SBR-160-RGBW-R41-RD100 数据手册
SBM-160 LED
Binning and Labeling
Introduction
Table of Contents
This document describes the binning and labeling nomenclature
for PhlatLight LED products as well as the orderable bin kits for
each part.
Table of Products ................................................ 2
With each build of parts, there is a distribution of performance
in both flux and wavelength or chromaticity. In order to guarentee specific performance for customers, each device is measured and subsequently grouped into flux and wavelength or
chromaticity bins. Each individual package or reel of parts contains only one combination of flux and wavelength or chromaticity bin. Furthermore, bins are combined into orderable bin kits
comprising of a selection of flux and wavelength or chromaticity
bins to ease the ordering process.
Shipping and Labeling Nomenclature ......................... 3
Bin Kit Ordering Nomenclature ................................ 4
White Flux Binning Structure................................... 5
White Chromaticity Binning Structure ........................ 6
SBM-160 Bin Kit Codes........................................... 8
www.luminus.com
© 2011 Luminus Devices, Inc. - All Rights Reserved
Last Update 04-27-2011
PDS-001792 Rev 01
SBM-160 Binning and Labeling
Table of Products
Product
Ordering Part Number
Description
SBM-160-RGBW
SBM-160-RGBW-H 41-X X 1 2 3
PhlatLight SBM-160 surface mount device consisting of four
4 mm2 LED mounted on a ceramic substrate.
SBR-160-RGBW
SBR-160-RGBW-R 41-X X 1 2 3
PhlatLight SBR-160 evaluation module s consisting of a SBM160 urface mount device mounted on an Aluminum star
board.
Page 2
PhlatLight Shipping and Labeling Nomenclature
All PhlatLight products are packaged and labeled with their respective bin as outlined in the following pages. Each package or reel
will only contain one bin. The part number designation is as follows:
ABC
DEFG
H45
IJK
Chip Area
Color
Package Configuration
Flux Bin
Package
Config
Chip Area
C - Chip quantity. “M” denotes multi-chip and “R” denotes prototype board
D E F G- Color. “RGBW” denotes red Green blue white
Flux Bin
Wavelength/
Chromaticity Bin
B - Lens type. “B” denotes window (no lens).
1 2 3 - Total LED chip area (mm2) x 10. “160” denotes 16 mm2.
Wavelength/
Chromaticity
Bin
L6
A - Package type. “S” denotes surface mount
Color
Product
Family
Product Family
123
H 4 5 - Package configuration (for internal use).
I J K - Flux bin
L 6 - Wavelength / Chromaticity bin
Example:
The part number SBM-160-RGBW-H41-WEA-G4 refers to a RGBW, SBM-160 emitter, with a flux range of 510-550 lumens and a
chromaticity value within the box defined by the four points (0.313, 0.338), (0.321, 0.348), (0.322, 0.336), (0.312, 0.328).
Page 3
PhlatLight Bin Kit Ordering Nomenclature
All PhlatLight White products are sold in sets of flux and chromaticity bins called bin kits. Each bin kit specifies a minimum flux bin and
a specific selection of chromaticity bins. The ordering part number designation is as follows:
ABC
DEFG
H45
Chip Area
Color
Chip Area
Package
Config
Bin Kit
Bin Kit
IJ678
Color
Product
Family
Product Family
123
I J - Flux bin kit code
6 7 8 - Wavelength / Chromaticity bin kit code
Example:
The ordering part number SBM-160-RGBW-H41-RE101 refers to a bin kit containing a minimum flux value of 510 lumens and falling
in the F4, F3, G4, G3, EF, and DG chromaticity bins.
Page 4
PhlatLight White Flux Binning Structure
All white PhlatLight LEDs are tested for luminous flux and placed into one of the following flux bins. Not all flux bins are currently
available for each product, so consult the specific product datasheet for the list of available flux bins for the specific product.
White Flux Bins
Flux Bin Code (FF)
Composite Bin Code
Minimum Luminous Flux
Maximum Luminous Flux
WD
WDA,WDB
440
510
WE
WEA,WEB
510
590
•Note: Luminus maintains a tolerance of +/- 6% on all flux measurements.
Page 5
PhlatLight White Chromaticity Binning Structure
All white PhlatLight LEDs are tested for chromaticity and placed into one of the following chromaticity bins. The binning structure is
universally applied across the full white product line, however not all chromaticity bins are currently available for each product. Consult the specific product datasheet for the list of available chromaticity bins for the specific product.
Luminus’ Standard Chromaticity Bins: 1931 CIE Curve
Page 6
6500K Chromaticity Bins
Bin Code
(WW)
DG
F3*
F4*
G3*
G4*
EF
DE
DF
CIEx
CIEy
0.307
0.322
0.323
0.309
0.305
0.313
0.315
0.307
0.303
0.312
0.313
0.305
0.313
0.321
0.322
0.315
0.312
0.321
0.321
0.313
0.302
0.320
0.321
0.303
0.283
0.303
0.307
0.289
0.289
0.307
0.309
0.293
0.311
0.326
0.316
0.302
0.321
0.329
0.319
0.311
0.330
0.339
0.329
0.321
0.329
0.337
0.326
0.319
0.339
0.348
0.337
0.329
0.335
0.354
0.348
0.330
0.304
0.330
0.311
0.293
0.293
0.311
0.302
0.285
5700K Chromaticity Bins
Bin Code
(WW)
DJ
H3*
H4*
J3*
J4*
EH
CIEx
CIEy
0.322
0.337
0.336
0.323
0.321
0.329
0.329
0.322
0.321
0.329
0.329
0.321
0.329
0.337
0.337
0.330
0.329
0.338
0.337
0.329
0.320
0.338
0.338
0.321
0.324
0.337
0.326
0.314
0.335
0.342
0.331
0.324
0.346
0.354
0.342
0.335
0.342
0.349
0.337
0.331
0.354
0.362
0.349
0.342
0.352
0.368
0.362
0.346
Page 7
SBM-160 Bin Kit Order Codes
The following tables describe the bin kit ordering codes for the SBM-160 and the flux and wavelength or chromaticity bins included in
the bin kit. Each kit specifies a minimum flux and the listed wavelength or chromaticity bins. A maximum flux is not specified. Within
each kit, Luminus may ship any part meeting or exceeding the minimum flux specification. Shipments will always meet the listed wavelength or chromaticity bins. For information on ordering bin kits not listed below, please contact Luminus or an official distributor.
SBM-160-RGBW-H41-XX123
Color
Luminous Flux
Bin Kit Flux Code
Minimum Flux
RD
440
RGBW
RE
510
Chromaticity Bins
Kit Number
F4, F3, G4, G3, EF, DG, DE, DF
RD100
RD101
F4, F3, G4, G3
RD102
RE100
RE101
F4, F3, G4, G3
RE102
SBR-160-RGBW-R41-XX123
Color
Luminous Flux
Bin Kit Flux Code
Minimum Flux
RD
440
RGBW
RE
510
Chromaticity Bins
Kit Number
RD100
RD101
F4, F3, G4, G3
RD102
RE100
RE101
F4, F3, G4, G3
RE102
Page 8
The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus
Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product
or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of
the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as
accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may
have in such information. PhlatLight® is a registered trademark of Luminus Devices, Inc., all rights reserved.
This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871;
7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059; Patents Pending in the U.S. and other countries.
www.luminus.com
Page 9
