9LB1212H101
9LB1212H101
    SANYODENKI
    FAN120X38MM12VDCRBLSTACH
9LB1212H101 数据手册
Long Life Fan 120 San Ace 120L 38mm thick (9LB type) 38mm thick (9GL type) mm sq. ■ General Specifications ・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1) ・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ , rated voltage, and continuously run in a free air state) Sensor yellow ・Storage Temperature …-30℃ to +70℃(Non-condensing) ・Lead Wire …………………⊕red ⊖black or blue 120×120×38mm ■ Specifications 〔Mass:370g〕 9LB type The following nos. have pulse sensors. Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. [V] 9LB1212H101 9LB1212M101 9LB1224S101 9LB1224H101 9LB1224M101 9LB1248H101 9LB1248M101 [V] 12 10.2 to 13.8 24 20.4 to 27.6 48 40.8 to 55.2 Rated Speed Max. Airflow [A] [W] [min-1] [m³/min] 0.39 0.22 0.46 0.19 0.11 0.11 0.06 4.68 2.64 11.04 4.56 2.64 5.28 2.88 2,600 2,000 3,500 2,600 2,000 2,600 2,000 2.9 2.2 3.88 2.9 2.2 2.9 2.2 [CFM] 102.4 77.7 137.0 102.4 77.7 102.4 77.7 Max. Static Pressure SPL Operating Temperature Expected Life [Pa] [inchH²O] [dB(A)] 67.62 42.14 120.8 67.62 42.14 67.62 42.14 0.272 0.169 0.485 0.272 0.169 0.272 0.169 39 32 48 39 32 39 32 [℃] 200,000 - 20 to + 70 Some models can also be equipped without sensors or with PWM control functions as an option. Please refer to the index (pp. 417 to 437). ■ Dimensions(unit : mm) 8-φ4.3±0.3 Mounting 取付用穴 Hole +30 300 0 104.8±0.3 119±0.8 (10) Lead Wire リード線 AWG24 UL1007 6.5±0.3 3.5±0.3 104.8±0.3 119±0.8 6.5±0.3 3.5±0.3 38±0.5 回転方向 Rotating Direction Airflow Direction 風吹出方向 ■ Reference Dimension of Mounting Holes and Vent Opening(unit : mm) Inlet side Outlet side 104.8±0.3 104.8±0.3 117 311 117 104.8±0.3 φ 13 0 4-φ4.5 117 104.8±0.3 117 φ 12 7 4-φ4.5 [h] 100,000 200,000 ■ Options(unit : mm) Finger Guards Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Outlet side Model:109-1000G 119±1 4.3±0.3 130 119±1 13 φ1 +1.5 152.5 ー0.5 質量:23g Mass DC 質量:32g Mass Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Resin Filter Kits Model:109-1000F13(13PPI) ,109-1000F20(20PPI) :109-1000F30(30PPI) ,109-1000F40(40PPI) 10.5±0.5 124±1 Inlet side, Outlet side 104.8±0.3 124±1 130 4.3±0.3 φ18.6 13 φ1 4-φ4.3±0.3 104.8±0.3 +1 5 0 φ1.6 φ1.6 152.5±0.5 4-φ4.3±0.3 4-2±0.5 φ1.6 2 Model:109-019E :109-019K 7±0.5 104.8±0.3 Long Life Fan 120mm φ148 +1 5  0 φ1.6 φ4 2. Resin Finger Guards 104.8±0.3 Model:109-019C :109-019H 8 φ14 4-φ11±0.5 4-2±0.5 質量:42g Mass 質量:44g Mass ■ Airflow - Static Pressure Characteristics H speed M speed (inch H2O)(Pa) 0.25 13.8V/27.6V/55.2V 70 12V/24V/48V 60 0.20 50 0.15 40 0.10 0.05 0 70 80 10.2V/20.4V/40.8V 30 20 10 0 1 2 3 4 (m /min) 3 0.25 60 0.20 50 0.15 0.10 0.05 0 12V/24V/48V 40 10.2V/20.4V/40.8V 30 20 10 0 1 2 3 (m /min) 3 0 20 40 60 80 100 120 140 (CFM) 0 9LB1212H101 9LB1224H101 9LB1248H101 9LB1212M101 9LB1224M101 9LB1248M101 風量 →→ Airflow 0.6 13.8V/27.6V/55.2V → Static → 静圧 Pressure 0.30 90 → Static Pressure → 静圧 → Static Pressure → 静圧 0.35 S speed (inch H2O)(Pa) (inch H2O)(Pa) 20 40 60 80 100 風量 →→ Airflow (CFM) 160 140 0.5 120 27.6V 0.4 100 24V 0.3 0.2 80 20.4V 60 40 0.1 20 0 0 1 2 3 4 5 (m3/min) 0 20 40 60 80 100 120 140 160 180 (CFM) 風量 →→Airflow 9LB1224S101 312
9LB1212H101 价格&库存
很抱歉,暂时无法提供与“9LB1212H101”相匹配的价格&库存,您可以联系我们找货
