting hole
71.5±0.3
25±0.5
(3)
(3)
+30
300 0
71.5±0.3
80±0.5
Lead wire
AWG24
UL 1007
(10)
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
71.5±0.3
4-ø4.5
78.5
71.5±0.3
ø9
78.5
■ Options
Finger guards
page: p. 584
Model no.: 109-049E, 109-049H, 109-049C
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1002G
page: p. 592
Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI),
109-1002F30 (30PPI), 109-1002F40 (40PPI)
111
很抱歉,暂时无法提供与“109R0812F4021”相匹配的价格&库存,您可以联系我们找货
